Question about Sony DVP-PQ2 Portable DVD
Sony DVP-PQ2 problem
I have a Sony PVP-PQ2 player. I took out one disc and replaced it with another. The player then stopped reading the disc. It acknowledges that there's a disc present, but instead of spinning round (I can see it's not through its little window), it just makes a brushing sound like the disc's being read accompanied by occasional clicking sounds.
  • Jamie1976 Oct 13, 2008
    It does do it on every disc. It also happened instantaneously and has not got progressively worse.
    Is it cost-effective to try to fix it, or is it essentiallythe death knell!?
  • Jamie1976 Oct 14, 2008
    I'm afraid not!
  • 661 Answers
Does it do this with every disk?
it could be one of several things, with some of these drives it uses a friction wheel at the center of the disk to "spin" the disk, this uses a circular rubber traction disk to grip the disk on both sides and then spins the disk using this traction, ( if the rubber there is not good it will not work well)
the other kind of spindle is a press on spindle which has a spring loaded grip mechanism where the disk is clipped onto the spindle,
the other issue is that you may have a driveband failure, this basically a rubber band which drives the main drivewheel from the drive motor, these can wear out or perish.
lastly, it could be a bad/burned out drive motor,
all of these issues can be fixed by the manufacturer and some of these can be fixed relatively easy by the user if the unit is out of warranty
Posted on Oct 13, 2008
  • Gareth Cockram
    Gareth Cockram Oct 14, 2008
    is it in warranty?
  • Gareth Cockram
    Gareth Cockram Oct 15, 2008
    it depends on whether it is the snap on spindle or the friction spindle.
    if it is a friction spindle it may just be that the rubber grip has lost traction on the disks
    I think you can get a "stick on" replacement, or some cleaning spray to revitalise it
    if it is the snap on kind, then you will need to see if you can replace the drive band (which means opening it up) the drive band is just an elastic band, it may just have perished.
I have a remote for sony tv RM-Y167 and need to program sony DVP-S530D CD/DVD player code
Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Jun 21, 2014 | Sony DVP-PQ2 Portable DVD
My Sony DVP-CX777ES player just opens and closes several times upon powering up. Then it stops and I get an error message that reads "C 32 00." Then it turns off.
Please check door mechanism as explained in chat session and possibly loading belt and/or door switches could be culprit and causing problem.
Hope this will help.
Thanks.
Mar 13, 2011 | Sony DVP-CX777ES Multi-disc DVD Player
We have a DVP FX 875 and the disc spins but it has just stopped playing/reading the disc - any disc! Is this fixable?
Yes, it is fixable, replace optical laser block of DVP-FX875 to solve its issue.
Let me know if you need part number of optical laser block or contact local tv repair shop for replacement.
Thanks.
Oct 31, 2010 | Sony Televison & Video
Sony DVP-CX995V "cannot play"
you can clean the motor by the back side
Oct 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
Sony DVP-PQ2 Portable DVD Logo
113 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
