Question about Maxtor Hard Drive
Maxtor hard drive xbox 360
Hi, do maxtor hard drives work with xbox 360's
  • 7 Answers
The maxtor hard drives will work with an Xbox360 but in only one case, your xbox hard drive is linked to work only with your console and if you swapped hard drives the xbox wouldn't read it so to answer this you need to reset your Xbox 360 copy protection serial number i.e. Flashing your Xbox or Chipping it, once your Xbox is Flashed or Chipped you can use a maxtor hard drive through the SATA cable port in your Xbox
Posted on Feb 24, 2009
    Problem Solver:
  • 9 Answers
Im not sure but i wouldnt do it because if you use stuff not made for the xbox microsoft will wave ur waranty. something goes off inside it that shows that an object not made spicificly for the console was used
Posted on Dec 31, 2008
    Genius:
  • 1,061 Answers
YES THEY DO.RICHARDM69
Posted on Dec 14, 2008
4 Suggested Answers
raevenzero
  • 53 Answers
SOURCE: Maxtor 52049U4 20GB hard drive jumper settings
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
Posted on Nov 12, 2007
Philster
  • 113 Answers
SOURCE: Jumper settings for a Maxtor hard drive, Model 87000D8
Here's the chart that lists the jumper settings for all of the various models of Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
The first drive above is a DiamondMax 1750, and
the 2nd is a DiamondMax 4320
Posted on Feb 08, 2008
SOURCE: maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Posted on Oct 23, 2009
I can not play original xbox games now it said the hard drive must be attached and it is what is the problem?
Just assuming that your hard drive did not come with your Xbox 360? Or if it did then you bought your Xbox 360 used maybe? Below is the reason why some hard drives won't work with BC games. But before you go out and buy a new HDD then go ahead and remove your hard drive from the Xbox 360 and reinsert it to see if that helps. Note: it has to be a HDD not a USB memory for BC gaming.
"Simple. Certain eBay sellers try to make more money by buying 20GB official Microsoft Xbox 360 hard drives for cheap, and then putting larger laptop hard drives into the official 360 hard drive case and then selling them for less than an official drive of the same size would be. Now, technically, these hacked hard drives are the exact same thing as an official one, at least as far as parts go. They will function exactly the same as an official drive. But many of the sellers that sell these drives forget (or might be just plain ignorant about) one important thing - to play backward compatible Xbox games, the hard drives need a special partition for the Xbox 360 to store BC-related data in. If the hard drive doesn't have that partition, you can't play backward compatible games with it."
"So, to answer the question "Why won't original Xbox games work on my Xbox 360" there really is only one answer - Your cheap eBay hard drive might not be as official as you thought and is missing key files that allow for backward compatibility. The solution - Buy official Xbox 360 accessories from established retailers, or if you want to save a few bucks on eBay, make sure you ask the right questions so you know what you're getting."
Aug 04, 2011 | Video Game Consoles & Games
Xbox 360 slim doesn't recognise new 250GB hard drive
Follow this instructions please :
a. Remove the hard drive by pressingthe release button between the hard drive and the air vent. Lift the hard driveaway. b. Check the hard drive contacts fordust, dirt or other foreign substances. Clean if necessary. c. Reattach the hard drive by insertingthe back end of the hard drive into the hard drive bay on the Xbox 360. Press thefront end into the Xbox 360 until it clicks. d. Reinsert the power cord and turn onthe Xbox 360. If the Xbox 360 still does not recognize the hard drive, the harddrive or Xbox 360 will need to replaced or repaired.
Feb 18, 2011 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Xbox 360 Hard Drive Device (HDD) deleting content
Reformat the hard drive using the Xbox 360 system. If this does not work, then it is time to get a new hard drive for your system. We sell 20GB hard drives for the Xbox 360 so you can contact us and we'll be glad in helping you.
- You've been helped by a Wired Extreme technician.
Apr 16, 2010 | Microsoft Xbox 360 Console
MY XBOX 360 HAS 1 RED LIGHT FLASHING, WHEN STOOD ON ITS SIDE THE LIGHT IS BOTTOM RIGHT
one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables. first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more. If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you. The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Jun 06, 2009 | Microsoft Xbox 360 Console
MAXTOR 1TB not recognised by XBOX 360
see if there any updates for the xbox 360 in terms of flashing the bios or something along those lines - not sure if you can get into the configuration to alter any settings regarding or relating to detection of hard drives.
May 09, 2009 | Western Digital Caviar SE16 (WD5000KS)...
Xbox 360 elite 1 red light
The number for Microsoft is usually listed on the back of any game manual.
I hope I was able to fixya problem, and Happy Gaming!
Oct 18, 2008 | Microsoft Xbox 360 Elite Console
Maxtor basics hard drive and my xbox 360
Does your drive make any sounds similar to these? If yes you have a mechanical problem and you should get a specialist to work on it if you need that data.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Oct 03, 2008 | Western Digital Caviar SE16 (WD5000KS)...
Maxtor 3200 external hard drive
Make sure the drive is formatted for the appropriate file system.
Keep me posted.
Oct 08, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Hard Drive Logo
442 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
