Question about Brother Sewing Machines
Ce5000prw recieving f5/e6 error message
All of a sudden my machine began doing a burst of reverse stitches and then flashed e6/f5 error message. the e6 reads in my manual to be a thread tangled up so I thoroughly cleaned the machine and tried again. same thing happened. so obviously the f5 is the more important issue but my manual does not say what this means.
    Problem Solver:
  • 8 Answers
I know this probably won't do you much good as it is now nearly 3 years after you posted your problem. However, I just had the same problem after using my machine for 4 years and couldn't find any solutions or answers anywhere, even from Brother, so I figured I'd post an answer in the event someone else has this problem. My local repair center wanted to charge $100 to even look at it since it is a computerized machine and Brother said the F5 code was not a good thing and I really needed to have it checked by an authorized dealer. You can get this machine brand new for $150 so I didn't see the point in spending the money to fix it.
I finally decided to open the hard case and see if anything was up. Yes, this voids the warranty but what good was the warranty going to do me anyway when I could replace it for less than any repairs would cost. When i opened the hard case, I discovered over 40 glass head straight pins scattered everywhere. I have a 3 y/o son who apparently thought dropping the pins through the holes on the top great fun, lol. I removed all the pins and used canned air to clean out all the dust bunnies, put it back together and was back in business in about an hour. The machine sounds great and doesn't skip a stitch!
Posted on Aug 26, 2011
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
E6 error keeps coming out and it never stops now even if the tangle thread is removed.
Have you cleaned and oiled the machine lately? If not, your manual will have instructions on how to do this and this may solve your problem. I have a CE5000PRW and have had to pull the bobbin shuttle completely out sometimes and clean that out as well. I always keep canned air handy to blow the fuzzies out of my machine regularly as I use mine everyday. I did recently have a problem with this code showing up on my machine no matter how much I cleaned it and a couple of times it even flashed f5 along with the e6 code. It was going to cost me nearly as much money to have it looked at by a repair shop as it would have to buy a new machine so I went ahead and opened up the hard case (voids the warranty but my machine was only $150 and they want $100 just to look at a computerized machine - before doing any work to it so I wasn't worried about the warranty). I found straight pins and dust bunnies everywhere when I got inside. My 3 y/o apparently thought it was fun to put the pins in the little holes on top of the machine and watch them disappear! Anyway, I cleaned out all the pins (over 40) and the dust bunnies from everything, put it the case back together and it runs great.
If you decide to go ahead and do this, be sure to be very careful when you open the machine. There will be a cable that connects some of the computer chips on one half of the machine to the chips on the other half and you don't want them to disconnect. Pay close attention to which screws were in which hole. Canned air works great for getting all those dust bunnies out. I recommend going outdoors to do this part or you will have dust everywhere!
Aug 26, 2011 | Brother CS6000i Computerized Sewing...
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
How to do a basting stitch CE5000PRW
Usually it's just a case of using the longest straight stitch that the machine has. Shout if you need more help!
Apr 06, 2010 | Brother Sewing Machines
The machine was accidentally dropped. We started with an E7 error, and now an E3 error message.
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed
E3 means
The buttonhole or bar tack stitch was selected and the
start/stop button was pressed while the buttonhole lever
is raised.
(make sure buttonhole lever is in correct position)
If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears.
download manual for this model at
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_cs80eus&dlid=&flang=English&type2=-1
Hope this helps
Feb 05, 2010 | Brother CS-80
Code E6 on Brother CE5000PRW sewing maching
I fought with this machine so much, then felt like a fool. It wasn't threaded properly, and I needed to re-set the tension.
Thanks for being there - if only to vent......
Nov 22, 2008 | Brother Sewing Machines
E6 and F5 error message
Are you using the right size needle? Try using an 80. Also try taking it to a service center. To find one near you go here: http://www.brother-usa.com/service/
Jun 21, 2008 | Brother CS-100-T Computerized Sewing...
Sewing Machines Logo
409 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
