Question about Lexmark X7350 All-In-One InkJet Printer
Printer not printing
My printer indicated ink low so i got them refilled, and now my printer still says ink low and wont print anything at all
  • lisa25grant Oct 15, 2008
    I did all of the above but didn't check if there was a safety removal process, thanks I will check it out
    Problem Solver:
  • 52 Answers
Did you do a test page and re aline the cartridges? when you removed the cartridge did you go through your computer to the "safely remove" program for the ink cartridges?? of just take the things out.?
there is a proper procedure for removing and replacing ink cartridges. if the machine doesn't know the replacement was made it will still think you are low.
if you have the manual for operation look for the "how to replace ink" and follow the directions.
there is also a plastic film that covers the new cartridge head and it needs to be removed. did you do this?? Or a pull tab at the end of the thing.
Posted on Oct 14, 2008
Ink is low epson me10
if your ink is low, you need to buy more ink. OR you can buy ink refill kits ( super cheap ) just be careful filling the ink cartridges so you don't over fill.
If you have only printed a few things ( photo's aside) and are low on ink, then try NOT printing the best quality. adjust the ink quality settings in the properties when your about to print.
Note: if your just printing text and it's not for anything super important ALWAYS go with draft. it prints faster and uses a lot less ink.
Jan 01, 2014 | Office Equipment & Supplies
Empty cartridge light keeps flashing
These cartridges don't have anything internally to check for new ink. They simply work on a basis of counting pages and page coverage to estimate ink levels. As such it is perfectly normal for your printer to warn of low ink once the cartridge has been refilled.
A low ink warning in itself should not stop your printer from printing though. If it does it is likely that the light is actually indicating a problem recognising the cartridge after refilling. I would recommend cleaning the copper contacts on the front of the cartridge and checking for any messages on the connected PC or laptop for more information.
Oct 16, 2012 | HP DeskJet F380 All-In-One Printer
Low ink indicator
Turn the printer on.
Lift the lid that covers the print-head mechanism.
Wait for the print-head to slide to the position at which the ink-cartridge(s) can be removed.
Press down on the ink-cartridge, to "unlock" it from the print-head.
Gently remove it.
Insert a new/refilled ink-cartridge, and "lock" it into place.
Print a "test" page.
May 08, 2011 | HP Deskjet D4360 InkJet Printer
After refill canon 860 says ink is too low and does not print anything. how do i reset the printer to accept refill ink? error message is "U410" with an "x" on the BK catridge icon on the printer.
When it says "error U410 -ink has run out even though ou have refilled the cartridge follow this procedure:-
1.Press Ok to get past the above error message. The machine will take a few momets to do its own calibration, etc.
2.When it comes on line, Hold in the rest button for 5 seconds.
3.When you request a print job, it will still show that the ink is low, just disregard and it will go on to print as usual.
Dec 09, 2009 | Canon PIXMA MX700 All-In-One InkJet...
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Refilled my black ink but my color ink is empty so it wont print
Apparently I just had the same problem and I managed to fix it! Click on the OK button on the printer to ignore the low ink level error, then you'll be able to print and scan.
Jun 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Printer Always Indicates Ink is Low or Cartridge is Incorrect
To get rid of the low ink warnings google the specific error message with 'ink refill' and look for 'engineers reset' or similar ..
NB. Dell printers (re-badged Lexmarks) are notorious for ink usage and high costs .. so my best recommendation would be to throw it away and purchase something else ..
Nov 30, 2008 | Dell 922 All-In-One InkJet Printer
Printing Photos
I refilled color ink for Dell Photo 924 but some reason it showing it me low ink.
Dec 09, 2007 | Dell 924 All-in-One InkJet Printer
Lexmark X7350 All-In-One InkJet Printer Logo
80 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
