Question about Microwave Ovens
Major Arching!!!! Whenever it's used it will start cooking for a few seconds then start arcing from the "element" on the right side.... It's a year and a half old........ Any ideas? Thanks, Doug
  • 706 Answers
Hello Doug,
Not sure I understand exactly what you are being confronted with when you say the arcing occurs on the right side .. I assume that is the side that houses the magnetron and waveguide assembly.. The fact that your microwave is 1.5 years old is irrelevant unless you have extended warranty coverage. If you place a cup of water in the cooking compartment and run the micro for about 1.5 minutes do you still experience arcing? If so.. you may have a loose connection on the magnetron, a bad magnetron , filament transformer may be breaking down or any number of non user serviceable components. Unless you are properly schooled on how to service a microwave oven, you should not try the repair yourself. There are high voltage components in there that pose a safety hazard even when power is disabled. If yoyrs is a table top model, the cost to repair may exceed the cost to replace so it may not be worth it.. Hope this helps...
Posted on Oct 14, 2008
After working on over fifty microwaves in the past six weeks, the assumption is that the magnetron has gone bad. I have seen magnetrons go for $45 -$169 bucks. Depending on how much you paid for this microwave, it may be best to buy a new one. You can always chat with someone on searspartsdirect.com, and they will tell you how much a magnetron should cost for your unit.
********CAUTON******** There are High Voltages that can kill you and all types of precautions should be taken.
Posted on Sep 15, 2012
Hi. Our 1 1/2 year old Sharp KB6524PS Microwave Drawer: While cooking oatmeal, at start of cycle, the microwave started arcing, then smoking. Shut off at 15 seconds. Microwave-safe china used.
I expect the arcing came from the waveguide cover or aerial cover having either a crack or carbonised food particles on it.
A new cover may affect a cure if the magnetron is not damaged.
Aug 18, 2017 | Sharp Microwave Ovens
Arcing and bang noise
The arching is probably to the cabinet where paint is missing. This usually occurs at the edge where the microwaves travel into the cabinet. You can get microwave paint from your local appliance parts supplier. It's special paint that is non - conductive.
May 17, 2014 | Sharp R959SLMA 900 Watts Convection /...
I have a GE Microwave Oven/Dual Element Browner Model # JES1288SHO3. The inside cabinet is arching through the wave guide panel. DAVE IN LA.
Hi Dave in LA,
The wave gude cover is replaceable, the part number is1085082. The reason for arcing through is typically a splatter of food stuck to the cover and then the heating waves overcooked or burned it. Carefully replace the cover (panel), look for any burned spots behind the cover, if the wave guide is burned through, the Microwave is unrepairable. If the waveguide has small arc spots you can carefully clean (sandpaper) and use touchup paint to recoat. I hope this helps and if it does, please let us know!
Apr 18, 2010 | Microwave Ovens
I have a Frigidaire over the stove microwave that pops/arcs
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 15, 2009 | Frigidaire GLMV169D Microwave Oven
The microwave starts, then stops after a few seconds, and smells
Remove the cover after pulling the power plug. Check the transformer and large capacitor for signs of overheating. If they look ok, then remove the sheet metal wave-guide from the area where the energy enters the cooking cavity. Under the wave guide is a fan-like device called a stirrer that has a plastic bearing. This stirrer bearing is commonly arced over (when the oven is operated with nothing to heat in it). Usually the bearing looks good, but has arced internally. Replace the stirrer as a unit. The machine can be operated with the case off and a cup of water for a load, but keep you hands clear. Look for smoke.
Sep 07, 2009 | Panasonic NN-H504WF Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Arcing
The metal shelf that comes with most microwave ovens must NEVER come in contact with any surface of the cavity wall or arcing will occur. (this is why its is mounted on plastic clips). IF you are not using the shelf to cook multiple items (as most people don't)....Remove the shelf and store somewhere else until needed.
Jun 06, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Comes on when you open door, and now it finally quit working
I think you've put up with enough hassle from this unit and should get another one. Intermittant flakey problems are hard (read expensive) to fix.
Dec 29, 2007 | Panasonic NN-S962 Microwave Oven
Microwave Ovens Logo
139 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
