Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Refrigerator Problem Hi Coolguy8, You had responded to me about the refrigerator problem--Unplug for 30 minutes to reset and it fixed the peoblem for 48 hours and is back. Any ideas on a more permanent solution? Thanks. NJ
    Genius:
  • 3,422 Answers
HI,
I suggest you to repeat the same process again.If the problem comes back again after 48 hours then start checking your defrost heater and defrost thermostat, you will need a volt/ohm meter.This process will require to remove the back panel to troubleshoot.The best solution is to get this repaired.
Posted on Oct 13, 2008
How do I fix my refrigerqtor hotpoint double door not defrostiong
Generally, if you unplug the refrigerator and set the freezer and refrigerator temperature controls to off then plug it back it, this will put the refrigerator in forced defrost mode. Keep the doors closed and allow defrosting to last for about 20 minutes. Then unplug again and reset the temperature controls to mid-range or a little above, and plug it back in. If this does not reset the defrost cycle, you probably need service.
Mar 07, 2015 | Hotpoint Refrigerators
Reset Water Filter Button; Stays Red after changing filter on Frigidaire Refrigerator/SideBySide LGUS2642L
Thank you for your inquiry, John Sodt!
From what you have described your Frigidaire refrigerator's filter display is not changing back to green after the filter has been changed. This could be a miscommunication within the control panel and to clear out any miscommunications I would suggest performing a reset on your refrigerator. The best way to reset your refrigerator is to unplug the power cord for roughly ten minutes. If that does not help your issue you may want to speak with a professional technician. Good luck. -Matt
Feb 11, 2015 | Frigidaire Refrigerators
Is there a reset button or internal circuit breaker on sears refridgerator model # 795,7830
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There is not internal circuit breaker or fuse in a refrigerator.
Component failure acts as the fuse.
There is a reset button on the control panel of your refrigerator.
It is a small black button. Located near where the part number is shown on the board. This is rarely the solution to a problem.
You may try to unplug your refrigerator for 30 minutes and reboot your refrigerator.
In your owners manual, it is recommended to install a surge protector. They are a good investment for $20-25.00. Static electricity, the slightest change in voltage and a magnetic field will knock out a electrical control board.
If you elect to press the control board reset button make sure you ground yourself by rubbing your hands on something that is steel.
25134658-bkvywf5rc1reqors4q4ptmqv-4-0.jpg 25134658-bkvywf5rc1reqors4q4ptmqv-4-3.jpg
Sep 24, 2014 | GE Refridgerator Relay Overload Wr07x10011
My frigde is beeping consecutively and wont stop and the temperature wont show it just doesnt work ever since the electricity flickered this morning like five times
Hi and welcome to FixYa, I am Kelly.
Unplug it and wait 20 - 30 minutes. The compresor needs 10 to 15 minuts of off time to re-start. Power losses of less than 5 minutes will cause the compressor thermal overload to cycle repeatedly until something fails or in the case of non-electronic control defrost timers... the next defrost cycle. What happens is the coolant pressures are so high that the compressor can not start. Let it stabilize for 20 - 30 minutes by unplugging it and try it again. If that does NOT work respond here and we will help you.
This is what caused your problem: ever since the electricity flickered this morning like five times
Thanks for choosing FixYa,
Kelly
May 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
None of the conrtol buttons on the Electronic Triple-Cool System respond when you push them. It seems like it is frozen (no pun intended) or locked up. Therefore we are not able to adjust the...
Unplug the refrigerator for 10 minutes then plug back in.Reset controls to your liking. If that doesn't help, you may need a visit from a technician.
Sep 26, 2017 | Maytag MBF2262HE Bottom Freezer...
Runs and cools to desired temperature for 2-30
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 11, 2010 | Jenn-Air JFC2089HE French Door...
Refrigerator Door Does not Close Properly
Try a hard reset. Just unplug the power cord for 30 minutes or more, then try again.
May 14, 2009 | Maytag MSD2756G Side by Side Refrigerator
Satellite receiver not responding
reset the receiver again and try if its responding again
Feb 06, 2009 | JVC SIRIUS Satellite Radio Interface for...
"Lock" light came on and I don't know how to turn it off.
first press and hold the lock button for about five seconds. If that doesn't help unplug the refrigerator for about 30 minutes. It may be that you have an electronc gliche then and if you break the circuit by unplugging the refrigerator (you can also trip the circuit breaker that controls the refrigerator, if that is more accessible than the plug) it should reset. if not you may have a more serious problem with an electronic control. Good luck, hope this helps.
Jan 16, 2009 | Jenn-Air JCD2290HES Side by Side...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
