Question about Kenwood KD-291RC Turntable
PS-T3 connection to Sherwood 4105 Receiver
Connecting my new Sherwood 4105 Receiver to iPod, CD, DVD players is okay. But my PS-T3 Sony turntable does not work and just hear a hisss sound. What do I do? Help!
You need a phono stage (phono amp) between the turntable and receiver to boost the lower signal from the turntable. If your receiver has phono inputs, use those as there will be a built-in phono stage.
Posted on Nov 20, 2008
Does the sherwood rx 4105 receiver have analog or digital inputs
Unfortunately the RX-4105 is a stereo only receiver with only analog L/R inputs. You will have to find a stereo output & go in through one of the stereo inputs.
Feb 12, 2013 | Sherwood RX-4105 Receiver
What is a compatible turntable for my Sherwood rx-4109 receiver?
many decks have pre amps or need preamps. hence the reason why you have distorted sound i would guess. you need the opposite of what you used. What record deck did you try?
Jan 06, 2013 | Sherwood New-RX-4109 STEREO RECEIVER WITH...
When connecting my speakers one side of the receiver is not working any suggestions?
You have a bad output transister in receiver this is common for the 2 channel Sherwoods. Not worth fixing if your not inclined in the electronic field. It will cost more than the receiver to fix. Sorry for the bad news Good luck.
May 24, 2010 | Sherwood RX-4105 Receiver
Is there a way of connecting my ipod to my sherwood cd player?
The answer isn't with the CD player, it's with the amp.
Does the amp have selectable inputs, or does it just have one input for each channel?
If it's a simple power amp, then you'll have to unplug the CD player and connect your iPod to the amp inputs. I'm guessing that the CD player connects to the amp with RCA (phono) connectors like these ones.
If that's the case, you can get a cable (like this one at Radio Shack, but any office supply store will have one too) to connect your iPod to the amp.
Jul 31, 2009 | Sherwood CDC-5090R 5-Disc CD Changer
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
I want to hook up my bose speaker systerm to my new vizio tv
Real easy, get a RCA audio cable (red and white ends) that is long enough to go from the tv inputs to your receiver inputs. Plug one end into the audio out on the back of your tv, then plug other end into input on your receiver (tv, cd or vcr). Now everything going to tv will output to receiver also. You may have to go into the TV menu and under audio, set audio output to fixed. Then you can change the volume on your receiver which is best way to go.
**Advanced** If your TV and receiver has optical capability you can use an optical cable instead.
Good luck,
Mar 23, 2009 | Vizio VW42LF 42 in. LCD HDTV
My turntable works on old reciever and not new one
A traditional turntable only works on Phono (which contains special preamplification and equalization circuitry designed to raise the the level and flatten out the response of a phono cartridge).
After you do that, iIf you're not having hum problems I wouldn't worry about the ground. Or try it again on the FM Ground.
Feb 20, 2009 | Sherwood RX-4105 Receiver
Sherwood RX 4105 no input for a turn table
Check for a line level switch on the turn table, it may be under the turn table itself lift the rubber mat and spin the table by hand, it may not have one or it could be on the back.
You can buy a phono amp that will boost the phono signal. Check at Radio Shack or google it.
Jan 31, 2009 | Sherwood RX-4105 Receiver
Sony PS-T3 turntable one-speaker audio
Hey Limber, I am also experiencing that problem with my Sony PS-T3, did you find a solution?
Sep 15, 2008 | Sony CMT-CP505MD CD Shelf System
Kenwood KD-291RC Turntable Logo
291 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
