Question about Hitachi 51F710 Rear Projection Television
Tv pic to large for screen
I have a Hitachi 50" high def. For some reason the pic is too large for screen. I have tried to adjust using the aspedt button on the remote but that didn't help. Any suggestions?
  • terrybowd965 Oct 14, 2008
    The pic is clear, just enlarged.
  • terrybowd965 Oct 21, 2008
    I'm still have the same problem.
    Genius:
  • 1,913 Answers
U have to reset yuor dispaly resolution.
open case of back side.
then clear all dust and dry all ic chip .
also reconnect all connection.which u can do.
then check there is one screw if u find then with this screw u can set resolution of your tv.
thats all.
best of luck dear.
Posted on Oct 14, 2008
    Scholar:
  • 136 Answers
But is the picture clear or blurry.or faint looking.
reply.
Posted on Oct 13, 2008
53-55 in high def tv, few yrs old. picture is way too red, wont adjust out. what are some possible solutions please
If a Hitachi rear projection it may be an adjustment inside the set--If you comment here with the model number and it is what I suspect--I will tell you a easy way to try to correct this.
As a first step go to black and white program or turn color all the way off and stand back and examine the screen/picture= if not black and white and mostly RED this is a common issue on their projection sets.
Apr 21, 2012 | Hitachi Televison & Video
My Hitachi tv no longer has any green contract when I try to change the hue as a result my tv has a large centre area that seems to have a redish hue and no matter how I try I don't get any real color...
This problem is very common with rear projection TV's.
It is related to one or more of the colour guns being out of alignment or needing to be replaced. The only way to correct this issue is to have a technician come in and fix it or bring it into a repair center. I personally would suggest purchasing a new TV. The cost of getting them aligned is usually more then a basic LCD.
Hope this helps
Dustin
Feb 12, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a 50" hitachi rear projection tv, do i need
rozmyers,
You do not need a high def receiver, your unit has an ATSC tuner which is the same thing. You do need to hook it up to a high definition signal. You mentioned that you have satellite. Call your supplier and order the high definition channels if you do not already have them on the downlink. They should be able to tell you if you have them or not. They should also be able to tell you which channels they are (normally the higher ones). Once you have a high definition feed you will have the best picture you are going to get with todays technology.
Thanks for using FixYa and for the great rating. Please consider a testimonial.
hardrocko
Jan 09, 2011 | Hitachi 57S715 57" Rear Projection HDTV
The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines and you can see the goast chanel behind the green lines. On pic in a pic setting the pic. chanel is...
Exact same thing happened to me last night. The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines. Light is definitely on and visible in the back. Now goes out after abut 30 sec. Misery loves company. Will watch the site for a solution. 4yrs. old just went off extended warranty 45 days ago. damn
Feb 12, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Hooked up a hdmi/dvi cable
try using the red- blue- green high def connections
Dec 08, 2008 | Hitachi 57F500 57" Rear Projection...
P3 not playing high def dvd
make sure your tv input is on the right selection
Dec 10, 2007 | Sony PlayStation® 3 (60 GB) Console
Hitachi 50" 50GX30B PJTV
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
The whole screen is shifted 1 inch to the left.
When in high def and on the PC the formate buttom on the remote is disabled. The formate will have to be done with the high def remote or through the PC. You will have to contact the high def and the PC provider to adjust the format.
Sep 24, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
81 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
