Question about Panasonic CQ-DFX403U CD Player
Can I use an external aux input in an f-150 with a this radio CQ-DFX403U
I have a 2007 F-150 and it has an aux input that is not attached to the radio. If I take that radio out and put mine in is there a way to hook that up to my radio so that I can still hook up my mp3 player to it.
  • tas9195 Oct 15, 2008
    Thanks I will try that.
  • 905 Answers
Not unless the radio has a pre output and an aux input
Posted on Oct 13, 2008
  • jason Oct 15, 2008
    you can also get a switch box to switch between the two outputs
How do I get the MP3 player to work in a 2007 Nissan Quest?
you said CAN , i bet you meant CAN'T or CAN NOT. right?
the AUX port is just a line input, analog audio input,
it dont know MP3 .
it only amplies the analog audio found there.
you connect any device, to AUX. push play on the device.
then put car radio in to AUX input mode and play. the audio.
that is all there is to it.
the external device does all the heavy lifting, reading a file, and decoding it (mp3 decode) and then sends raw analog audio out.
the cable is sold and radioshack, or walfart or many other stores,
Target, most MP3 players, come with this cable,
they use mini phone plugs, stereo, type,. (3 contacts)
Jul 05, 2014 | 2007 Nissan Quest 3.5 Minivan
It wont play cd just keeps saying e1 eject cd radio plays fine
look for areset botton if it dosent have one by a cd cleaner if after that its the same replace the radio
Jun 11, 2010 | Panasonic CQ-DFX403U CD Player
Is there a aux output for this stero?
There are two pre-outs for amplifiers but there are no AUX inputs to play MP3 players.
Nov 25, 2009 | Panasonic CQ-DFX403U CD Player
Can i use mp3 player with panaconic cg-c1300u?
If your audio system has aux input then buy a compactible cable to connect your 3.5mm output oprt to the audio systems aux input. then change the audio source is Aux input in your audio system and play the audio using our ipod.
Aug 19, 2009 | Panasonic CQ-C1300U CD Player
No User Manual for my Panasonic DFX444
Copy and paste this address into your address bar and it will take you to site with a download of your manual:http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-DFX403U. Good luck and please don't forget to rate this answer,Thanks.
Apr 11, 2009 | Panasonic CQ-DFX403U CD Player
Aux input location
Though I'm sure there is an AUX button on the radio, there isn't actually an auxillary port on a 2007 Grand Prix stock radio.I'm sorry to say, but you would have to get an aftermarket radio.
Mar 11, 2009 | 2007 Pontiac Grand Prix GXP Sedan
Connecting iPod to Panasonic CQ-C5310U
I'm pretty sure that there are RCA jacks in the back of the unit for the aux input. Don't have my owners manual so can't really say, but if there is an aux input, there is sure to be some RCA jacks in the back. So if you take the stereo out, look for those jacks then attach a 1/8 "Y" connector. Then route that wire to the front. Then you'll have something to connect your mp3 player to. =)
Feb 23, 2009 | Panasonic CQ-C5310U CD Player
Using an ipod with CQ-DFX403U
http://www2.panasonic.com/consumer-electronics/support/CD/model.CQ-DFX403U
This is the link to your units pdf manual. It also covers a 7 series model which does have "Aux in" Your unit does not. You do have the capability to add a cd changer via the link on the back of the deck but it is Not an auxillary input. Now, it is correct that you could use a FM modulator running thru the tuner on 87.1 or 89.1. I think the confusion on this unit was a quick glance at the manual. It does have an "audio in" but it is specific to the panasonic disc changer and triggered thru the changer din cord. which is why you see no "Aux" on the display nor hear any audio. If you look at page 5 in the pdf version of the manual it states that the 403 does "Not" have aux in. The manual reads tricky on the other pages, sounding and looking like they are detailing the 403 when in fact the example is the 783. At the moment I can't think of a "good fix" for this pickle. I'll noodle it thru and if I can get you a solid way to make this do what you wish without lots of signal loss I'll post another comment. Hope this helps explain what's happened.
Jan 21, 2009 | Panasonic CQ-DFX403U CD Player
Unable to select auxillary input
its xm ready shouldnt need to use rcazzz
Jan 07, 2009 | Panasonic CQ-C3301U CD Player
Panasonic cq-DFX444LEN
The heat is normal due to the large output IC's Panasonic uses. You need to get a "Laser Lens Cleaner" one that uses fluid. You can find them at just about any retail store these days for 15-20. Run it thru a couple times and hope that's the magic bullet to fix the issue, otherwise it needs service at a cost of 100-150 on average. If the cleaner does the trick, make it a habbit of cleaning your player every 3mos or 3000 mi. It truly is the best preventative maintanance on any CD/DVD/PC etc.! Hope this helps
Apr 04, 2008 | Panasonic CQ-DFX403U CD Player
Panasonic CQ-DFX403U CD Player Logo
191 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
