Question about Janome Sewing Machines
Janome XL-II Stuck in reverse
I am currently trying to fix mums old Janome XL-II mechanical sewing machine. The machine seems stuck in reverse. The reverse button is fully our but when you press it there is no engaging of systems behind it until at least 50% travel. As far as I can see the reverse mechanism is not returning properly so if someone could tell me where to look that would be great. I dont want to pull anything of this machine apart that I dont have to.
Thanks,
Matt.
RickE1
  • 202 Answers
SOURCE: Viking Husqvarna model 6440 gets stuck in reverse
There are numerous things that can cause this, some very simple, some less so.
1. Fortunatly, the most common one is also the simplest to cure. When you turn the selector (upper left) knob between stitches, one of the things that is happening when you feel the resistance is that it is lifting the followers off the camstack so that it can move to another stitch. When the camstack is normally doing its job, lifting the feed cam follower is what puts the mechanism in reverse. So, while the selector is between stitches, the machine is temporarily in reverse. Also, the dots where the dial is to be placed to change the camstacks is between stitches, so if the dial is on these dots or anywhere else except snapped into a stitch, you will get nothing but reverse.
2. The buttonhole mechanism is stuck in the reverse portion of the buttonhole. Usually if this is the case, the needle position will also be stuck on the left side, and the width control /buttonhole control will not function correctly. Usually you can correct this yourself and I'll explain how in a bit. It is usually caused by lack of use of the buttonhole mechanism.
3. Either the arm that connects the camstack to the stitch length block or the block itself is stuck. Both these parts are spring loadedto bring them in the forward position, so long periods of rest are a contributing factor.
All of these causes except for the first one are because of the mechanism not being exercised frequently enough. These older Vikings do not like to sit still very longYou should fully exercise all the knobs at every sitting.
Ok, try this fix. And this is to free up the mechanisms that are probaby stuck from non use and old oil and grime buildup. Take your seamformer (cam) out of the back. Find a hairdryer and blow some heat in there for awhile. This will soften up any hard oil or grease that may be causing the mechanisms to stick. Then if you can it would be best to have what is called TRI-FLOW oil (the BEST) and spray or drop quite a bit into there covering the mechanisms and let it soak in. You might try a good sewing machine oil soaking or WD-40 in small amounts. Little by little test your knobs, slowly working whatever is stuck lose. Never force the issue. Small amounts of movement little by little will eventually free it up.
Good luck. Hope this helps. If this does not help you may have to take it to a technician and hopefully you won't find out that your take up slide isn't broken which is a major job.
Posted on Nov 25, 2007
SOURCE: reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Posted on Feb 04, 2008
  • 8 Answers
SOURCE: LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
Posted on May 20, 2008
  • 323 Answers
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Posted on Jun 05, 2008
mallow1
  • 35 Answers
SOURCE: Janome Travel Mate - Model 4612 - Need InstructionManual
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link to them:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Posted on Aug 16, 2008
My Janome JL250 is stuck in reverse
Probably the reverse mechanism has stuck. Only suggestion may be working the lever manually to see if it frees up. Other than that, it would need service or replacement.
Jul 15, 2016 | Sewing Machines
The reverse button is stuck on reverse. How do I fix it to go forward?
Hello Leah, I think you need your machine cleaned and oiled. Over time, the old oil will dry out and even get sticky. This can cause the feed dogs to stay in the reverse position.
Oct 10, 2015 | Janome Sewing Machines
Necchi 535FA is stuck in reverse, no matter what adjustments I change. I oiled and cleaned it and properly threaded it. Everything seems to work and move fine, except the reverse button was stuck.
A part of the Reverse Button mechanism is probably frozen.
This may work:
Direct heated air from a handheld hairdryer into the internal mechanism and let the metal parts get pretty hot. (Don't burn your fingers!) Then try the reverse button to see if it has loosened. Repeat and hopefully it will begin working. If you figure out where the reverse button mechanism is located, you can try lubricating the metal joints--ONLY 1-2 drops of GOOD quality sewing machine oil (do NOT use 3-in-1, WD-40, cooking oil, or OLD sewing machine oil). Then try the hairdryer again. Do NOT oil plastic parts or belts unless directed to in the owner's manual instructions.
Vintage Sewing Machines
To keep your machine sewing well, be sure to clean and oil on a regular basis--about every 8-12 hours of continuous sewing, every time you empty a bobbin, or if it's not in frequent use, every six months. Oil drying out is a frequent cause of machine moving parts freezing.
Sep 01, 2015 | Sewing Machines
The reverse button does not work
The button is a relay switch and is an electronic component
Quite easy to replace, but you need to get parts from Janome Authorised Dealer
Feb 28, 2015 | Janome D'cor Excel Pro 5124 Mechanical...
Why is my Janome Mystyle 20 stuck on reverse?
It may be in the buttonhole mode, change the stitch selector to straight stitch.
Jul 16, 2014 | Janome Sewing Machines
My friend bought jenome sewing machine. It is working very well except that it only sew in reverse (backwards). Could it be that the reverse button got stuck or is there a setting that needs to be done?
button in centre of stitch length control is probably gummed up and stuck lubricate with penetrating oil and wind stich control backwards and forwards to see if centre knob starts to move. Remove arm top cover and do same to mechanism visible from above
Feb 19, 2014 | Janome Sewing Machines
The lever on my machine for dwing backwards seems to be stuck or broken
then it would be a good idea to have the machine serviced
to find out if the lever is broken or stuck.
Feb 22, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Machine stuck in reverse will not go forward
With these very cheaply made Brother models, unfortunately it is going to need to go for repair, if you try to open the casing you WILL break something.
Oct 23, 2011 | Brother XL-6562 Mechanical Sewing Machine
My machine is trying to sew backwards! moving the backward switch doesn't change it at all.
Try taking off the cover and then use a hair dryer pointed at the reverse mechanism, it may be stuck. Also oil according to your manual. If you cannot find your manual, go to www.brother-usa.com and download a free one.
Oct 07, 2010 | Brother XL-5340 Mechanical Sewing Machine
Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Sewing Machines Logo
141 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
