Question about Belkin Computers & Internet
Dont have the CD to find my ip address - Belkin Computers & Internet
  • 749 Answers
Click on START - RUN - in the text box type CMD (this opens a DOS looking window so you can see the IP address before it flashes out of your sight) - at the command prompt type IPCONFIG
-- this will show you your IP address, it should look something like this:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Jeff>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection 6:
Connection-specific DNS Suffix . : domain.invalid
IP Address. . . . . . . . . . . . : 192.168.254.1 <-----------YOUR IP----------<<<<<<<
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.254.254
Posted on Oct 14, 2008
How to install router wr740n v4 without resource cd
Milan have you got the user manual as it clearly explains how to set up the router and configure it manually !
http://www.tp-link.com.au/resources/document/TL-WR740N_V5_User_Guide.pdf
Your modem device already on your network has to have an IP address of 192.168.0.1 and according to the user manual the router detects the conflict in ip address and allocates its IP address as 192.168.1.1. If you IP address is different say 10.0.0.1 then you will have to plug just the router in to your Laptop and alter the i/IP address to 10.0.0.2 and turn off the DHCP server if the modem or existing router has DHCP. You will need to alter any existing DHCP server to have the first 10 IP addresses skipped for available leases to the computers.
Feb 07, 2015 | TP-LINK TL-WR740N Router
How can i install belkin wireless router n450 without the cd
Access it via its ip address. Google Belkin for their standard username and password and connect via browser to the router -you will need to obtain its ip address. Think it should 192.168.0.1
Jul 13, 2014 | Belkin F5D7234-4 Router
I dont have the d-link cd
to use a wireless router you never need a driver cd... connect your computer to the LAN port of the router using an ethernet cable...check wat is the default gateway ip address... Type the default gateway address in address bar of internet explorer... you can see the user interface of your router... you can configure the settings manually...
Aug 07, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
No IP address was set
Turn off DCHP after setting the IP address
Sep 21, 2009 | Toshiba E-Studio167 Copier
I recently installed my printer onto my computer by the cd given but then it got lost and i dont know where it is, but just a week ago i got a laptop and im trying to install my printer onto my laptop...
If you are using a router or modem on the network then the IP Address of the printer can be found out through the router/modem attached device list. Also, try taking a manual print out from the printer and check if it shows information of the IP address on it.
Jun 19, 2009 | Sharp (AR-NB2N) (ARNB2N) Print Server
I need to change my NAT settings from moderate to open and dont' know how to do that.
A. Determining the IP Address and MAC Address of a Computer: Note: Please use the computer for which the Ports are to be opened: For Windows 2000/XP users: 1. Please click on Start and select Run. 2. Type in cmd and click on OK. 3. In the Command Prompt, please type ipconfig/all then press Enter or Return key. 4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). 5. Please note down the IP address and Physical address. B. Reserving an IP Address: 1. Please open any web browser like Internet Explorer or Netscape Navigator. 2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. 3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password". Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it. 4. When the setup page opens, click on LAN IP Setup under Advanced tab. 5. Click on Add under Address Reservation. 6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table. 7. If the computer you want is not on the list, please click on the Refresh button to update the table. 8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add. 9. Click the Add button when done. C. Enabling DMZ: 1. On the left side of the setup page, click on the WAN Setup under Advanced tab. 2. Check the Default DMZ Server and specify the IP address of your computer. 3. Click on the Apply button.
Jun 04, 2009 | NetGear WGR614 Wireless Router
Lost the install CD
hi,
it should be an ip conflict.I believe you are using both routers at same time which can give same ip address (as both routers ip range is same).hence by disconnecting one router(from network/power) will make your ip conflict resolved.
secondly there is no need of linksys installation cd as it will do more harm than good.routers dont need any software to run where as network adapters need drivers.if you have any further doubts ,you can directly post it.
thank you
Dec 11, 2008 | Linksys Wireless-G Broadband Router
Ip address
do u have the internet if so connect the ithernet cable to the modem and try again
Oct 21, 2008 | Microsoft Xbox 360 Console
Problem with CD Disk installing Linksys BEFSR41 wired router. Static IP addresses or Automatic!? Where is Automatic?
definitely do automatic, especially when you dont really know what youre doing. It will automatically fill in the ip address for you that way!
Aug 08, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
