Question about Frigidaire FRS26ZSG
Freezer freezing over
The freezer has a open vent at the bottom on the inside at the back.. i can see cooling coils thru the open vent.. after a while the cooling coils will freeze over and the frig compartment will not cool at all then... last year.. the unit did the same thing. and i found the switch under the left front side of the frig...and i adjusted the setting on it ....it took a few trys but it worked for over a year after i fooled with that switch a few times..Now i cant seem to hit the lucky spot with the switch at all..i suppose it has went out .. can you help me?
We have the same problem: We own a Fridgedare FRS26ZXH that's about 10 years old. We went to the following website: http://www.refrigerators.com/refrigeratortroubleshooting.aspx
and found a solution.
A refrigerator self-defrosts about four times a day. If a part of the self-defrosting system stops working, the refrigerator keeps cooling. This causes frost and ice to build up on the evaporator coils, which keeps air from the circulating fan, which in turn prevents the refrigerator from cooling properly. It sounds contradictory, but if there's ice building up in your freezer, your refrigerator probably isn't cold enough either. We could not see the coils in the back of the freezer compartment (should be shiny aluminum color). All we could see was ice build up over what might look like a vent.
We carefully blew warm air on these coils with a hair dryer until we could see the coils. Time will tell the cause of this problem if it happens again. It may be coincidence that the outside temp went into the teens and my 4 year old flipped off our house's heating system overnight, causing the issue.
If the problem is with the defrost system, it's either the defrost timer, defrost heater, or defrost thermostat.
Posted on Dec 23, 2008
Testimonial: "thank you.i bought a defrost timer switch..and for the last year it has ran well..now the compressor isnt kicking in..all i get is the fan to come on"
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
The refrigerator stays at 47 degrees but the bottom compartments freeze
You have a defrost problem. A blockage of frost in the freezer prevents air flow over the cooling coils there, allowing very cold air to migrate back into the bottom of the refrigerator section. Unload the freezer and remove the back wall, melt the frost off the coils with a hair blower, and check to see if the defrost heater at the bottom of the coils is burnt out. If heater is OK, replace the 1.5 inch long white thermistor located at the very top of the cooling coils.
Feb 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Freezer is slowly getting warmer - water dispenser won't dispense (occasionally) turbo cool won't work
Open freezer door and look for any frost on the back wall inside the freezer. That would indicate a defrost problem.
Disconnect power to refrig. Unload freezer, Remove shelves and back panel inside freezer. Melt frost with a hair blower. Replace defrost heater located at the bottom of the heating coils. (Note: It may look different than the original, but insturctions enclosed with replacement cover that) Might as well replace the evaporator thermister at the same time, as your problem is about 98% of the time one or the other of those parts. The thermister is a white pencil shapped item, about an inch long, located cliped to the top of the cooling coils you just defrosted.
If you don't have the parts on hand, defrosting only will get your refrig working again for several days, while you obtain the parts.
Note: non-water dispensing is the result of the cold air from the freezer not being able to continue over the frost blocked coils, so it migrates back though the return air vent in the bottom of the refrig, resulting in a frozen water line, and often freezing in the bottom bin of the refrig.
Jan 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not cooling. Pulled out fridge and cleand the vents for the cooling fan in the back. Also cleaned the front vents and coils. Tilted the fridge a little bit to get at the coils on the bottom....
If it is not cooling at all it is because the compressor is not running and that needs to be confirmed. Once established that the compressor is not running, then you need to look at the start relay and the capacitor if there is one (Capacitor). That may be the problem; bad start relay/overload or bad capacitor. Check thoroughly. If your compressor is running and there is no cooling, the refrigerant might have escaped ; I mean a refrigerant leak. In that case, you need to call a serviceman.
Dec 24, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Refrigerator Has stopped chilling/ keeping things cool and freezer has stopped freezing.We Have Cleaned all the Vents of Dust and Hair And Checked Coils Foe Freezing. What Else should be done To Ensure Itz...
Check fan in freezer. Put your ear inside and listen and feel vents for air circulation
Also you might need a hardstart relay installed on compressor.
Check with local parts dealer for the part (ERP410) Instructions are on the kit. Easier than you think to install.
If this was helpful please rate me.
IMUFO2
Sep 12, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Water is leaking out of inside bottom vent of freezer and pooling and freezing on bottom under pull-out container unit.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Amana arb2557cw condenser coils freezing, fridge not cooling
There are a few things that it could be. Do you mean the evaparator coil? This would be the coil on the inside of the freezer, the condenser is outside the unit. If the evap. coil is freezing, you could have to much in your freezer blocking air flow. You could also have a evap. fan not running. Check the owner's manual for the location of the defrost timer, it could be bad. The thermostat needs to be checked and set so that it is at a reasonable level. One last thing to check would be the condensate drain. Make sure the drain is not plugged or the line is not plugged. Good luck.
Jul 31, 2009 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Refridgerator not cooling
is it side by side or freezer on top/bottom...check to see if the fan inside the freezer is running when the compressor is running..also check to see if ice is covering the evaporator coils.. the freezing should be even with a thin layer of ice/ not partically melted..sometimes the ice forms in the vents and stops the air flow...to review...check and see if fan is working in freezer
check to see if vents are clogged......good luck!!
Apr 29, 2009 | Refrigerators
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
Freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Apr 01, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Refrigerators Logo
283 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
