Question about Bosch Nexxt 300 Series WFMC2201UC
Parts manual This may simple pretty simple, but where do I get a parts manual for my 300 series Nexxt Washer wfmc2201uc. I have a broken (leaks) intake valve. This is the second time this has happened. Do they have a problem
4 Suggested Answers
paulcharmbur
  • 744 Answers
SOURCE: Our Bosch Nexxt 300 washer has a small piece
Bosch Nexxt 300 washing machine
This video will show you how to change a
door seal on this Bosch front loader washing machine and where to get the parts!
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 05, 2013
  • 10 Answers
SOURCE: Getting E:13 error on Nexxt 300 series washer
Try putting the washer on COLD and run "TWO" cycles. It must be on COLD. There is a chance there is too much soap or fabric softener in the washer. It may also help to clean the fabric softener tray where you add the softener.
Posted on Nov 27, 2009
SOURCE: I just have gotten a new Bosch nexxt 300 series
Make sure your door is securely latched. Push it closed in the middle where the latch is.
Posted on Jan 10, 2010
  • 2006 Answers
SOURCE: Bosch Nexxt 300 series WFMC2201UC
You can check the inlet valves with either an o'scope or a multimeter. Unfortunately, the control module PN: 661081 controls the voltage to the inlet valves and costs around $240.
Sorry, to give you the bad news.
Posted on Jun 09, 2011
Leaking water
If it is still under warranty, I would call customer service. If not, I would call the place you bought it, and explain the issue. I am sure they can order the part or give you somewhere to order it. Is it a removable seal? If so, you should be able to six it pretty easily yourself. here is the manual. Hope this helps.
http://www.ajmadison.com/ajmadison/itemdocs/9000224447_ver03_WFMC2201UC.pdf
Jul 31, 2013 | Bosch Nexxt 300 Series WFMC2201UC
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Leaking
This video will show you how to replace the Bosch Next 300 Series WFMC2201UC washing machine door seal with step by step guide on the process of how to fit and replace
Apr 17, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Nov 22, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Our Bosch Nexxt 300 washer has a small piece missing from the door seal gasket - I'm a skilled home remodeling contractor - Should I attempt this repair - Are instructions an diagrams available - Who...
Oct 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Popping (electric) sound from back. Caused breaker to pop. Opened unit to get a better look, nothing broken or blackened. Reset breaker. and turned machine "on". No more popping sound. Washer only fills...
Have a look at the capacitor, this is part of the starting circuit for the electric motor.
It is a cylindrical shape and usually splits or bulges.
Post again if you need further assistance.
Jun 19, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch 300 series washer// led code E04
Remove the access panel at the front botton right corner. There is a manual release button you can pull.
Oct 27, 2008 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 300 Series WFMC2201UC Logo
91 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Richard Roth
Richard Roth
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
