Question about EliteGroup P4M800-M7 Motherboard
Is P4M800-M7 mobo can support the pc333 sdram memory? Thank you.
  • dhexter Oct 14, 2008
    how about if i have 2 memory on the slot having different specs, the one is pc333 and the other is pc400? would it cause a problem?
    Scholar:
  • 76 Answers
Yes, according to the specs that I read the P4M800-M7 (socket 775?) is designed to support pc333.
Only one time I had a problem with an ECS motherboard, I had the correct memory, but the board had a different voltage requirement. Did not cause any issues, other than it didn't work. I don't think that this would be a problem for you though.
Posted on Oct 14, 2008
  • J. May Oct 14, 2008
    Actually, I got a little mixed up.
    It should run DDR 333, which is PC2700. If you run DDR 400 (PC3200) than because the motherboard is only rated for PC2700, it will run the PC3200 at the PC2700 or the speed to match your slowest stick. Both are DDR1 type memory so they will both fit in the memory slots, and you should be able to run them together, BUT...
    At the most, your computer will run slow and possibly get errors. If this happens just remove one of the sticks. Mostly the problem will arise where you run memory from different manufacturers and with different CAS Latencies, or you run two different memory sticks (size or speed) in a motherboard with dual channel requirements. This should not cause a permanent issue if you try it.
Hi..i have a P4m800-M7 rev 3.1 motherboard which recently had only 1 512MB DDR 400mhz RAM.. itried to install an additional 256MB DDR 400mzh ram but the system recognizes only the 512MB RAM. I've tried...
Check that your memory is supported, according to Biostar documentation for your motherboard:
Single Channel Mode DDR2 Memory
Registered DIMM and ECC DIMM is not supported
Re-check the memory module's specifications.
Nov 03, 2009 | EliteGroup P4M800-M7 Motherboard
Wonder if p4m800-m7 will support the new pentium dual core
For the full list of processors supported on your motherboard, click this link:
http://www.ecs.com.tw/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=548&MenuID=69&LanID=0
Hope this answers your query. For more help and clarifications, please reply to this post. Thanks
Aug 31, 2009 | EliteGroup P4M800-M7 Motherboard
Elite group P4M800-M7 Can i use 2GB 667 / 800 ddr2????
I have p4m800-m7 also and i cant seem to get both sticks to work.....I still have only 1 gig with both sticks i have 2 DDR-2 1Gig sticks PC2-5300 533 mhz
Mar 12, 2009 | EliteGroup P4M800-M7 Motherboard
RAM DDR2 PC 1300
DDR 2 will _not_ work the way it's supposed to in a DDR slot, if at all. If you want to see what memory your computer can use, go to crucial.com or similar website for a free scan of your computer. From the spec. sheet it looks like your machine takes a maximum of 2 sticks of 1 gig each (for a total of 2 gigs) DDR SDRAM, either 333 or 400MHz of memory
Feb 07, 2009 | EliteGroup P4M800-M7 Motherboard
P4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
P4M800-M7
please give me a software copy of motherboard P4 M 800 -M7 A ver 7.1
Jul 13, 2008 | EliteGroup P4M800-M7 Motherboard
Compatibility of p4m800-M socket and ddr pc266
The motherboard supports DDR400/333 DDR SDRAM only according to their website. So most likely not..
Jun 26, 2008 | EliteGroup ECS P4M800-M Socket...
RAM P4M800-M7 problem
try to clean the ram slot then try again . Also read the motherboard manual if it supports your new ram or not .
Please rate me .
May 03, 2008 | EliteGroup P4M800-M7 Motherboard
P4M800-M7 presumed memory problem
I have never had a problem with Mobo's supporting 2 GB of memory.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&DetailName=Specification&MenuID=44&LanID=0
As per the website your mobo supports 2 GB memory.
Dec 25, 2007 | EliteGroup P4M800-M7 Motherboard
Problem with my mobo
are you sure the wires are on the right pins.
No it wont hurt the bios, but power may of fried something,
But thats rare.
here is the pins. #1 is lower left.
1 HD_LED_P
2 FP PWR/SLP *MSG LED(+)
3 HD_LED_N Hard disk LED(-)
4 FP PWR/SLP *MSG LED(-)
5 RST_SW_N Reset Switch(-)
6 PWR_SW_P Power Switch(+)
7 RST_SW_P Reset Switch(+)
8 PWR_SW_N Power Switch(-)
9 RSVD Reserved
10 Key No pin
Here is the manual
Nov 07, 2007 | EliteGroup P4M800-M7 Motherboard
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
189 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
