Question about Garden
Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
Mower just came to a stop. Engine still running but will not go forward. Goes in reverse fine but when I put it into forward it will not move. I checked belts and made sure the free wheeling lever was in the right position. Please help
  • 3 more comments
  • TiimT Oct 14, 2008
    I'll check and see. I removed the cover plate on the back of the mower so I could see the lever and check the belts. The lever seemed to be operating correctly. As soon as I move the lever back the mower starts moving in reverse. When I return it back to netural and the on to forward the lever moves as far forward as it seems possible and I can hear a whinning sound like the pump running but mower will not move.
  • Anonymous Mar 13, 2014
    My hydrostatic snowblower reverse perfect but has soon has i go foward in snow it stops going wheels dont spin if i lift the weight in the back wheels starts going foward again
  • Anonymous Mar 24, 2014
    as explained above engine starts when switched on but when put into forward or referse mode it will not move
    engine starts but cannot ddrive forward or reverse
  • Anonymous Mar 30, 2014
    Craftsman 20 HP Model 917.275661
    Hydro trans free wheels on down hill slops and slows down and to stop until I move the speed lever to a higher speed and then can reset speed lever to desired mowing speed. this problem doesn't exhist going up hill!
    Larry
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Posted on Oct 14, 2008
Riding mower no longer moves.
If this is a hydrostatic transmission, one of 3 things:
1. Drive belt off pulleys (recommend replace belt if so)
2. Belt broken (obviously, replace)
3. Hydrostatic transmission failed (least likely, but this is an expensive repair shop issue if so)
This happened to my GT1554 two weeks ago - fortunately, replacing the belt resolve the problem.
Oct 19, 2012 | Cub Cadet Garden
I have a L118 John Deere mower. When cold, the mower moves forward and reverse without problems. I mow my 1/2 acre yard and at the last couple passes, the mower barely moves forward and has no reverse. ...
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
May 23, 2011 | John Deere Garden
What kind of fluid goes in the hydrostatic drive ? The mower goes fine in forward and reverse when first started. As the mower heats up it has trouble pulling itself. After about an hour it will barely...
Hi Jeff,
Use hydrostatic fluid. Consult your owner's manual for information. Do not use hydraulic transmission fluid.
If you do not have your owner's manual, you can find one on www.managemylife.com Just go to that site, click on manuals and enter your make and model number.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 09, 2011 | Briggs & Stratton Garden
Riding mower will not move forward or backward
Assuming the engine is running and sounds good, you need to check the drive belt. With the engine OFF, make sure the topmost belt which goes from the engine to the top of the transmission is in place and snug. If it is there and in good shape, then I would suspect the hydrostatic transmission has failed. If the belt is not there, replace it; if it is loose, replace it. AGAIN DO NOT ATTEMPT TO PUT YOUR HANDS UP INSIDE A RUNNING MOWER.
Aug 22, 2010 | Husqvarna Garden
Husquvarna hydrostatic mower won't move
Sounds like the belt going to the hydrostate broke. Or a key on one of the pulleys broke. The belt runs inside of the frame and is hard to see.
Jul 11, 2010 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Oct 10, 2009 | Garden
Troy built lawn mower (riding) won't go full
I did not know riding mower had a gas pedal. I know if you leave the throttle control up all the way the engine will choke out. The pedal you are pushing, I think, is the forward/reverse hydrostatic transmission. You may need a new drive belt. The one you have now may be stretched out.
Good Day.
Oct 07, 2009 | Troy Garden
Cub Cadet engine runs but, also will not go in forward or reverse
you didnt say what model this is, but i assume its hydrostatic because it has a drive shaft. is the hydrostatic unit filled with oil¿ if its ok, check the linkage from the pedal to the rearend (hydrostatic drive) make sure its not broken or loose.. if that l@@ks ok, check both ends of the drive shaft making sure the couplers are not broke and the drive shaft is ok. hope this helps.
Jul 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
1,494 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
