Question about Hunter Fan Company 5/1/1 Programmable Thermostat
I have a trane thermostat and I need help programming it
I have duel heat which is gas and ac which is electic but when i switch to heat on thermostat it runs for a little bit then shuts off I think program is stopping it.
  • 56 Answers
If indeed the program is stopping it you can find out by putting the thermostat temp on a manual hold. Set tstat to a desired temperature then push hold. If all works well then you will need to reset your program to fill your needs
Posted on Feb 14, 2009
My Honeywell PRO 4000 Programmable Thermostat is set to 62 but last night went to 74 & then to 78 & heat would not go off. We have a Trane XB furnace - Both 5 years old. Took face plate off...
You probably have it running a program. Try using it simply on heat mode. Then set temperature and press hold on thermostat. The word hold should show up on the screen.
Feb 02, 2018 | Honeywell Heating & Cooling
Home AC only blows cool air when set to fan. When placed on Auto/fan it doesn't blow and no heat.
At your thermostat ,
Set switch to heat, turn up temp switch.
Fan should be set to auto. Wait up to 5 mins to be surethat somthing is wrong. If your fan comes on without heat. Check gas valve or if heat pump check main a/c breaker. If elect heat or any of above dosn't work.
Call a service company. If your in Pensacola. Look up Absolute Heating and Air Conditioning.
Oct 30, 2012 | Heating & Cooling
Trane xe 1200, can i use the heat blower with out a working compressor, i need heat not air, thanks
you can switch the thermostat to "emergency heat" which will turn the outdoor section off and the thermostat will control the electric heat elements in the air handler if it has them.
Oct 19, 2009 | Omega Trane Furnace Draft Inducer Blower ...
Trane Air Handler and Trane Thermostat with no power. Please help
First of all put back the jumper wire you remved Rc to Rh and also put the red wire to either one then the white to W, the green to G and the yellow to Y .That is for the thermostat wiring for a not heat pump outdoor unit.Remember this electronic thermostat has a time delay so the unit will take a few minutes to start.All this if the problem is the thermostat.But also when nothing works it could be that the drain line is clogh and some air handlers have a flood switch who shut the unit off if drain is clogh(it could be located in the drain line out of the air handler or inside it on the drain pan.) newer TRANE units have it inside.
Aug 13, 2009 | Heating & Cooling
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Trane XL19i 8? ton heat pump not heating very well
Your second stage heat check the dip switches on the board and the wires to the proper two stage heat t-stat.
Feb 06, 2009 | Omega Trane Furnace Draft Inducer Blower...
Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Jan 25, 2009 | Honeywell Electronic Programmable...
Hunter 44360 thermostat wiring
OMG! has anyone came up with a solution? I have the same problem as mlc3530b
Mar 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
234 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
