Question about Dewalt D51256K 16 gauge finish nailer kit
Gun wont sink nail
Gone was droped long time ago started to leak a little air out of the exhaust but still worked fine now a year later the gun has started to not be able to sink the nail with the adjust all the way in
  • 104 Answers
Sounds like safety needs adjusted you have bent the arm and it is thinking that the guard is not fully depressed and thus it vents air . adjust it with wrench or straighten arm. I have had this happen before- but in my case the adjuster backed off- same result -look in manual for adjusting as well - should be there or take to service -easy fix and should be cheap
Posted on Oct 22, 2008
When i tried to use the nail gun, it only produce a little pop and no nail came out
Try spraying Carburator cleaner to clean out the air chamber on the gun, and where the nail comes out
Sep 26, 2015 | Air Tools & Compressors
Miss fires and wont sink nails depth set deep and pressure over 120 psi
If no air is leaking from gun, miss-fire is usually caused by worn or too tight piston oring or lack of lubrication. Easy test. Disconnect airline, remove nails, point nose of gun up then down. Driver should stay in uppermost position. If driver moves up then down within gun replace piston oring and retest. Set pressure to about 100psi. Good luck with repair.
Oct 14, 2012 | Porter Cable Coil Roofing Nailer
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at Good lucki
Apr 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
There is a flow of air continually blowing from the gun at the nail loading location, causing it to fail to properly sink the nails into the wood
Can't be specific without model number, however, air leaking around nose area (where driver strikes nail) is indication of orings not sealing around cylinder spacer and body of gun and/or leaking at cylinder spacer and cylinder. Most likely grit has entered the gun and has begun to scratch metal and orings. Time for a reseal kit available thru Dewalt service center (or if you are a tinker-er, remove head and pull cylinder, remove fine scratches on body of gun with fine sandpaper and lube with plenty of silicone lube paste ). Final note, air could be leaking between cylinder seal at top of cylinder and headvalve. Air leaking here would also come out of gun thru nose, but the driver would be pushed down cylinder with nails removed. If no scratches are found and orings appear to be in good shape, then suspect this seal.
Dewalt used vinyl orings (gold colored) that do not last allowing leaks. The orings that come in their repair kits are also vinyl (not good). If possible replace bad orings with buna-n or viton from bearing house. Good luck
Mar 28, 2011 | Dewalt Air Tools & Compressors
Coil nailer wont feed nails, fires no problem
Remove nails from the gun and dry fire the gun by bumping it against thick rubber mat or coiled up rubber hose. As the gun cycles notice the feeder moving back then forward in time with the cycle. Make sure that the feeder is connected to feeder driver with a roll pin and that the check feeder is in place in the latch door. The check feeder is thin metal and should have spring action. The driver should return completely to top of cylinder with some degree of force. There should not be much air leaking out the nose as the gun cycles. If a quantity of air is leaking out nose with each cycle, then lower bumper may have broken/cracked. Replace as needed. If very little air is leaking out nose with each cycle then driver could be bent, piston oring could be worn or lack of lubrication in cylinder. If all lower parts seem good, then only area left to check is head valve. There is a 1/4 inch dia. rubber ring at the very top of head that could restrict air flow out of exhaust port. Adjust as needed. Good luck.
Mar 18, 2011 | Duo Fast DuoFast 1015141 CNP65Y Siding...
Brad nails not in all the way
There are no adjustments on any electric stapler / brad nailer that I've heard of , only the pnumatics. The electric staplers/brad nailers only work well in softer woods
May 26, 2009 | Arrow ET200 Electric Brad Nail Gun
The nails are only coming half way out and sticking.
Hi again, Well we don't know what size or how you are using your compressor but if it receives a lot of use like in a big shop, investing in a dryer might not be a bad idea. The more you use one the more water as heat is generated by compressing the air and as in cools it condenses the water out. In the mean time most all compressor tanks have a valve at the bottom of the tank to drain the water out, open it slowly so that you get a good stream and when the water is gone it will start bleeding the air and you can close it. I think Idaho is right about the composition of the nails and sometimes the glue strip on the top that holds them all together can gum up the gun. Also between you and me I don't think there is such a thing as an oil less pneumatic tool. Put a couple of drops of pneumatic tool oil in the air inlet, if the gun doesn't need it, it will come out in the exhaust. but it will also force any moisture through the gun as well. Let me know how this works out for you and Thanks to Idaho as well.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 27, 2009 | Air Tools & Compressors
Gun failure
Have you been lubricating it regularly with nail gun oil. We use framing nailers every day at the commercial tree farm I work at and one of the operating instruction is to put 6 to 8 drops of oil in the air hose connection on the nailer before every use. I suspect the O ring on the piston is worn out/
Hope this helps Good luck Loringh PS Please leave a rating if appropriate Thks
Nov 15, 2008 | Dewalt D51256K 16 gauge finish nailer kit
Dewalt D51256K 16 gauge finish nailer kit Logo
194 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
