Question about Dishwashers
Maytag Dishwasher, Quiet Series 300, Won't let us CHANGE CYCLES
We bought this dishwasher in 2007 and it's never consistently allowed us to change the cycles by pressing the choices on the push-pad panel in front. It cleans just fine, but it won't let ME decide to use a "normal" wash versus a "light wash" versus any of the others. I've tried contacting maytag and they say there's nothing they can do because it's not under warranty anymore. My husband is a plumber who installed this AND many others for other people, and he thinks there's a bad "sensor" in the pad. Is this likely? All I want to do is select the length of the wash cycle and I'll be happy! Thank you. please reply to direct email at smlong@meer.net
SOURCE: Maytag dishwasher legacy 300 quiet series
FYI... I followed Miss Midget's steps... and there it was... a piece of plastic... actually one of the end caps from the rack. Poor design if you ask me. So for all you "grinders" out there, it's an easy fix... just need the appropriate star screwdriver. It went back together easier than it did taking it apart. Thanks.
Posted on Nov 28, 2007
SOURCE: Maytag Quiet Series 300 dishwasher,
Our control panel is fine. For now. (The machine is only 3 months old). This is our problem--and I haven't yet seen this complaint at all over the internt: The lower wash arm is getting stuck on the bottom rack and stopping immediately. This seems to be a design flaw. The bottom rack is just built too low. A service man was out once. He tightened the wash arm. Didn't work. The service department at the dealership is now ignoring our subsequent calls!! So I wonder if the "not cleaning" problem you have is because of this.
Posted on Apr 05, 2009
MNfisherman
  • 11896 Answers
SOURCE: Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Posted on Jun 01, 2009
StarGGundam2
  • 24 Answers
SOURCE: Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Posted on Oct 12, 2009
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Posted on Dec 19, 2009
My dishwasher the maytag quiet series 300, will not respond to the start button
Find your circuit breaker for your dishwasher and turn it off for 3-5 minutes. Turn it back on, then turn on your dishwasher. If this works, after the complete cycle of your dishwasher, you have to turn it off manually by pressing "on" botton then press it 1 more time to cancel; this will turn off. The defect is, probably the moisture built up in the control board causing it to ground some of the connections. Suggestion for the manufacturer, insulate the control board to prevent absorbing moisture.
Jan 04, 2013 | Maytag Dishwashers
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Foul smell coming from Maytag Quiet Series 300
Hello jscott,
It is typical nowdays for most dishwashers not to drain all water out of the bottom tub (Even where you cant see) due to siphon design and energy efficiency. Try using about a liter of vinegar and throw it on the bottom tub of the dishwasher. Let it run through a full cycle and see how that works. Has worked for me
Sep 07, 2009 | Dishwashers
Maytag Quiet Series 300 owners manual
my dishwasher does not want to work anymore it has a big L flashing
Jun 14, 2009 | Dishwashers
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Maytag quiet series 300
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Maytag Dishwashers
Dishwashers Logo
175 people viewed this question
Top Dishwashers Experts
