Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Bad water taste coming out of Refrig
After moving to NC, our water has had a funny taste to it [like coffee]. During our move, we placed ground coffee in a stocking [it was suggested to my wife] in the refrigerator. Not sure how or why the coffee smell is in our water. I changed the water filter for a 4th time and still no luck. I replaced new filter and ran the water [a couple of gallons] and the bad taste went away. The next morning, the water was cool but again with the coffee taste. I am wondering if the water sits anywhere in the refrigerator waiting to be dispensed or in the freezer to be made into ice. Any advice is greatly appreaciated. I am tired of buying bottle water when we have a nice refrigerator.
  • Jim Jan 14, 2009
    I have a simila r problem and I believe the water tastes like medicine or plastic. Is it possible that the lines themselves are giving off the taste. I have PVC lines going to the refrigerator. I went out to see if there are different lines and they all seem to be PVC. Anyone else find the similar issues?
    elijam1
  • slmky May 02, 2009
    My Kenmore Coldspot Model # 50517002 has the same problem. We noticed a while back that the water coming from the dispenser had a mildewy taste, so we purchased a new filter and followed all the directions to properly install it. We ran gallons of water through it, changed all the ice, and it still tastes mildewy. I don't know about the ice, because usually it's in something that might cover up the nasty taste. I asked our Sears store about it, and the salesman couldn't offer any suggestions. Desperate to get this resolved, because we really use that option on the refrigerator alot.
  • 706 Answers
Hello collado36.. I'll give you a few ideas of things to try.. First off..is there a coffee scent in the refridgerator or freezer compartment when you open the door/s? If so, try emptying the fridge and wash everything with white vinegar and dry all surfaces with a soft cloth ( dish towel is OK).. air drying is OK but you don't want the food you removed to clean it to go bad.. Do you have any food in the fridge that may have been exposed to that coffee that may be 'out-gassing' that coffee smell?
The water comes into your fridge via an electrically operated inlet valve and is dispensed into the mold tray of your ice maker as well as the drinking water spicket. ( I am not sure if your model fridge has a reservoir to chill the water prior to dispensing but it probably does...but that reservoir should not be exposed to the inner refridgerator compartment nor should it pick up any scents or tastes from there either. )
In trying to diagnose exactly where the foul water is generated.. can you detach the incoming water feed line from the fridge and drain that into a large jug? Then check that jug for the same smell? If it only happens within the fridge then the white vinegar wash should help.. .if it also happens in the jug then your incoming water may be the culpret.
Another way to clean your water supply system to the firdge would be to detach the water supply line.. buy another length of flex water line with couplings.. and fill that section with white vinegar that can be forced thru the water system and clean it from the inside out.. if you do use this approach, make sure you flush teh system clean of any leftover white vinegar .. Hope these tips help you resolve your problem.. please get back to me if after you've tried these, they don't work.. Good luck..
Posted on Oct 14, 2008
May be stuck in that water tray , flush & drain out the water pipes in the fridge then leave it to try and then use as normal.It may clean the fridge as the bacteria may not grow again as there is no water
I have move to a place at around 2500m above see level and my coffee from my Nespresso machine taste very different than before, more bitter (at about 500m).
water will boil at 91.673 degrees celcuis.This will affect the brewing of coffee beans. Can you try using a finer grind of coffee ?
Nov 17, 2015 | Nespresso Coffee Makers & Espresso...
Coffee tastes bad
Brew a pot with vinegar and no coffee grounds. Then rinse well with water and run a pot or two with water alone.
Mar 08, 2015 | Miele CVA615 Espresso Machine
How can I avoid bitter coffee?
If the water that comes into contact with the coffee grounds is too hot, you will extract bitter elements from the coffee. The water should not be boiling when poured on the coffee grounds. Coffee oils, fats and sediment are the natural parts of the coffee bean that causes bitterness by forming as the brew ages. The longer the coffee sits the stronger it tastes.
Article Source :
Espresso Machines Coffee Makers Grinders Reviews
Sep 08, 2014 | Coffee Makers & Espresso Machines
BUNN MY CAFE BAD TAST WITH COFFE OR HOT COCO
Try really cleaning the basket that the water and coffee or cocao goes into. If you don't really clean it well, it will have the taste of the last thing brewed mixed in with the new brew. Coffee followed by coffee should not be a problem, but coffee followed by cocao will give the cocao a coffee taste, and visa versa.
Nov 21, 2013 | Bunn My Cafe MCU Universal 4-in-1 Single...
Ice and water tastes funny after I installed a rubber water hose
Discard the first few batches of ice made by the ice maker. If new plumbingconnections are installed, discard the first few batches of ice. The plumbingsystem is flushing and may cause a bad taste or odd color. Discard ice stored in the bin for long periods of time. Wash the ice binwith warm water and mild dish detergent. Dry thoroughly before replacing thebin. Place foods in airtight containers to prevent the transfer of odors.Thanks and hope it's helpful.
Feb 16, 2011 | Admiral 26 cu. ft. Side-By-Side...
Funny tasting coffee
Vinegar/water cleaning is a good idea, but it won't necessarilly solve funny-tasting coffee. First, replace your charcoal water filter - you can get the Cuisinart brand-name replacements at Lowe's, Bed/Bath/Beyond, or Williams-Sonoma in most areas.
To do the vinegar/water cleaning, just pour 1/3 caraffe distilled white vinegar and 2/3 caraffe water into the water reservoir and brew it like it was regular coffee - I would simply bypass the self-clean function if your Cuisinart has one. Repeat up to 3 times, using a fresh batch of vinegar each time.
(if you have the caraffe-less DCC-2000, then just pour in 4 cups vinegar and 6 cups water).
Then run a full cycle of water. Then run a combo of 12 tsp lemon juice and 12 cups water (or 10 tsp and 10 cups water) to improve the taste.
On your next batch of coffee, use bottled water just to rule out any possibility that your local water supply may be contributing to funny-tasting coffee.
Now your coffee should be tasting fine again.
-Tha Mp3 Doctor
Apr 03, 2009 | Cuisinart Coffee Makers & Espresso...
Filter basket opening during brewing
Push the permanent filter's basket handle all the way down and then reclose the filter basket drawer lid. There is a pretty flimsy piece of plastic holding it in, though - may require replacement.
Sep 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee pot
durabrand has no contacts outside china this is a unit made for and imported for walmart only walmart is the only contact ...... your problem is not anything you or walmart can do anything about the problem is the cheap plastic that is used , when it gets hot some people can taste and smell it and others cant . .. its getting more common in everthing that heats water .. personaly i would not drink anything from an appliance that puts a plastic taste in my water ..... if you move up in price the problem is reduced , better plastics are used , but your not going to get one for 10.00 ! "you get what you pay for " more now than ever .... good luck Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 18, 2008 | RoadPro 12-Volt Coffee Maker
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
508 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
