Washing Mach slow fill up of water
Hello, my Fisher & Paykel Smart Drive 703, has just recently started filling up really slowly. I have checked the water pressure through the hoses which is very good, I have clean all areas from there where the water would go until where the water comes out. It's as though somewhere between where the hoses go in to where the water comes out is held up somewhere. I can only open the lid a crack before it stops, so I can only see a slight dribble come out up the top back where it would normally come out quite strong. Would it be something electronic slowing it down or a hose that's possibly no longer sealed properly (but looks ok)? Would really appreciate some help!!! Thanks heaps!!!
I've been retired from the appliance business for many years but a friend had this problem and asked for my help . First I checked the screens where the hoses connect to machine those were ok . Next i checked the solenoids checked good . Scratched my head and decided only one thing left to check the hoses going to machine . I got a bucket disconnected hoses from machine . I aimed first one at the bucket and turned water on and wow just a trickle . I didn't have another hose but just for the heck of it I reversed the hose hooked the machine end to the faucet aimed at bucket wow got full stream of water . I hooked the faucet end to machine ran the machine worked perfect . That was three years ago and I see my friend now and then he says still working great .... Weird LOL
Posted on Apr 23, 2017
Just because you have static pressure that is good doesn't mean your flowing rate is acceptable. To check the water fill lines on both hot and cold water, use a short garden hose hooked to one and then the other. Turn on the hot valve first and see if plenty of water comes out of the hose continually...many times you will have good pressure for just seconds and then because there is a valve or pressure regulator regulator before the hot water spicot that is blocked partially all of the pressure that built up when the hot water valve was off...allowing for good pressure to finally get past the partial limescale or rusted blockage drops. Same with the cold line. Just remember to have constant good pressure. Water lines can be blocked all the way through the home and past the inlet water regulator usually located outside of the home. If you have good pressure, then start looking at the filters. There may be one in both hot and cold lines going to the back of the machine's inlet water valves. Then if they are not there or they are clean, then see if it is just one side First try the hot water only side...and then the cold side. If the cold water was side fills slowly and the hot fills up quickly you can bet that you have an inlet valve blocked. If you get no water out of one or the other side that could show up too. good luck...
Posted on May 03, 2017
    Problem Solver:
  • 9 Answers
Something you might try assuming it is a hard water problem. After you've had a look for clogged screens detach the hoses at the water supply and elevate them so that the water can flow downhill. Start a normal cycle on warm to drain the hoses. Then I'm thinking you could try and funnel a solution of CLR (calcium lime remover) into the hoses and start a warm cycle again. Repeat that numerous times and see if it helps any. Just be sure to run an empty cycle or two once you reattach the water supply to clean out the chemicals. Good luck!
Posted on Apr 26, 2017
    Habit-Forming:
  • 30 Answers
You can't go wrong with the 4 answers attached. Most people never realize how much scale & grit are in the water supply. After awhile, the screens in the hoses get clogged & block water from coming through. They can also cause problems with the solenoid inside the washer, i've read that you should inspect the hoses annually and change them every 5-7 years. While you can easily unblock the supply hoses, you can't do much about equipment failure. I have seen many videos on You Tube, and others, that actually show you how to fix/replace parts on various appliances. I have also used them with great success, and no, you don't have to be a mechanical whiz to do it either!
By now, hopefully, your washer is back up & running normally!
Posted on Apr 25, 2017
  • 20 Answers
What Potgieter GCJ said - I had to replace the solenoid/valves which regulate the water flow on our machine. The difference was amazing. It took a third as long to fill the machine after I replaced them. They came as one unit and were fairly easy to replace.
Posted on Apr 19, 2017
Try pulling the machine out far enough to access where the hoses connect to the machine. Turn off the water supply and disconnect the hoses at the machine, look into the connection at the machine and check for a small screen (if one is there it will be removable for cleaning). Most manufacturers put one it to prevent loose scale and deposits from household and city water systems from entering the machine and messing them up. The screen is similar to the screen on your kitchen faucet.
Posted on Apr 10, 2017
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Check the solenoids
Posted on Apr 07, 2017
aborcass
  • 2651 Answers
SOURCE: fisher & paykel washing machine fault codes
try removing hte screws from the rear of console and within the console usually is a techsheet with an explanation of hall hte major faults
Posted on Mar 12, 2008
  • 351 Answers
SOURCE: fisher & paykel slow to fill?
if its the cold water (most common) replace the valve remove the two screws on the top of the control panel then you will see the valve i think its the right one looking from the front.its an easy job .hope this helps.
