Question about Microsoft Xbox 360 Console
Red lights 2 flashing red ligths
  • 52 Answers
Ok well heres some things NOT to do and see wether you have done these things:
1. Make sure the console sit in an open space with nothing blocking the air from coming in and out.
2. Be careful not to put the console next to a hot item such as stove, radiator etc.
3. From time to time check on it and make sure all the fans are working and that your console does not over heat, if it does you might want to buy some kind of a cooling system.
4. DO NOT put your console outside in the cold weather or in the freezer it might cause even bigger problems!
5. If you still have your warranty now it is a good time to exchange your console for a new one! Don?t wait like I did?
From my experience this should prevent the 2 red lights from coming back and from the appearing of the 3 red lights which means your console need to be repaired!
Posted on Oct 13, 2008
Green ligth comes on and then gose off, proceed by red ligth flashing.
Hi:
If you count the number of times the red light blinks before pausing and starts to cycle over again. This is the error code the unit is producing. Also if its been a while since you replaced the lamp then it may be time for a new one. Check the lamp housing and pull out the lamp it may be shattered. You can find the lamp area and installing instructions using you onwers manual.
Nov 10, 2010 | Sony KDS-50A2000 50" HDTV
The intercom light on my GE 2-9451 phone is flashing between green and red
This is what is in the user manual about the ligth means
Red Someone else is using the line.
Flashing red fast Incoming call.
Green You’re using the line.
Flashing green Line on hold.
Flashing red Line on hold by other stations.
Flashing yellow Incoming call transfer
Dec 18, 2009 | Video Game Consoles & Games
Nintendo charges but doesn't turn on and both screens are ok
whats happening when you connect to a charger? if red ligth flashes that mean you have a blown fuse , if its solid red ligth that mean had a water damage or droppend , you will need to open up and put the loose part on the sopt , usually L1 next to power switch , REgards
Dec 08, 2009 | Nintendo DS Lite Console
Why are the lights around the power button red
this is a fault xbox main website will tell you the fault by the way the ligths flash
Nov 24, 2009 | Microsoft Xbox 360 Console
Dont know what red light is flashing for because ive lost the ins
hello the red ligth is flashing, because to much coffee or u need to clean the machine cleane with sal and liqued soap thanks
Feb 24, 2009 | DeLonghi EAM3200 Espresso & Coffee Maker
4 red ligths on my xbox 360.
The AV cable cannot be detected
THINGS TO TRY
  1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
Jan 18, 2009 | Microsoft Xbox 360 Console
Can you help me with kyocera fs-1030d
If a paper jam occurs while printing, the printer notifies it by the following combination of the four indicators. Remove the
jammed paper . After removal, open and close the top cover once to initialize the jam sensing
Dec 04, 2008 | Kyocera Mita FS-1030D Laser Printer
Exbox 360 4 red ligths
4 red light is a problem with your AV cable.
THINGS TO TRY
  1. Make sure that the AV cable is correctly connected to the xbox 360
    You can also check to see what the error code is yourself if your not sure whats wrong with it.
    To do this, you turn your x-box on, press the Connect button on the console itself and hold it in. Now press the DVD eject button to and look at the lights. it should be flashing 1 light, 2 lights, 3 lights, or 4 lights. grab a piece of paper and write down how many lights are showing. While still holding the connect button, press the eject button again. Write down how many lights are showing again. Then press eject again, and write it down. Then do it one more time and write it down. After you do this, then come back on fixya.com and let me know what error code it is.
    1 Red light = 1
    2 Red lights = 2
    3 Red lights = 3
    4 red lights = 0
    so an example of what you might write down would be:
    0
0
0
which would be 0001.
If you figure out the error, you can also visit the following website and determine what it is and if you can fix it yourself:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Feb 24, 2008 | Microsoft Xbox 360 Console
KDF-60WF655
5 red flashes on your Sony indicates the power supply for lamp is not working .Or 5 pin harness to it is not seated properly.Possibly needs replacement..
Aug 01, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
