Fisher & Paykel Washing Machine agitator removal
I have a Fisher & Paykel Aquasmart washing machine 8.0kg. I think there is an object stuck under the low profile agitator. How do I remove the Agitator to get at the object ?
  • julsam Mar 06, 2009
    I have stanley knife blades fell under the agitator. Need to remove agitator
  • 1294 Answers
SOURCE: I need a new agitator
Go to: espares.co.uk
or RepairClinic.com
Posted on Mar 21, 2008
  • 447 Answers
SOURCE: Water leaks from my Aquasmart 8 kg washing
On most units, the water pump was a "weep" hole on it which tells you pump needs to be changed soon. It tells you the internal seals are starting to fail.
Posted on Dec 28, 2009
  • 713 Answers
SOURCE: Fisher and Paykel Washing Machine
Hi just found your posting.Do you still require help?The problem with your machine sounds like your suspension rods are faulty.Please reply and I can help you rectify this fault.Looking forward to your reply.
Posted on Jul 16, 2010
  • 4 Answers
SOURCE: my aquasmart fisher and paykel
Sounds like the 'lid lock' has shorted out. They're not completely waterproof and have seen pins completely blown out inside them. Should measure 73 ohms (or very close to it) across the terminals. Hope this helps.
Posted on Feb 26, 2011
  • 251 Answers
SOURCE: Something is stuck underneath the
Hi - with aquasmarts there is a plastic dome like fitting in the middle of the agitator & unscrew this to remove the unit.
Posted on Jul 09, 2011
Fisher and paykel washing machine fault code 9 how to fix
All replaced electronic boards need resizing.
Going by your post your have an AquaSmart machine
Here are some details to resize an AquaSmart machine
Aug 03, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
How to clean machine
what are you wanting to clean?? most places are the pump & bowl under the agitator..
the pump is under the machine, some have a little plastic side hatch you open to get to the pump.
the bow is gotten to but removing the agitator, usually a thumb nut down the middle of agitator, and then pull up agitator to remove out the top,
soak up all the water & clean out the dirt & scale you find.
Feb 20, 2014 | Fisher and Paykel Aquasmart wl80t65c
Fisher & Paykel aquasmart washing machine display panel not working
You need to size set the LCD panel to your motor controller.
1. Press and hold the left SCROLL button,Then press HIGH EFFICIENCY button until two beeps are heard.
2. Press the SCROLL button to select machine size
(600 for WL70,650 for WL80).
3. Press the POWER button to set in memory.
Mar 05, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Something is stuck underneath the agitator in m Fisher & Paykal Aquasmart. How do I remove the agitator?
Jul 08, 2011 | Fisher and Paykel WL37T26D Top Load Washer
Cleaning washing machine
pull dispenser up and off lossen large plastic wing nut in bottom of agitator throat lift agitator off if you wish to remove basket pull plugs out front corners of top remove phillips screws lift top up remove agitator as described remove ring on top of basket it just snaps off lift basket straight up
Jun 13, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
383 people viewed this question
Top Washing Machines Experts