Posted on Mar 20, 2008
aborcass
  • 2651 Answers
SOURCE: fisher and paykel smart drive 503 top loading washing machine
while under the lid there should be a tech sheet, explaining varions flashing light codes and there respective fixes for each instance, replacing tha switch(out of bal switch) seems like a good start though. cant remember if jumping it out will help, might be looking for a break in the line rather than continuity through it
Posted on Nov 02, 2008
SOURCE: Slow fill on cold water/Fisher&Paykel GWL11
Assuming you have already done what you said you have done, now it is time to do some real troubleshooting.(Dont worry, if you have gone this far you'll be able to do what I'm going to tell you)
First take the lid off. To do this, open it, and lift up on one side, it should come right off. Now take the control panel cover off. There are two screws on the back side of the washer holding it on. You'll need to wiggle it a bit to get it off. Once the cover is off you should find a plastic bag with a "service" sheet in it. The service sheet explain how to put the machine into the "Test Mode". This is very easy to do and will allow you to check out all functions. One of the test, allows you to check the cold water inlet valve. Assuming your water pressure is good and you have indeed cleaned the screen filter going into the machine you will most likely find that the cold water valve is not opening all the way and will need to be replaced. If your handy with a phillips screwdriver you only have two more screws to take out and the valve assembly will come right out.
Don't think you can swap out the hot water valve with the cold water valve. Fisher Paykel, clever as they are made sure you can't do that. One is a proportional valve and the other is a digital valve. They both look identical but they are not!
If your going to do the repair yourself (you've come this far, why not see it through to conclusion), be sure when you call Fisher/Paykel to order the cold water inlet valve that you give them the serial number of your machine to be sure you get the correct part.
Good Luck!
Posted on Jan 27, 2009
  • 69 Answers
SOURCE: How to I get to the pump on my Fisher & Paykel
If machine has water in it, bucket out as much as you can.
To access pump:
-Pull machine forward and lean it backwards so you can access under machine.
-On the front right hand side, you will see a fan blade- this is the drain pump. This fan blade should spin freely if you turn it by hand.
-To remove pump: remove plug connection that has 2 wires. Remove other plug connection that has 1 wire. On the top of the pump assembly, you will see a white plastic tag, about a 40mm long horizontally across the pump- gently pull tag towards you, and turn complete pump unit anti clockwise- whole pump will drop out (don't force it, it should come out easily) *Note* if there is water in machine still, it will come out when you remove pump assembly- be ready with some towels!!
-Check pump impellor(blade on other end of pump) is free from obstruction, and turns easily. Check with your finger to see if there is any obstruction in the hole where the pump has come out of (inside bowl).
-You can test pump with an ohm meter (should be approx 37ohms from memory)
Reassemble and test for leaks etc
Posted on Aug 11, 2009
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Fisher & Paykel smartdrive 053 fills really slow
Your cold valve could be faulty & need replacing.
Try swapping hot & cold valves to see if it fills faster.
Jul 12, 2012 | Fisher and Paykel Washing Machines
Machine gets stuck between rinse ans spin and sits for a while then spins but wont stop, then **** from the in the machine or hose is on the clothes???? Any suggestions? Machine is a top loader smart drive...
You could try a hot load with epsom salts....this will clean out the machine....Make sure it is with hot water. It goes slow in between rinse and spin possibly because it is slow draining...clean out the pump. Also as it FILLS make sure the water runs in properly and not just trickle in making a hissing noise. Good luck. Tony the technician.
Apr 02, 2011 | Fisher and Paykel Washing Machines
Washing machine slow to fill
yes or a water pressure issue, mosty when using hot or warm
May 19, 2010 | Fisher and Paykel Active Smart E522B...
Water filling issue
It sounds like you have a faulty Out of Balance Micro switch(the machine now thinks it's always out of balance) you'll find this under the motor controller module (main computer module) in the top of the machine on the righthand side. Anymore questions feel free to ask. cheers
May 15, 2009 | Washing Machines
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher&Paykel Smart Drive 601 Both Hot and Cold Water Fill very slowly
Hey there. I've had the same problem recently. It would fill slowly, and then after a while, it wouldn't fill at all. So I got some a new valve. it cost about $NZ30 delivered. You'll need one each for hot and cold. You can get parts from http://www.primedistributors.co.nz/. I think the part you need is 426142. you can check an image of it on the website. Good luck.
Aug 17, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fills slowly and does not max spin
we found that there was a controlling switch "thingamebit" that sets the water coming into the machine, and a part was just replaced. The part cost $40 but the service cost $90.
Mar 17, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
141 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
