Question about Philips 60P8341 60" Rear Projection Television
60VB2K3RF I have a wave on the bottom left side which is causing it to lose focus and the letters show as double and they are not straight across. What can I do other then calling a serviceman?
  • jeremiahchar Nov 16, 2008
    My philips 60p8341 also has a wave along the bottom of the screen. The convergence does nothing to help it, can't even line them up the picture is so warped
  • Anonymous Mar 13, 2009
    my phillips crt tv has a red line doubling up everything i think its a convergence problem how do i fix it
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 22, 2009
Soap bubbles and small amount of water seeping is from bottom of door. Opened for visual inspection. I removed lower rack and found that a rubber gasket/seal (white) that is attached to door does not run...
with out a model number i cant see what you see,,,but it does not matter that much i doubt if its the seal...what to look for is something causing the arms or sump to spay down...the water in the bottom of a dishwasher stands still almost except for the water that return off the dishes and down the sides,,,now it never enough to make the water in the dishwasher bottom wave up,,when something causes it to wave up you get splash over from the right or left cornors.now what to look for...blocked or defective spray arms,,check well if not blocked could be worn split at weld,,check your sump fitler over for tightness of screws if lose will cause to wave,,check for unseen blockage ..ie plastic spoon and make sure a person did not use dishwashing liquid ie joy.dawn.if so flush with cold water only ,.also old dishwasher detergent will cause this bubble over ..good luck
Sep 09, 2011 | Dishwashers
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
Blue wave across screen
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Sep 08, 2008 | Apex Digital GB5108 51" Rear Projection...
DOUBLE VISION AT TOP OF MY SCREEN. DISTORTION.
Good Day, wars;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Magic focus grid not straight.
i'm no expert by any means; but I wonder if it could be as simple as the reflective screening on the inside comming loose. I have a 65" and I took it apart to clean it. The reflective screening looked to me like it could be a weak point. Just a thought.
Jul 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Touch Focus Error
you need to replace both of the STK392-110 ICs you can get replacements at the following link and they come with free instalation instructions with pictures. Here's the link.
Jun 20, 2008 | Toshiba 53H71 53 in. Rear Projection...
DOUBLE IMAGE
Convergence system overhaul cost about $400. No mfr. warranty after 90 days to a year unless you bought an xtended warranty for up to 5 yrs. Good set,worth keeping. Senior tech only== careful soldering needed+ OEM or better quality parts a must.
Sep 29, 2007 | Toshiba 42H83 42" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
173 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
