Question about Sony STR-DA3000ES Receiver
Won't power up
Unit has been working fine. Suddenly will not power up. I've tried unplugging it, etc.
Any ideas?
    Scholar:
  • 142 Answers
Does the unit light up...standby light...anything?? If the unit is completely dead then you have a bad stand-by power circuit...98% of the time the stand-by transformer is bad. It is a tiny transformer usually near the back of the unit and MOST of the time right where the ac line goes through the back panel. To test this part you need an volt-ohm-meter or digital multi-meter. The input side of this transformer (side where ac goes into) must have continuity (current will pass through it). It most likely will read "open" on the meter. This part is available from tritronicsinc.com. Good luck!
barneyluc
Posted on Oct 14, 2008
HP Compaq Presario SR1430NX Powering On Issues...HELP!!??!??
If the power supply is "Fine" then it has to be your motherboard. Look for the capacitors around the board. They should have either a dished or flat top. If any are domed or have a powdery substance on them, they will need replacing. Or if you don't want to do this, replace the board.
Apr 26, 2013 | HP Compaq Presario SR1430NX (PS566AA) PC...
Cabrio washer won't fill normally but diagnostic shows valves are fine
when doing the diagnostic testing machine fill up almost full and stop display an ol mode
Apr 17, 2013 | Whirlpool WTW6400SW Cabrio Washer
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
All of a sudden the MP560 won't turn on. The outlet is working but the printer doesn't respond to the ON button. I've checked the power cord it seems to be ok, the cord hasn't moved or been...
This may be a longshot, but many electronic devices like TVs, dryers with electronic computerized controls, entertainment systems like the Wii, and other devices sometimes get "confused" and won't turn on, turn off, or otherwise work properly, perhaps due to a small power surge in your AC line.
I've found that one of the first things to try when it appears to be a failure of the electronics and not a mechanical issue is to unplug the device at the wall (to make sure that any power adapter is also unplugged) and wait about 10 minutes for any residual electric charge to dissipate. Then plug the device back in and give it a try. This has worked with a television, a Wii console, an electric clothes dryer, and some other devices that I thought had died for good. This may explain why sometimes a device is taken to a repair shop and it works fine.
There are, of course, other reasons that the unit won't turn on, but I would try this first before looking for other reasons for the problem.
Jul 23, 2011 | Canon MP560 All-In-One InkJet Printer
My scanner used to work just fine, but suddenly it won't work anymore. It is plugged in and everything, but suddenly in Photoshop, the Xerox 7600 option under File > Import disappeared, and the WIA...
Have you tried an other USB cable??? have you tried a different USB port on the computer??? try the scanner on an other computer as well, does it have POWER???... eazy stepps to troubleshoot all types of devices is to first make sure the device has POWER, than concentrate on connectivity (cables, ports, etc...) than try it on an other computer, re-install drivers as well..., check for viruses also, when everything is clean and it still not working than replace the device... it's dead (send flowers) ha! just kidding!
Jul 23, 2011 | Xerox 7600 Flatbed Scanner
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
Dell Dimension 4600C won't turn on
Unplug the unit. Re-seat the Memory and Daughter-boards. Plug in and try to start.
Nov 22, 2008 | Dell Dimension 4600 PC Desktop
Open Questions:
Sony STR-DA3000ES Receiver Logo
187 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
