Hi. i have an enviro gas model 828 free standing fireplace. i tried to get the pilot lit and it wont light even after bleeding air out. i held the knob down for a while and still no gas. the unit is about 10 yrs old and would intermittantly shut down last year when it was running. any ideas of what it may be? thanks..John
5 Suggested Answers
  • 49 Answers
SOURCE: pilot light will not stay lit
The flame must satisfy the thermocouple. Then the thermocouple must satisfy the valve. If you have a great flame on the thermocouple, it is possible that you have a bad gas valve, if no other saftey switches has you shut down to not allow the valve to open.
Posted on Nov 20, 2007
22yooper
  • 828 Answers
SOURCE: 2001 Coleman Niagara Elite folding
You may have one of two problems; The pilot orifice is very small and allows only a limited flow and any air trapped in the gas supply takes some time to bleed out while you are holding down the pilot button. Or the pilot orifice may be plugged in which case you would have to replace it.
Posted on Jul 10, 2008
  • 6 Answers
SOURCE: Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Posted on Dec 02, 2008
  • 85 Answers
SOURCE: the pilot light to our
Check venting, exhaust, the adj vent in fireplace. If that does not work your valve failed, warranty it. If no warranty expect to pay between 90 to 150 dollars.
Posted on Dec 05, 2008
robocop
  • 90 Answers
SOURCE: Pilot Light will not remain lit
Try this, turn the black gas ****, on top of the control box, to the Pilot position. Set the temp. control on the front of the box to the desired temp. Then, hold a match or whatever else you use to light it, next to the end of the pilot, then, while holding the match to the pilot, press the reset button on top. When the pilot lights, continue to hold the reset button down for about 1 minute. Then, after a minute, turn the gas **** to the ON position, then it should remain on.
Posted on Jan 20, 2009
Why wont an older model carrier gas furnace light when standing pilot light is lit at all times? Why would there be no gas at the burners
when it comes to GAS appliances , I do not recommend any self fixes . they can explode and do you serious damage even up to death .call a gas furnace repairman
Feb 28, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Procom pilot light wont light
Make sure the gas valve is on. The thermocouple may need to be cleaned in order for the pilot to stay lit.
Nov 26, 2013 | Procom Heating & Cooling
Gas fireplace
replace pilot assembly and pilot generator
Sep 05, 2013 | Pool & Spa
I changed my thermocouple on my fireplace,it still wont stay lit
Thermocouple keeps the pilot lit.
Thermopile keeps the burner lit.
Please specify what won't stay lit...
If it's the burner, you may need to change the thermopile as well.
If the pilot still won't stay lit, you will want to make sure that the pilot flame is large enough to completely engulf the thermocouple and keep it hot. If it's too small, you may need to take some compressed air and blow out the pilot hood to remove any blockage.
Dec 18, 2012 | Napoleon 36" Zero Clearance Top/Rear Vent...
My dimplex electric fireplace model HEF22 wouldn't turn on
take out fireplace flame, 4 screws, in the middle is a thin sq. black box 1.5 inchs sq. with an insulated screw driver pull it forward. you should here beep,
if u do- unplug-get a good tape,put tape to keep it forward, what happens is it pulled backwards and the two pins slipped out of the circuit board. dust while u arre in there. hope that works for u. mine is working.keep fingers ccrossed. HAPPY HOLIDAYS
Apr 10, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
Gas fireplace wont stay lit- it is a sealed unit so can taccess the pilot or gas holes in the logs. is it safe to remove glass panel?
Yes, removing the glass is safe, if you do it carefully, so as not to break it. Put it well out of your way, after removing it. In fact, removing it is the only way to access and service the Pilot Assembly and the Burners.
If the pilot won't stay lit, there are several things that can cause this on a Direct Vent Gas Fireplace:
  • The direct vent on the outside of the house is block or clogged.
  • Wind is blowing back through the direct vent, blowing out the pilot.
  • Low gas pressure
  • A dirty pilot.
  • The thermocouple and/or Thermopile (part of the pilot assembly) has failed.
If you can provide me with the make and model number of your gas fireplace, I may be able to furnish you with an Owners Manual, that will help you to continue to troubleshoot the problem.
Hope this helped you.
Apr 29, 2011 | Heating & Cooling
Intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
Jan 02, 2010 | Heating & Cooling
I need help relighting the pilot light on my Marco mfg gas fireplace-model # 794015c
First, turn the wall switch to the off position. Second, turn the key all the way tcountercockwise to the open position. At the front of the unit, below the hearth opening there is a black front access panel. Should have a little recessed part. pull it out and expose the gas valve. Turn the plunger/knob that says off, on, pilot to the pilot position. You'll knw your in the pilot position when it lines up with the indicator (usually a red or black mark on the gas valve body). If you are in the pilot position, you will be able to push in the pilot (it will feel springy). Push the plunger in and then push the red button (piezo ignition button) in until it makes a snapping sound. You may have to do this several times because the air has to bleed out from the pilot tubing. This should light the pilot BUT wait. DO NOT LET GO OF THE PLUNGER ONCE THE PILOT IS LIT. You need to keep the plunger depressed for about 30 seconds and then let it go. After 30 seconds let the plunger go and verify the pilot is lit. If not try the last step over. After the pilot is lit, you may turn the plunger/knob to the on position. Now go back to the wall switch and flip it on. If it doesn't come on tap it hard. Sometimes dust can actually prevent it from making good connection. I work on fireplaces for a living and coincidentally worked on this model today. Simple as pie.
Dec 28, 2008 | Heating & Cooling
Dec 01, 2008 | Heating & Cooling
Heating & Cooling Logo
181 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
