Question about Sharp VL-WD450U Mini DV Digital Camcorder
Playback(not capture) miniDV on a PC using Firewire
I just want to use my PC as a playback source for my minidv tapes- i have 35 hrs of video, and only want to capture a small amout for editiing, but reviewing on the camcorder is making me crazy!
I have firewire, and a new fast computer with plenty of memory (2G , intel 6066 chip, nividia media card etc)
  • 35 Answers
SOURCE: Firewire connection not responding
Take a magnifying glass to the firewire port on the camera. Check to see if it looks damaged at all. I've used firewire with my students for many years and this has happened to me on more than one occasion. The student is not as careful as he could be when plugging in the cable. The inside of the firewire cable becomes damaged. This is a cheap fix. Buy a new cable. However, when the port is damaged, it is an expensive fix. Since the computer recognizes another camcorder it may not be the computer. And if you are using the same cable, then it will probably be a hardware issue with the camera. Look at the port and let me know if anything looks out if place.
Posted on Jul 01, 2007
  • 298 Answers
SOURCE: Help!! Can not connect my Sharp ViewCam Z VL-Z3U Through FireWire
Try searching these posts to see if they will help your problem. Seems this is common. See the link below.
http://www.fixya.com/tags/VL_Z3U
Posted on Mar 26, 2008
ripleymojica
  • 643 Answers
SOURCE: How to fix Sony DCR TR7000 Firewire port
if you can open camera make sure the ribbon cable from port is seated all the way. if not replace input board.
Posted on Jun 02, 2009
erleichda1
  • 7 Answers
You've probably fixed this by now, but since nothing is posted:
I have an older Sharp digital camcorder, one of the first. It's the VL-NZ100 and Sharp does not support transferring the video to a PC with this camcorder because they did not include the cable to do it. That said, I WAS told by Sharp that I could figure it out myself if I got a fireware (IEEE) cable.
I got a very inexpensive IEEE-1394 firewire cable, set my camcorder to Tape/VCR, connected the cable to my PC and my camcorder, and Windows Vista recognized it. It asked if I wanted to transfer the video and it just walked me through the whole thing! This is built in to Vista, so if you have the operating system, you are set.
If you don't, I don't know if you can download Windows Photo Gallery from Microsoft. I know that you can download Windows Live Photo Gallery but I don't know if that has the same functionality. You didn't mention what operating system you have.
And FYI, I didn't need drivers.
Posted on Jun 11, 2009
  • 155 Answers
SOURCE: My computer has no firewire port
Unfortunately USB and Firewire use two completely different protocols for handling the data transfer, so it is not possible to just buy an adaptor that will change one to the other.
You can however buy fairly cheap plug in Firewire cards that will fit a notebook, providing you have an expansion socket (PCMCIA, CardBus, ExpressCard). Just try Googling '"Firewire for notebook"
Hope this helps!
Posted on Jul 02, 2009
How do I upload miniDV tapes to PC running windows 7. What's the best way to save the tapes for editing
Use the IEEE1394 Firewire interface on your PC if you have one. If your PC does not have a IEEE1394 port then you may be able to add one via an internal add-on card or a PCMCIA card if it is a laptop. With Windows 7, you can use Windows Moviemaker to capture the video. Don't bother with USB capture as this will be low quality and too slow. Moviemaker is not great for editing so you should investigate alternatives.
Captured video will take about 4GB of hard disk space for 20 minutes of video. If you are using a FAT32 file system then this is the maximum file size limit. You should therefore use NTFS to capture large video files.
May 25, 2016 | Sony Handycam DCR-TRV33 Mini DV Digital...
I want capture vedio through usb in movie maker but it cant support usb how it will possible?
You c annot c apture from tape using a USB cable. You can if you connect using a firewire cable. All miniDV camera will have a firewire socket. It may be called iLink or IEEE1394.
May 09, 2011 | Panasonic NV-GS11gc Mini DV Digital...
If i connect my sony handicam dcr-h26 to my laptop usb it says unkown usb device
Using USB with a miniDV camera will only allow still picture transfer.
