Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp 6110 all in one
It will not pull paper through the feeder . I pulls it to the leftand gets crumbled up
    Novelist:
    Scholar:
  • 111 Answers
This problem doesn't seem to be exclusively a 6110 problem. HP.com has a web page that addresses this and related issues:
Paper Catches Causing Paper Jam
Post back your results. Good luck.
Posted on Oct 14, 2008
Paper jam. How do I get the paper out. my instructions don't tell what to do. This is HP Officejet J4680cAll in One
http://h10032.www1.hp.com/ctg/Manual/c01770356.pdf
Follow the instructions on how to "To clean the plastic strip inside the automatic document feeder" This is the closest you will be able to get to getting inside the paper feeder to check for the paper jam.
Feb 28, 2011 | HP Office Equipment & Supplies
Service manual for the HP 6110 all in one printer.
A metric allen wrench set (small sizes) is needed to remove the drive mechanism from the document feeder, then the parts can be disassembled. Unfortunately, the drive rollers, made of rubber were damaged by a small metal piece - (staple?) that was fed into the machine. Removal of the metal piece almost restored the drive. It needs to be lightly snded to remove the marks made by the staple. Thanks anyway.
Jan 15, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My HP 66110 will not start up. There is a grateing sound when on button is pressed, there is no paper jamed in system.
Try unplugging the printer and opening the door where the printing heads are, and make the sure belt that moves the print carriage back and forth is not broken or damaged. Pull the belt so that the print carriage is moved to a different position than where it usually parks, and that may unjam or reset the mechanism. The grinding sound might be coming from the scanning mechanism, or the scanning sheet feeder. Try manually turning the wheels for the feeder and make sure they turn.
Sep 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Faxing from scanner rather than feeder.. help.
ideadly the scanner needs to scan to get the image to send out in fax form. The feelder paper feeder that is for recieving fax
Jul 31, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Paper jammed in the feeder, what do i do?
Hello, You can try to pull it out of the feeder. If it's too hard, open every doors and see where you can pull it out from Hope this helps
Jun 10, 2009 | HP LaserJet 3055 All-In-One Printer
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 scanner wizard
What is the OS on both the computers ?
Jan 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 All-In-One Printer
there is Paper separation pad in Paper feeder that may me worn out or not fitted properly so just remove the same & fit the properly it may solved the problem. and also cleaned the sensor. thanks aniket
Sep 23, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
50 people viewed this question
Ben Johnson
