Question about Saws
My saw wont run only buzz
I am mechanical--- i took the motor apart cleaned it --- it got hot today and triped a breaker at a cusomers house ran ok for a few minutes longer then it stopped the motor hums blade dosent move i think the circut board that would probably have to do with the soft start is bad i checked power going into the board looks like 120 on my not so accurat volt checker after the circut board it lights but not full brightness????/
    Novelist:
  • 99 Answers
Sounds like teh capacitor has blown. These machines use normally use induction motors so they need the capacitor to take a charge and give the motor a kick in the right direction. You could CAREFULLY turn the machine on and spin the blade by hand. If it runs now then you will need a new capacitor.
Posted on Nov 01, 2008
My 10" radial arm saw motor won't run. I took it apart and found a mouse had eaten through wires running through the arm. Spliced but still would not run.
look on Google for a break down diagram make model .if mouse ate one place he might have done more in the arm it's self too
May 23, 2015 | Saws
What? Kenmore central vac S107 34089?
Sounds like it's overheating and tripping the thermal breaker. The motor housing should have some ventilation (cooling) ports or slots. Inspect them carefully and remove any clogs and debris you find.
May 25, 2014 | Vacuums
How do i test the control board on minn kota maxxum 80lb?
My guess is you either have a brushwire against the housing or the leads are on the wrong terminal. the red/black goes on the same as the lower brushwire and the black goes on the same as the upper brushwire. The motor should have a 60A breaker, assuming you have 6ga wire. If wire is smaller than 6ga, the breaker should be downsized. To test the control board, check the voltage in and voltage out. Voltage out should vary as you turn the dial.
Oct 12, 2012 | Minn Kota Boating
Ge dryer way too hot. I have cleaned all the lint out but still way too hot. unplugged vent hose and ran machine still too hot. Took apart machine and tested continuity of heating element and its fine....
I do not know your definition of "way too hot". Remove the exhaust vent and insert a accurate thermometer in the dryer exhaust. Run the dryer on high heat. The temperature should get up to 165 degrees then cool down to about 125 degrees then back up to 165.
If it goes above 165 and stays there replace the high limit thermostat.
If it cycles correctly it is OK.
Aug 31, 2011 | GE DWSR405EBWW Electric Dryer
I just got a bandsaw. When I plug it in in my garage the GFI circuit trips. When I bought it it ran fine, the guy I bought it from ran it for a minute or two to show me. I cleaned it up some, took it...
GFI usually trips from unequal current levels between the hot and neutral lines unless the saw starting-current-draw is more than the ampere rating of the GFI breaker. You may have to wire a special circuit for this saw if it is a heavy duty unit. If the previous owner was sawing metal, that can leave particles within the motor that may cause electrical leakage to ground which will trip the GFI. Hope this helps!
Aug 15, 2010 | Garden
Blower motor stopped, there is a medium-loud ''electric buzz'' sound every minute or so as if trying to start the blower motor. Could be relay switch. Last week, I extracted the entire motor and fan...
you have a bad "starting capacitor" .. the capacitor is used to get the motor to start in the correct direction .. when its bad the motor doesnt know which way to turn so it just sits there buzzing until it gets hot .. that trips a thermal breaker in the motor and shuts it off ... when it cools it tries again .. dont let it do that for a long time since you could damage the moter eventually ... the starting cap is a round cyclinder probably mounted close to or on the motor (wires come from it to the motor) .. they are not expensive .. you can take the old one with you to a motor parts place so they can match it up with a new one ..
while the motor is buzzing .. if you spin the blower it will start in whatever direction you spin it ... it will run until its shut off but then wont start on its own again ... changing the starting cap will fix that ..
Aug 18, 2009 | Bryant Heating & Cooling
WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Sep 09, 2008 | Whirlpool LER4634J Electric Dryer
Motor on fan feels hot
If I were you I would turn off the fans when you are not at home. These are run by electric motors and by thier design as houshold and not industrial they do need time to cool. These are not designed to be ran 24/7.
Hope this helps Ya
Jul 05, 2008 | Dryers
Saws Logo
296 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
