Sony KDF-46E2000 LCD Projection TV
I have a Sony KDF-46E2000 LCD Projection TV and it will turn off after about 10 minutes and flash red light 3 times. I am able to turn TV back on after a minute and so and then in 10 minutes it will do it again. Any ideas what the problem may be? I have a similar problem with the Sony Grand WEGA KDF-46E2000, wherethe TV will power on and operate normally for 5 minutes, then go black.The green power led will flash quickly, then the picture will reappearfor a few minute and repeat the process.
The red LED never goes on, so I don;t think it's the buld..I opened andcleaned out the bulb area, but I am unsure as to the problem.
thx
5 Suggested Answers
  • 586 Answers
SOURCE: I have a grand wega kdf-55wf655 projection tv.
The detail of your fault is given below according to the SELF DIAGNOSTIC SYSTEM.
The description is given below:
6 : Low B error When no "DD 6V " is detected, pin 129 of TV-micro is low and it turns off the main power.
Suggestion:
This problem is little bit technically difficult, therefore i advise you to please contact any expert who can handle this or contact SONY SERVICE CENTER.
Hope you will understand my saying.
Thanks for using fixya.
Posted on Jul 02, 2009
SOURCE: Sony KDF-46E2000 LCD Projection TV
4 flashes is a bad fan, 3 flashes is lamp door switch
Posted on Jun 29, 2008
welcomejee
  • 10594 Answers
SOURCE: No picture or sound
3 times error shows that lamp is not installed properly or lamp cover is off / not fixed.
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Posted on Jan 15, 2009
AJIN G
  • 6694 Answers
SOURCE: Sharp lcd tv. Grn lite flashing, reset by unplug, vol + ch - , plug in. Tv came back on, after few mins screen goes blk, have sound. turn off and on picture back for few minutes, goes blk, snd ok.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Posted on Jan 07, 2017
Hi i have a sony lcd projection kdf-e50a12u and as i turn it on the green light flashes for a few minutes untill it turns to red along with the light next to it and stays red?
Sir check the lamp of your projection if already damage, if damage replace the lamp and reset also the lamp hour meter. Remove the screws to open the panel labeled "lamp" on the back of the Sony TV. Remove the screws that hold the lamp in place inside the TV. Pull the lamp out. Let me know what is your observation to the lamp so I can guide you. Good day and best regards.
Sep 15, 2011 | Sony KDF-E50A12U 50" LCD HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from rivervalleyelectronics.net. They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
Tv will shut off and red light will flash 3 times
If its Sony KDF-42WE655 TV that goes to standby and LED blinks 3 times then check Lamp Door that seems not fixed properly.
That happens when lamp replaced in TV.
If its different model number TV, let me know exact model number.
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I replaced the bulb in my sony kdf-46e2000 tv but it still shuts off after about 2 min. the red light flashed 3 times which means the lamp door is not secure, I have tried the procedures to fix it but it...
have you tried to temporarialy by pass the lamp door switch, or checked the switch to see if its working when the switch is in the closed position?
Jun 13, 2009 | Televison & Video
Tv is shutting down then restarting.
How old is this TV, if its more then 2 years old and have not replaced lamp yet then its problem of weak lamp. Please replace its lamp and always purchase Sony original lamp for smooth TV function.
Mar 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Sony projection TV screen going black.
need to replace the bulb
SONY-XL-2400 replacement bulb
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
No picture or sound
Jan 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Jun 29, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
