SOURCE: Connect A JVC GR D31 Camcorder to a Computer Via USB 2
Well I'm afraid not the cable don't not come in such of a way either cause they are different type of cable, but what u can do is buy an external fire wire card for yr PC it comes in PCI format for yr desktop PC. because camcorder in these days do not use USB cables due to the cause that fire wire cable is much faster than the USB ones.
SOURCE: JVC GR-DX307 Mini DV Digital Camcorder
I need Drivers for JVC GR-Dx307.
I do not have the CD for my camera,Kindly help me to get the Tape data to my computer,
Regards ,
Basha
Bellary
[email protected]
SOURCE: Camcorder to computer
u need the dv cable out from the camera , to usb going in to the computer and more than likely the drivers that will probably be needed. Also you will need a certain software program that is compatible...usually comes with the driver.
SOURCE: I need to transfer video from JVC GR-770U Camcorder to my compute
Hi I am Vortash according to the manual for this unit available on http://www.safemanuals.com the unit is quite capable of downloading to a computer but yes it does require the correct software to do so .. you may find this is available from JVC support as a download .. it says that you can download to a usb terminal or a Rs socket with a compatible retail software .. hope this helps Regards Vortash
SOURCE: We can not connect our JVC GR-DF430AA CamCorder
In order to connect your camcorder to your computer, you have to install the drivers for your camcorder and windows Operating system before you connect your comcorder to your computer. Here are the steps in sequence to install the drivers.
1- Use the CD which came with your camcorder and install the drivers. If you do not have the CD, you may be able to download it from JVC webSite.
2- Afetr installing the drivers, Connect your camcorder to your PC and turn the dial to play (Turn on the comcorder if not on).
Follow the screen until it says ready.
3- Now click start, then computer. You should see several icons with one of them having all or part of JVC GR-DF-430AA Camcorder. If you double click on that icon, you would see one or more folders with your stored pictures and videos. Now you can download, copy delete all of them.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
