Question about Lenovo 3000 J Series 1.80G VBE PC Desktop
RAM how much ram does the mainboard 2NKT31AUS support? I have 1gig now running windows vists home. Can I up this to 2 or 4 gigs? thanks
  • 749 Answers
Looks like your limmitted to 2 gig until they come out with a new bios for that model..
Posted on Oct 13, 2008
Need the motherboard to utilize all the RAM
Hello download the manual here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5L-VM%201394&p=1&s=22
The mainboard only supports up to 4 gb of ram.
To use the 4 gb, the ram type must be at equal size, inserted in the yellow or the black socket.
Good luck
Feb 17, 2013 | ASUS Computers & Internet
MT3705 Gateway, what motherboards will work with this laptop. I want to upgrade this laptop, so i want to get a motherboard able to really max out my ram but still use this chip set and everything else on...
You don't get different mainboards for laptops.....sorry. It's not like desktop pc's where pretty much any mainboard will fit. And even if you could, it's not really going to improve things, as you are using the same speed cpu. Your laptop has 2 ram slots. That's the most you will see on laptop mainboards.
Adding ram is probably the best bet. That laptop shipped with 1 gig of ram.....which is not enough for Vista. I bet it's quite slow. Vista wants 2 gig of ram to be happy, and 4 gig to really motor along. Laptop ram is cheap for that machine, so check it out. Ram is not expensive, and will give you an immediate, very noticeable improvement in performance.
Hope this helps. Post a comment and let me know how you make out
Sep 04, 2009 | Gateway Computers & Internet
Is 1 gig of ram enough memory to support vista to run?
Hey there you want to use vista?? lol good luck. You need a min of 2 gigs ram to run vista but should ideally have 4 gigs for good operation. vista is a memory hog. You can change the configuration to use less but still need at least 2 gigs
seth
Jun 27, 2009 | HP Pavilion dv6000z Notebook
Computer will not work with extra 1gb ram
It sound like you have incompatible memory. Try taking out the original 256 and test with the 1 gig. Keep in mind some PC requires memory to be paired. If you only have one, 1gig memory chip you might need to get another. I would try removing the 256 first. The specification of the motherboard would also tell you the memory usage.
Let me know if this helps!!
Joe
Mar 25, 2009 | Dell Dimension 1100 PC Desktop
DDR2's only showing half installed RAM
IF THE SYSTEM SAYS YOU HAVE 1GB RAM THAN YOU HAVE 1 GIG OF RAM, EVEN THOU SOMEONE TOLD YOU YOU HAD 2-512MG=1GB.
HERE IS HOW I SEE WHAT YOU ARE SAYING YOU HAVE 2-DDR-2 1 GIG STICKS THAT MEAN IF 1 IS INSTALLED THAN YOU HAVE 1 GB AND IF YOU COULD GET 2 STICKS WORKING TOGETHER THAN YOU WOULD HAVE 2GB RAM.
1 CHIP SET = 1GB RAM
2 CHIP SET = 2GB RAM
YOU MOTHERBOARD MAY NOT ALLOW THAT MUCH RAM, OR WHAT I MEAN THE BIOS MAKE UP THE AMOUNT OF RAM.
TO RULE OUT ANY BAD CHIP SETS OR GOOD RAM OR BAD RAM.
TAKE THE PEACE OF RAM THAT IS WORKING OUT AND REPLACE IT WITH THE OTHER PEACE AND SEE IF IT WILL RUN.
IF IT WORKS THAN LEAVE THAT ONE IN PLACE AND INSTALL THE SECOND PEACE IN THE SECOND SLOT.
IF BOTH CHIP SET ARE GOOD THAN BOTH SHOULD WORK OKAY TOGETHER.
IF THERE IS A PROBLEM, IT MAYBE SOME DUST IN THE MEMORY LOTS
OR THE SLOT MAYBE DAMAGED.
OR
THE CHIP DESIGN LAYOUT MAYBE THE OPPOSITE SIDE, THIS MAY MEANS THE CHIPS MAY FACE EACH OTHER, OR FACE OUTWARD FROM EACH OTHER.
ROD
Mar 14, 2009 | EliteGroup P4M800-M7 Motherboard
Adding memory
chek your laptop first if it can accept the 1gig memory. if so then ask the supplier of your 2 pcs 512 memory to replace with 1 pc. 1gig memory. and also ask assistance to replace it.
Jan 08, 2009 | Toshiba Satellite R25-S3503 Tablet PC
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
More ram for my laptop
Never, NEVER buy a computer that is going to run Vista with less than 1Gig minimum!
2 Gigs of RAM is recommended for Vista.
To check on prices and the type check some online sites that sell memory
Most laptops have a removable door or hatch on the bottom where you can access the memory very easily. The modules easily clip in or out but never use force! (RTFM)
If you take it to someone, they'd probably charge $50 for labour, plus parts and the job takes 5 minutes.
Easily do it yourself, or find a teenager who's good with computers. Son, nephew, neighbour perhaps?
Before buying any new modules, check your laptop to see how many slots you have and what type of modules are in there now.
To upgrade to 2 Gig,  you will have to buy 2 new 1Gig modules, There's a 2Gig kit (1Gigx2) listed at one site for $80.
You would remove you current memory and install the 2 new 1Gig modules. Sell your 512 or make a keychain from it.
Oct 16, 2007 | Lenovo ThinkPad Z61m Notebook
Lenovo 3000 J Series 1.80G VBE PC Desktop Logo
62 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
