Question about Linksys Wireless-G WRT54G Router
Wireless connection My cable modem dropped off line along w my wireless connection. I got my hardwire connection back up through comcast. I now tried to get my wireless router up but the network does not show. A "generic" linksys network does show up on available networks. What should I do? Thanks
    Problem Solver:
  • 35 Answers
Possible you did reset the router. Its okay to connect to that linksys network name. But if you want to customize you network name.
MAKE SURE TO USE THE WIRED COMPUTER TO SETUP WIRELESS CONNECTION.
Example : The Desktop computer that is connected to directly to router.
Just follow the steps.
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3967&p_created=1159257209&p_sid=aNKUFggj&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODExJnBfcHJvZHM9MCZwX2NhdHM9MTcyMSwxNzIzJnBfcHY9JnBfY3Y9Mi4xNzIzJnBfc2NmX2xhbmc9MSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PUNoYW5nZSBTU0lE&p_li=&p_topview=1
Hope it will work..
Posted on Oct 14, 2008
Comcast cable says they don't update firmware. l have a SB6141 motorola DOCSIS 3.00 and l just upgraded to 105 mbps. l'm hardwired to my modem. l'm only getting 32 power level ?
You may need to enable IPV6. All Comcast modem updates are done automatically. I would contact ARRIS for additional assistance. Comcast also has a helpful online community.
Mark
Motorola Mobility Support
Jun 18, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
I have a linksys cm100 modem with comcast isp, when connected hardwire from computer to modem I can connect to internet, but when i connected my Fry fr-300rtr with dir-615 E1 firmware it will not transfer...
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
Jan 31, 2011 | Linksys CM100 Cable Modem
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Internet connection problems
Sorry but that seems to be a pretty convoluted explanation. Here is how it should go.
Vonage unit connected to phone line(s) and cable modem. Linksys connected to Vonage box. Computers connected to Linksys.
Ethernet has a length limitation of about 300 feet before you need another switch (hub) or a repeater. Does your wire length exceed this?
Apr 20, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Help with wireless router
Try using admin as the password and leaving the username blank instead.
Feb 24, 2009 | Linksys Wireless-G Broadband Router
Arimex comcast router won't talk to belkin wireless g plus mimo router
Comcast has a little known "trick" that they use when setting up users. Here's how it works:
When Comcast first comes to setup your new cable modem service, they insist on connecting it to your computer and "testing" it. Most people think nothing of it, and that it's good customer service ...truth be told, what they are doing is attaching your computer's MAC address to that cable modem, so that you cannot create a wireless network. This is because they want you to pay them $150 to do this for you.
In this situation, since the modem is a modem/wireless router in one, my guess is that the MAC address on your machine now does not match the MAC address on the new router, which is what Comcast has stored in their database(s).
Try this: on your computer (while connected to the modem), perform a release on your IP address (start, run, cmd, then type "ipconfig /release"). Disconnect the ethernet cable from the computer. Turn computer off completely. Hold down the reset button on the cable modem until it performs a reset. Once it's back up and running, boot up your computer with the cable back in the ethernet port.
The cable modem should assign a new address to your computer. However, that may or may not work ...this is an easy workaround with a Linksys router, but not necessarily with the all-in-one devices.
Worst case scenario: contact Comcast and notify them that the new modem is not recognizing your computer's MAC address and that it needs to be updated in their system. They will scan your computer (through the telnet interface on your modem) and get your computer's MAC address, then (hopefully) make the necessary changes on their end.
After that, everything should work flawlessly. If not, insist on a Comcast tech to "fix" the service that you are paying for.
Good luck - hope this helps :)
Sep 29, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Became new customer to comcast-got the bundle package, internet,phone,cable. Voice overlay modem to accomodate internet and phone lines. Did not use their wireless router-using exsiting router D-Link model...
Hi jad123,
I am sorry to learn about the problems you are experiencing with your service.
I will be happy to reach out to my contacts to assist you in resolving this issue. Please feel free to contact me so that I can get more information from you.
Thanks in advance!
Mark C.
Comcast Executive Offices
We_Can_Help@cable.comcast.com
Apr 10, 2008 | Computers & Internet
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
Nov 09, 2007 | Belkin (F5D8231-4) Wireless Router...
Linksys Wireless-G WRT54G Router Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
