Question about Canon PIXMA MP830 All-In-One InkJet Printer
Pixma 830 I'm trying to scan a document. I get to the =>Scan screen but nothing happens when I press (either the Color or Black) button.
  • Anonymous Oct 14, 2008
    Scanner won't scan- nothing happens!
  • arthughes1 Oct 14, 2008
    i updated the drivers and it works fine now.
You need to use your MP Navigator , It should be on your desktop , after downloading driver, then click on Scan. Naturally the document must be on the glass platen. Hope this helps
Posted on Oct 22, 2008
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
How do you scan?
Hi kebranch,
To scan the documents, pictures etc., This are the step just follow,
1. Scanning using the Operation Panel
2. Load the document on the platen glass or in the ADF.
3. Press the [Scan] button on the machine.
4. Then the machine switches to Scan Mode
6. Press the [Color Start] or [Black Start] button on the machine
7. MP Navigator starts on the connected computer. You can scan in documents placed on the platen glass or in the ADF using MP Navigator.
Hope it helps.
Thank You for using Fixya.
Sep 07, 2011 | Canon Pixma MP450 All-In-One InkJet...
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
I have Canon MX 310. It prints, sends fax and copies with no problem at all. But it does not scan. I push the scan button and it then shows a screen that is black or color scan. It then changes to...
Hi
I think you will need to run the cd installer again to install the scanner driver on your printer.
You can check if the driver of the scanner was successfully installed once you view on the Scanners & Cameras inside the Control Panel and see the image of your printer scanner. It means it is connected and ready to be used. If you can not see the icon of the printer scanner there, then, it could not be installed or the printer is attached to other pc in the network.
Remember to use the printer as scanner, it should be attached locally to the pc you are using. Pressing the Scan button in the printer will save the scanned documents in the computer as pdf files.
In order to save the documents as jpeg files, you must need to use the scan option on the Scanners & Cameras inside the Control Panel.
Hope it helps. Just post back if you still have questions.
Dec 21, 2010 | Canon PIXMA MX310 All-In-One Printer
I havea mx310 but have lost the manual - how do i set up to scan photos?
You can download your manual from this site:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Solution: Setting scan methods for the button (Windows) - MX310
You can scan documents using the operation panel.
Important
bullet.gifDo not disconnect or connect the USB cable while the machine is in use.
bullet.gifIn Windows XP, the program selection dialog box may open when you press the Color Start or Black Start button on the machine for the first time. In that case, select MP Navigator EX, then select Always use this program for this action and click 'OK'. From the next time, MP Navigator EX will start automatically regardless of the selected scan mode.
arrow.gifSelecting a Response to Commands from the Operation Panel
1. Place the document face-down on the platen.
2. Press the Scan button on the machine.
The machine enters Scan Mode.
3. Press the Color Start or Black Start button on the machine.
MP Navigator EX starts on the connected computer. Scan documents on the platen or ADF (Auto Document Feeder) using MP Navigator EX.
Trust this is helpful.
Dec 14, 2010 | Canon PIXMA MX310 All-In-One Printer
How do use the scan.
The machine switches to Scan Mode
Nov 23, 2010 | Canon Pixma MP450 All-In-One InkJet...
How to scan documents with canon mp160
i press scan button then asking me to select publisher or photoshop, after select both but nothing happen
Nov 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My Dell copier model# A920 will not copy manually
If you want to scan you will need to connect the device to a computer. For copying, place a document to be copied on the flatbed scanner and press the color or black button (as appropriate).
Jun 02, 2009 | Dell A920 InkJet Printer
How do you scan a photo?
- press "scan" button, then press "start" button (either black or color)
- a small window (MP Navigator EX - MX310 series) should appear on your computer screen
- you can then choose one of the option there
- place a document or photo you want to scan on the canon plate face down
- then back to your computer screen and click "scan"
i have iMac and the pop up window says (MP Navigator EX - MX310 series) when i press "start" button on Canon
now i'm not sure if it'll say (MP Navigator EX - MX310 series) on windows PC
hope this helps. good luck.
Feb 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
135 people viewed this question
old marine
old marine
