Question about HP Photosmart D5160 InkJet Printer
Did you get printer issue resloved?
Hi, Have had the same problem with my HP Photosmart and wondering if you were able to get the "cover open" red light flashing problem resolved since you posted 2 months before me.
Thanks,
Ronald11
It works darnest thing one little hard close on the cover.
Posted on Oct 29, 2008
I had to unplug the printer for a couple of minutes to let it reset and then dropped the cover 3 times and it started to work again.
Posted on Oct 25, 2008
Hello, well, several users have been kind enough to offer advice regarding this problem. The only thing that really seems to work at all is slamming the cover with a bit of force. Of course, please don't use to much force here. It seems that closing the cover is supposed to trigger a mechanism that will let the printer know. Apparently this mechanism is defective on the HP photosmart. So you just need to make your point with a bit of force when closing that cover. It may take a couple of tries, but it seems to work.
Hope that helps!
Posted on Oct 17, 2008
How do i adjust the color on my photos when printing from my hp photosmart 7525?
Hi Miriam,
Press the Setup button on printer screen,Scroll till you find Tools. Press OK - Look for Clean Printhead/cartridges and Press OK
This should fix the issue
Regards,
Sean
Apr 09, 2013 | HP Photosmart 2575 All-In-One InkJet...
Colour not printing properly have replaced all cartridges how do you clean the heads
Well take out all the cartidges and cleaning procedure is mentioned below: http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=52784&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=1153494&key=null&site=null
Then before you insert the cartidges turn off the printer and unplug the power cable from the back of the printer press and hold the power button of the printer for atleast thirty seconds release the power button.Then wait for atleast ten secs, plug the power cable back in the printer wait for ten secs let the printerwarm up and open the cover to insert the cartidges. Try and print I hope this will reslove your problem.
Apr 11, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart D5160 gives error message -0 03 31 IF F$ 4d dd d6
Issue
The product displays an 0x ... error code when printing (for example Error: 0xf0af8004). These error codes indicate that the product has an internal condition.
Solution
Use the instructions below to resolve the issue by restarting the product.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover.
If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
Mar 05, 2011 | HP Photosmart D5160 InkJet Printer
I am getting 'carriage Jam' message and being told to clear it. but i dont know how
Hi
1. Open the cartridge access door and try to move carriage manually back and forth.
If issue not resloved
2. Unplug the power cord from the back of the printer and while the printer is tuned On, Now press and hold OK and CANCEL, while holding them plug in the power cord once the printer is On release the buttons
This will RESET your printer to factory settings and it should fix your problem
Note : As I told you that it will Reset your printer to Factory Settings so if you have IP address saved in it then it will deleted.
Jan 08, 2011 | HP Photosmart 2610 All-In-One InkJet...
Error:0xb80e15be HP Photosmart 3310xi All-in-One
Please open the link below and follow the instructions to resolve the issue if the problem persist then you may have to repair the product.
http://h10025.www1.hp.com/ewfrf/wc/......
Jan 31, 2010 | HP Photosmart 3310 Printer
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
HP Photosmart D5160
Hi Arnie,
Infact the machine cover is not a customer replacable part, hence u ll not be able to open it . however if u try to open it make sure u ll not break the bezel.
thanx .. nd best of luck
Jun 15, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Photosmart D5160 InkJet Printer Logo
279 people viewed this question
Ben Johnson