You will have to use an appropriate Firewire cable to capture any video from the tape.
Mar 09, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
How to transfer sony dcr-hc26 videos to pc using usb cable thanks
The Sony HDR-HC26 is a miniDV tape based camcorder. No surprises if you can't get USB streaming working.
ALL miniDV tape based camcorders transfer DV-format video by conneting the DV port of the HD camcorder to the Firewire port of your computer. USB won't work. The "DV" in miniDV = Digital Video. It is as digital as the digital video from flash memory or hard disc drive or DVD based camcorders - only better because it is not compressed as much as the others.
Memory cards are not the only way to store digital video - and while not as good as miniDV tape, memory cards are not as bad as DVD based consumer camcorders...
Firewire IEEE1394, DV and i.LINK are all the same thing.
If your computer does not have a firewire port, hopefully it has an available expansion slot (PCI for desktops; PCMCIA or ExpressCard for laptops), so you can add one.
Oct 17, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony MiniDV DSR-PD170 won't playback recorded video
the tape path of the camera needs to be adjusted ,so you need to get that fixed.
regards
Aug 04, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
I need drivers for JVC GR-Dv500 camera
GR-DV500 is a miniDV vcam w/c must be FIREWIRE**-connected to a pc to upload video thru video capture or video editing* application while vcam is on playback. Before cable** purchase, note: Firewire port of vcam is 4pin...check the firewire port of PC whether 4 or 6 pin. http://en.wikipedia.org/wiki/Firewire
Normally, the drivers are bundled with your computer OS, such that when the vcam is connected, the vcam is recognized by the video editing programme.
For starters, free Windows Movie Maker* (XP-wmm2 & Vista-wmm6) provides simple & easy way to learn the ropes < click help for details>. Upgrade to other video editing app http://video-editing-software-review.top... accdg. to need & skill level
Video Editing Process
>>> open wmm- start/all programs/wmm->TASK pane
..Step 1. Capture/Import video files (+pics, music) to be edited
..Step 2. Edit- drag/drop files->timeline & enhance w/effects, transition, music & titles
..Step 3. Finish (render)- save Movie file, also save Project* file
..Step 4. Share-burn to CD (to DvD thru a DvD authoring app)
Jul 11, 2008 | Cameras
Sony DCR-HC38E Exporting miniDV video to computer
I had a similar problem with my Sharp camorder.
The preview window on XP simply displays corrupted images.
At the end, I bought a different firewire card and it worked for me.
Good luck.
Alex
New Zealand
Jan 15, 2008 | Cameras
How to use the MV6401 as an AD converter
There are more direct way of transferring VHS to digital format (MPG, AVI, etc. There are now cheap video capture devices like TV tuner, or a video capture card tha connects to USB 2.0 port. However if you still want to use this camera, this ?s what you need to do. 1. Connect the camera to the PC. Most MiniDV cams have an iterface called i-link, firewire or IEEE-1394. If your computer has no shuch interface, you have to install. 2. Record the analog video to the miniDV tape. 3.CApture the recorded tape to the PC. You need to video capture software to do this. You may need to convert the format to the format that you prefer. 4. Burn the vdeo to DVD, you will need a burner and video autthoring softare such as nero.
May 28, 2007 | Canon MV630i Mini DV Digital Camcorder
Audio meltdown!!
Use a head cleaner tape (available on eBay most likely) and clean the recording heads.
Mar 14, 2017 | JVC GRD650US DIGTL VIDCAM 32X ZOOM 16:9...
Sony HC90 and Picture Package software
Ask "What is this Picture Package software?" And what does it do? Here's the gimme that you don't move video with this product: " Is Picture Package compatible with USB2.0? It is only compatible with USB1.1 not 2.0." From the Sony site. Look to other software and move to a Firewire connection.
Sep 14, 2005 | Sony Handycam DCR-HC90 Mini DV Digital...
Sharp VL-WD450U Mini DV Digital Camcorder Logo
52 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
