Question about Cobra GPS
My cobra3000 keeps freezing up what could be causeing this
My whirlpool fridge is freezing the food in the fridge. What is causing that?
adjust the temperature settings.change from coldest to colder
Jul 15, 2014 | Refrigerators
Fridge keeps freezing up have replaced motherboard
What is the model number of your unit?
Nov 23, 2012 | Refrigerators
If i set the temp to low on my window air conditioner can it cause the unit to freeze up
Under some conditions, it could freeze up. High humidity levels can cause the coils to freeze. Not cleaning the air intake filter regularly, can also cause the coils to freeze. However, most window units can not be set below 65 degrees. But, in high humidity, it could freeze at that temp.
If you want to avoid the possibility of the coils freezing, operate a ceiling fan or other small fan as fast as comfortable. This keeps the cool air moving a generates a wind chill that fools your body into thinking it's cooler than it really is. Doing this will keep you from having to turn the AC way down and thus, save on energy cost.
I hope this has helped you and thanks for choosing FixYa.
Sep 08, 2011 | Heating & Cooling
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
Why do the freeze plug keeps popping out and keeps over heating change t stat and water pump
If your in sub bellow zero weather you need to install engine anti freeze not water this is the cause of freeze plugs popping water in your cooling system if you install anti freeze this should stop these from popping out on =you.
Jan 09, 2011 | 2001 Volkswagen Beetle
54501 Dehumidifier: keeps freezing up....
There can be many things that can cause the dehumidifier to ice up...
This tip will give you some things you can check...
Dehumidifier2_bing.gif is Freezing up and not working
May 16, 2010 | Kenmore 54501 Dehumidifier
My whirlpool AD50USS2 keeps freezing up and then runs into the bucket. It is connected to a drain hose. What causes it to freeze up?
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
May 03, 2010 | Whirlpool AD40DSL Dehumidifier
Keeps freezing
The freeze ups normally happen before the red lights of doom and they are caused by the GPU and the CPU getting too hot and the soldering snaps off so they lose connection.
If you stop the heat build up you will be fine.
You can do this yourself using a good repair guide or you can send it in and they will fix it for you.
Feb 01, 2010 | Microsoft Xbox 360 Console
Screen keeps freezing
The Firmware need to be reflash on the phone to correct this issue
Nov 20, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Keeps Freezing
Jul 04, 2008 | Creative Labs Zen Touch MP3 Player
GPS Logo
24 people viewed this question
Top Cobra GPS Experts
TO Lady
Are you a Cobra GPS Expert? Answer questions, earn points and help others
