How do I disassemble the top part of the agitator on Whirlpool II Ultimate Care washer.
The bottom part of the agitator works fine, but the top part does not work properly. How can I get the top part of this off? Is there a place I can get a repair manual for this product? I cannot get the agitator apart to get to the broken feed dogs. Can you help me?
    Scholar:
  • 112 Answers
The top cover just pulls off, then as you look down the center of the agitator, there is a round plastic cap that just pulls out. You may have to tug hard for either or both of these. Then there is just the center bolt that you take out and the entire top of the agitator will come off. Usually, the "dogs" in the agitator wear out and need to be replaced. Cheap and easy fix. Note: you may want to get a new o-ring for your cap when you take this apart.
Posted on Oct 18, 2008
oldTech2332
  • 2341 Answers
SOURCE: How do you disassemble the agitator for a
i am assuming that you want to do that to replace the agitator dogs? this vidoe will show ya how to remove the agitator and replace the dogs.......http://www.youtube.com/embed/0GQh8JLqVv8" frameborder="0" allowfullscreen>
Posted on Jul 18, 2011
  • 161 Answers
SOURCE: whirlpool ultimate care II, Top agitator not
stand on agitator,pull top section upwards,the agitators are meant to be disassembled this way,sometimes they are stubborn,and you cannot service agitator if agit is still in the machine...
Posted on Mar 10, 2010
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
washdryman
  • 154 Answers
SOURCE: Upper agitator on Whirlpool Ultimate Care II washer
replace agitator "dogs"
Posted on Mar 01, 2010
SOURCE: How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
Posted on Jul 14, 2010
Cannot remove top agitator from bottom agitator on whirlpool ultimate care 2
Easy once you have removed the agitator put both feet on either sides. In other words hold it down and pull. The factory tabs needs to be broken. If that fails used a long screw driver and try and break off the tabs.
Apr 28, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Hello, the agitator seems to work (and turn) well at the bottom but it seems stuck at the top (hardly turns. What can I do? Thanks, Isa
If it has a fabric softener dispenser in the top, it is most likely a waxy buildup from the lanolin in the softener. Disassemble and clean.
Sep 11, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
How do you disassemble the agitator for a whirlpool ultimate care ii?
Jul 18, 2011 | Whirlpool Ultimate Care II GSW9650LW Top...
Why would the agitator spin freely? It's not
The agaitator dogs are worn out or broke. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the disassembly and replacement.
Mar 27, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II, Top agitator not working. I got it apart and can see the agitator dog gear not catching, unable to free the gear from the clips. Suggestions?
Mar 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Top agitator does not move on a whirlpool LSN100KQO Ultimate Care II commercial washer. how can i repair that?
I have run into the same problem and spent some time with it. There are little pieces that catch and release the top aggitator called dog agits(dogs). They are cheap and easy to replace but the problem is this aggitator is put together so that the top and bottom piece do not come apart. I dont know how this will resolove.
Oct 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool ultimate care 2 washer works great, however, the agitator misses and clicks before it catches up
Is this a two piece agitator? You may just need dogs, they are inside the agitator. Rotate the top of the agitator back and forth, top should engage the bottom portion when turning counter clockwise.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
528 people viewed this question
Top Washing Machines Experts
