Why does my acer pc hard drive show full and not use the other hard drive when it is
    Scholar:
  • 136 Answers
Computers are good at calculus, but dumb as a doorknob.
You should move data manually to the other drive, and keep in mind that a disk cleanup should be performed in a regular basis. Also, NEVER keep your important data in the same drive as the OS, specially if it is from Silicon Valley. If by any chance you have to format, without some hard to come by software, say bye bye gigabytes.
Posted on Oct 14, 2008
Acer Aspire 5002WLMi Laptop won't recognize full 320 Gigabytes of new PATA hard drive. It's always been running a 80 Gigabyte 4200 RPM but that drive is old...a 2005 HD. New WD320 only reads 137...
The BIOS in the ACER determines the maximum size of the hard drive it can support.
Check the laptop's specification to see the max size you can install in this model laptop.
It appears that the max size your laptop can support is 140 Gb (unformatted). 137Gb formatted.
I suggest you install a hard drive up to 140 Gb capacity in your laptop and place the 320 Gb hard drive in an USB hard drive adapter case and when you attach this hard drive to the USB port in your ACER laptop then you will be able to get the full 320 Gb capacity after you delete the partition and create a 320 Gb partition and format the hard drive.
Nov 02, 2011 | Acer Aspire 5002WLMi Notebook
My acer netbook won't go past the welcome. It allows me to pick a user. sign in, but once the welcome shows up it just stays there. I'm afraid my son down loaded too many songs and now it doesn't have...
It sounds like this one is a bit full!
When the hard drives get above 85 to 90% full, everything slows down to a standstill.
If you use your rescue disc to get into your Laptop, remove some of the unwanted files, run CHKDSK and follow the instructions.
Oct 18, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer 5315 HD C is full HD D empty
Very likely the answer is yes, IF: 1) there is enough space and 2) that D drive is not being used for something else. Check on what is on the D drive. It's usually reserved by the manufacturer and contains OS restore files (used for restoring your system after a crash). Don't delete these, but if there is enough free space, just create a new folder and put your files in there.
Jan 31, 2010 | Acer Aspire 5315 Notebook
I have an acer travelmate 4010 laptop with windows xp professional. i recently purchased a wastern digital 320GB hard drive (wd3200beve). when i installed it, windows only sees 137GB. when i take the drive...
Yes. Go to the control panel, adminstrative tools,computer management, disk management. From there you will see the hard drive and be able to expand it to the full 320gb.
Nov 26, 2009 | Acer TravelMate 4010 Notebook
My acer will not pick up the hard drive. It does
If the drive was visible before but is not showing up now, most likely you have had a hard drive crash and will need to replace the drive. You might try taking the drive out and reinstalling it on the outside possibility that you may have a loose connection but, based on the information posted, if the computer is not seeing the drive at all, it will more than likely need to be replaced.
Oct 14, 2009 | Acer Aspire 5100 Notebook
Skipping hard drive
it sounds like your hard drive is getting close to failure
Apr 15, 2009 | Acer Aspire One PC Notebook
My Acer Aspire 5100 Laptop wont detect the hard drive
If it works on another computer then either the ide cable in the acer is bad/loose at either end or the ide controller on the motherboard is bad. I would try a known good ide cable first as if this is the problem it is fixable alot cheaper than a motherboard. Hope this helps.
Mar 27, 2009 | Acer Aspire 5100 Notebook
I have an ACER ASPIRE 5720 laptop - it is less than a year old and it is showing the memory is full - the memory is meant to be 32 GB and from what I can see from the programme menus there is less than 4...
Hi j0shuatsb,
Acer like many other manufactures seem to design their system to fail or have issues just after their 1 year warranty is up. Like other Microsoft windows operating systems, when you receive an error message that you're memory is full. This does not mean you have run out of RAM = memory. You're notebook can only run a max of 4GB of memory. The error message refers to hard disk drive space. Depending on you're operating system, windows will lock out so much drive space so it can move about. All notebooks also have a hidden partition which holds drivers & programs used in combination for running the system restore.
This hidden partition can range in size from 2GB up to 4GB.
This also lessens you're total hard disk drive space. Bottom line is there is nothing wrong with your memory.
What you need is a larger hard disk drive. Notice the Technical specifications from this link:
http://www.acer.co.uk/public/page9.do?sp=page4&dau34.oid=24360&UserCtxParam=0&GroupCtxParam=0&dctx1=17&CountryISOCtxParam=UK&LanguageISOCtxParam=en&ctx3=-1&ctx4=United+Kingdom&crc=512458878
It does not show what size you're SATA hard disk drive is.
Since you are still in warranty, now would be the time to increase you're drive size. On another note, if you're HDD is the standard 160GB than there is an issue with your current HDD.
Please run a full system virus scan.
Suggest you back up all you're personal data on to a DVD & run you're system restore CD including a format to help you regain you're HDD full space. A temporary fix would be to uninstall any non needed programs through Add/Remove programs. This should free up some space. Many Acer programs you do not use at all or need should be the first to go.
Mike
Aug 08, 2008 | Acer Computers & Internet
Hard drive filling up
clear the temp folder and recycled bin
Apr 24, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
