Question about Sharp R-1460 Microwave Oven
Sharp microwave carosel not turning, light on, fan on and unable to turn it off without pulling plug out. How do I fix this?
  • Sharp Master
  • 9,086 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
If you only need a switch, you can order part # QSW-MA085WRE0 from Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Oct 19, 2008
My Sharp Carosel volume got really quiet. Is there an easy fix?
If you are referring to the beep when you press any function,the beeper on the board may have failed.
The two other sounds are :i. there is a fan that comes on when start is pressed and, ii. the other sound is a heavy hum also when start is pressed.This comes from the transformer and maybe the magnetron tube. If you are not getting these sounds then troubleshoot these areas,careful though, the output voltage from the transformer is about 1.5kv
Mar 02, 2014 | Sharp R-1480 Microwave Oven
Sharp model R-320F carousel doesnt turn but it lights up and doesent make any noise
Your probably have a defective bottom door switch, or that switch's mount is bad.
This is a very common probpem in Sharp-made microwaves.
See a help file on door switches here.
The full service manual is here.
You can order Sharp parts from Encompass here.
Dec 11, 2012 | Sharp Microwave Ovens
Why does the fan on my Sharp Carosel II microwave continue to run? Model R-8560
From the description one of the door switches is defective, if you have a digital meter then I will walk you through the testing phase.
Jul 06, 2012 | Sharp Microwave Ovens
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
Carousel not turning; light on, fan on and unable to turn it off without pulling plug out. How do I fix this problem?
Check the door interlock switches. One faulty switch will cause this problem as will excessive condensation problems.
Hope that helps.
Jan 11, 2011 | Sharp Microwave Ovens
Microwave dead
one of 3 things, for sure the internal fuse is gone, then check for a: bad Hi-Voltage;diode, Hi-Voltage capacitor, or the magnetron tube is defective,none are too hard to change out,but the magnetron is fairly expensive to replace:
Sep 22, 2009 | Microwave Ovens
Lights fan and carosel do not work
tricky one. common denominator to all parts not working could be open neutral track at back of the circuit board, or possibly a relay not switching correctly.Need testing equiptment for that.
Sep 13, 2009 | Microwave Ovens
Carosel on sharp R-1505 not turning
Look for damage to rollers on intermediate carrier under the oem plate.
Jul 26, 2009 | Sharp R-1510 Microwave Oven
Sharp 1470 over-the-range microwave - no power on panel
Did you unplug any wires when you took it apart?
Otherwise, I would think one or more of the connectors got unplugged when you removed the control panel.
Another thing that can happen on these models is a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under thebottom edge of the switch. It's usually the top door switch.
You can find the wiring diagram at our site here.
After you look into this, if you still need help, please write back with more details.
Oct 12, 2008 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
188 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
