Question about Kenwood KM800 Major Classic Stand Mixer
Problems with the speed, runs allways on high speed
  • 905 Answers
The selector switch is bad , needs to be replaced
Posted on Oct 13, 2008
  • jason Oct 13, 2008
    that is the only thing that controls the speed! the motor obviously works so the selector that controls that is bad!
  • jason Oct 14, 2008
    glad to help!
I have a KitchenAid KSM90 Stand Mixer and it will only run on Speed 8. Any ideas?
Your description is very incomplete. Does it not start turning until the lever is at position 8 or does it run at high speed from the moment it starts at position 1?
If it's not starting until position 8 then the problem is probably mechanical and will require some parts to be replaced or adjusted.
If it starts on high speed at position 1 then it's likely you need to replace the phase board under the back cover at the top.
Whatever you decide to do check the carbon brushes first as worn out brushes can sometimes create funny speed problems.
Oct 18, 2017 | KitchenAid Food Mixers
Kitchenaid Hobart K45SS when set at 1-2 accelerates to high speed when making dough. How can I fix this?
Usually when the mixer runs only on high speed it is caused by the control plate adjusted incorrectly or the control plate spring unhooked. Remove the trim & end cover on the mixer and check the control plate spring, if unhooked, attach to bottom of the control plate and squeeze the spring end, also check the speed control plate screws,there are 3 screws on this plate, one at the bottom two at the top, see if adjusting the top screws slows your mixer down.
Next check the wiring of the mixer, Insure everything is wired correctly, to get wiring diagram go to the last page of the service manual. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
If neither of those fixes the problem it is probably a bad phase control board, or a shorted phase control board. With the line cord disconnected, pull the t-bar contacts to open and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run, if it operates at full speed the phase control is defective and needs to be replaced.
Use the service manual to aid you in taking apart the mixer, trouble shooting the problem and putting the mixer back together, based on the mixer only running at high speed some of the time I would assume it is the speed control phase board.
If you have any questions let me know.
Thank you,
Colleen
Customer Service
MendingShed.com
Apr 24, 2013 | KitchenAid Food Mixers
Mixer only runs at one speed
if it runs only at high speed it needs a new phase control board if the mixer is post 1978, if the mixer is pre 1978 then you will have to replace a capacitor on the end of the power cord inside the mixer. if the mixer only works on one speed that is not high speed then you need to adjust or replace the speed control plate on post 1978 mixers and the capacitor on pre 1978 machines. Hope that helps
Jan 30, 2013 | KitchenAid Food Mixers
Kitchen aid hd professional mixer problems with speed controls
you need a new speed control board, easy fix about $35.00 for the part and an hour of your time, not even messy to do a total of six screws and four wire connections that clip on, several youtube step by step instruction videos available. parts available on ebay. let us know if this helps you
Jan 28, 2013 | KitchenAid Food Mixers
My kitchenaid mixer run on high at all times
If your mixer only runs on high speed there are 3 things that can cause that. The first thing to check will be the speed control plate, Remove the trim and end cover on the mixer, the first thing you should see is the speed control plate, this has 3 screws on it, try adjusting the top two screws 1/4 turn, this should slow the mixer down, do not over tighten. Also check to see if the control plate spring is unhooked. If the spring is unhooked, attach to bottom of the control plate, and squeeze the spring end.
If this does not fix your mixer, check the wiring of the mixer, you can locate a wiring diagram on the last page of the service manual.
If the speed control plate is adjusted correctly and all the wiring is correct it will be your speed control phase board. You can test the speed control phase board to see if it is shorted. With the line cord disconnected, pull the t-b ar contacts to open, and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, teh phase control board is defective and needs to be replaced.
This will aid you in taking the mixer apart, troubleshooting and putting it back together, remember the wiring diagram is the very last page.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 07, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
Panasonic Mixer/Blender not working - works only when tapped
It looks like there may be some loose wire connection. Or it may be due to carbon brush probelm. We at Inno Concepts or any of our dealers can diagnose and fix the problem for a reasonable cost. Please contact us at 770-594-1815 or send us an email with all the details to info@innoconcepts.com
For grinding hard vegetables, use thinner pieces not more than 1/2" in any dimension.
Jun 23, 2009 | Food Mixers
High speed stir setting
There are several things that regulate the speed, we will assume that the adjustment has not been messed about with. If the governor on the motor armature that presses against the underside of the square black speed control plate at the back has not flown apart then I would replace the small pcb (phase board) on the top under the back cover. One screw and 4 wires hold it on.
Jun 22, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid 2671 onmly run Stir and Second at high speed
Hi. Goto kitchenaid.com and download the parts catalog for your mixer model, these drawings will assist you in the disassembly and reassembly of your mixer.
You'll need to replace the speed control in your mixer. This is a common problem. Be prepared to wait at least a month for your parts to arrive. Unplug your mixer before you open it up.
If you're still under warranty call kitchenaid!
If this solution has assisted you, please rate it. Good luck! ricardok45
Jan 28, 2009 | KitchenAid KP26M1X Stand Mixer
K-tec elite mixer
The company handles these as Blendtec now. The web site is at http://www.blendtec.com/default.aspx Maybe this will help:
Customer service and sales are available from 8:00 am to 5:30 pm (MST) M-F.
Phone
Toll Free: 800-253-6383
Local: 801-222-0888
Fax: 801-805-8585
Oct 14, 2007 | K-Tec Kitchenetics K2 Stand Mixer
Kenwood KM800 Major Classic Stand Mixer Logo
141 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
