Question about Vacuums
Oreck carpet cleaner not dispensing water
My oreck carpet cleaner is not dispensing water. i replaced the water pump and it is still not sucking water from the main jug of water. it trickles out but nothing serious.
  • Anonymous Nov 11, 2008
    i have the same problem, just trickling of water but not dispensing
  • cindi942 Jan 05, 2009
    I have the same problem. I have cleaned the whole cleaner but the water just comes out in little trickles.
5 Suggested Answers
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: hoover will not suck carpet shampooer
no solution, hoover is by far the most rediculous machinery... it says its as easy as filling it up and using it as a vacuum.. but it doesnt show how the hell you fill it up, there are two possible places where water and solution obviously enters and leaves... yet niether of them open up for fluids to be put in
and of course the instructions dont tell you how to fill it up
no wonder it has only a 30 day money back "guarentee"
because it takes 30 days for the buyer to realize that it doesnt work
so you can spend 300 on this faulty product.. or spend 300 on something that wont infieriate you
have fun
Posted on Jul 24, 2008
SOURCE: Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Posted on Sep 20, 2008
SOURCE: not sucking up water
Hi.  I had the same problem.  After looking at the manual I went back and made sure the canister was making a proper seal.  That fixed the problem.  Make sure when you put the top back on the canister (that holds the dirty water), that you place the two front hinges in  place first and then snap the center clap on the back of the top.  This will give you a proper seal for suction. (My two front hinges weren't fitting correctly.)
Posted on Oct 26, 2008
SOURCE: 9200 Bissell carpet cleaner, water will NOT dispense
The water or soap line might be clogged, or something is broken. If it is just the upright part and not the handle, then its a solenoid, if its both then either the pump motor or the pump is not working.
Here is a list of parts.
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
Hope this helps.
Posted on Jan 08, 2009
My oreck steemer carpet cleaner xls465q wont dispense water or shampoo
You seem to have a clog in your pump. It is possible that left over soap and minerals from your water have brought your machine to a stop. I would go into the pump it self , and clean out any obstructions, then check all your feed lines for the same. I believe that going into your pump and cleaning inside will solve your problem. Take your time. GOOD LUCK FRIEND.
Jan 10, 2015 | Oreck Vacuums
Bissell proheat turbo 2x carpet cleaner
There should be 2 switches one for suction and one to disperse detergent.
Aug 15, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
Oreck carpet cleaner wont **** up water
Your reservoir is full. Empty the water and it will work properly.
Feb 20, 2013 | Oreck XL Shield Power Scrubber Floor And...
Instruction manual for hoover swish carpet cleaner
my hoover swish dosent seem to **** up much of the water out of the carpet carpet is still quite wet and bot much water is sucked up for the amount of water that goes in the water dispenser
Nov 26, 2010 | Vacuums
The Bissell won't spray any carpet cleaner but it is still sucking up water.
If it doesn't dispense water then that means that you need to replace the pump belt. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 27, 2009 | Bissell 1699 ProHeat Clear View Upright...
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do you clean out the SteamVac...for example..the area where the water is sucked back through is very dirty...where it is visible from the outside
The easiest way is to rake the debris out with a piece of wire. More difficult, but better, is to remove the screws that hold the "wondow" on and clean. Some disassembly required! We see a lot of posts for cleaners that are stopped up. I know you didn't ask, but it's a really, really good idea to run a tankful of just plain hot water through the main dispenser and the attachment dispenser before you put the machine away. It will keep your dispensing lines free of soap that will plug it up, and cleans the soap out of the pickup side as well.
--W/D--
Aug 08, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Will not dispense soap from handle
The soap dispenser, on the side, make sure the seal is on the bottom of it and not in the hole. You may have to replace the valve asm for the dispenser part # 2101795
Sep 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
273 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
