MPA-101 Amplifier powers on, receives source signal, the fuse is not blown inside, but no sound comes out of the amplifier. The amp is pretty new, doesn't even have dust inside the unit.
  • daroll19 Oct 14, 2008
    This is a Jamo amp that I am trying to use to power a passive subwoofer. It powers on, the LED in the front remains constant, as the manual states it should from it knowing it has a signal, but no power output in Stereo or Mono Modes. (The LED is NOT red, but Blue.) I was guessing some internal problem, but I am not technicial by any stretch. Thanks for the response. daroll19
    And literally, to state it again, the amp looks un-used in its appearance.
  • jacobsenlc Dec 16, 2008
    I have the same exact problem with TWO MPA-101 Amps.
    L Jacobsen
    Scholar:
  • 142 Answers
Hello, is this a Radio Shack PA amp or Jamo amp? The unit is probably in "Protect" mode. Is this a PA system or a receiver...receivers have a protection circuit that will not let the speaker relay activate if the amplifier output section is shorted and sending voltage towards the speakers...so they won't fry!!The speaker relay should activate within 3 to 5 seconds if your output section is ok.
barneyluc
Posted on Oct 14, 2008
Power light on but no sound/bass? I have 2 10" 1000 watts jbl sub. i bought this amp from somebody. it came with a 25 fuse, do i need to have 30 for it to work or it doesn't matter?
I would check the subs for resistance. If the Voice Coil of the subs shows an Open Circuit, your subs are blown. It is possible that the wiring inside the box has come loose, or the wiring from the amplifier to your sub box is loose or disconnected. I would then check the RCA or signal wires from the Head Unit to the Amplifier. The fuse is fine, and wouldn't make a difference in your situation.
May 17, 2011 | Soundstream XTA880.2 Car Audio Amplifier
Where on my mixer should I plug the subwoofer into? Or would plugging it in somewhere else be better ?
This will depend on whether your sub-woofer is powered (has it's own built in amplifier) or not. If it is not powered it will need connecting to an amplifier. If it is powered you will need a line level output either on the amp or the mixer.
Many modern amplifiers (and some mixers) have a dedicated output for sub-woofers in which case this is the best place for it because the higher frequencies will have been filtered out.
Some high quality amplifiers like the JAMO MPA 101 have a filter switch and adjustable filter level for powering sub-woofers. You then just connect the speaker to the speaker terminals in the normal way.
Otherwise on a p.a. mixer you could use the main output, one of the auxiliary, monitor or sub-mix outputs. If you are not using the main output you will need to route signal to the appropriate output accordingly. Either way your output signal will cover the full frequency range - your subwoofer may have built in filtering or you may need to use some sort of crossover to split the signal between the sub-woofer and the rest of your speaker system.
Feb 25, 2011 | Audio Players & Recorders
Alpine MRP-T220 car amp. When I turn on the JVC stereo, the amp plays for a split second then dies. The power light stays on, and the fuses from the battery and the amp are fine. It always worked...
Yes your amplifier is stable @ 2OHM but only in stereo mode. If you are running the amplifier in BRIDGE mode then the amplifier is stable only @ 4OHM. So if you are running a sub woofer and it requires a 2 Ohm mono load then the amplifier has either been damaged or is trying to protect itself from the wrong OHM load. You could also make sure that your GND is secured properly, as some times it could come lose from vibration and not offer a decent ground for the system. dreamsystems.
Feb 21, 2011 | Alpine MRP-T220 Car Audio Amplifier
It turns on,everything works normal and sound even comes out of the headphone jack.but there is no signal coming out of the speaker jacks.no sound or test tone
Hi depending on the design some receivers , when you plug in headphones, speaker sound is disconnected by the headphone socket so it could be faulty, or there may be a separate switch to switch of the speakers, (while using headphones) if so that switch could be suspect. I dont think the amplifier part of the receiver is at fault as you say you can hear sound at the headphones. It is not impossible though that a fuse has blown inside the amp, If you unplug from mains and look inside you may spot a blown fuse , (only replace with one of the same rating).
Hope this helps
pete
Nov 14, 2010 | Teac AG-V8060 Receiver
I'm replacing a JAMO amp.
The 201 is 100w in to 4ohms and the 101 is 50w into 4 ohms other then that there the same
Mar 24, 2010 | Jamo MPA201 2-Channel Amplifier
Jamo MPA-101 2 channel amp quit working
Check the small electrolytics on the power supply board for high ESR, Very common problem on these amps. Protect circuit stays latched due to high ripple from PS.
Mar 24, 2009 | Jamo MPA201 2-Channel Amplifier
Two Jamo MPA-101 amps not working
I can almost guarantee that you'll find bad electrolytic caps on the power supply board to be the cause of the problem. I've seen several of these with the same problem. The protect circuit stays latched due to excessive ripple.
Dec 16, 2008 | Jamo MPA201 2-Channel Amplifier
Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
Subwoofers not getting music
looks like you need to check the SOURCE of where the signal is coming it could be that your CD car stereo SUB opt. is turn off , check the menu of SOURCE and switch to SUB on , hope this helpful
Apr 28, 2008 | Kenwood KAC-9152D Car Audio Amplifier
How do i know if my amp is blown
Hey Yoo,
Go to Radio shack and get you an adapter that will take an earphone jack and convert it to RCA male.  You use this to simulate the signal coming from the reciever.  Hook up to a Cd player or Walkman, anything with an earphone output jack. Test that the device actually puts out music or anything worth listening to.  Connect the device to the input of your amp, with the car running, and the reciever turned on.. This will tell yo if the signal is getting from the reciever to the amp. You may not be getting signal from the head unit.
If you still get no sound to the woofers, dsisconnect the woofers and try a different speaker.  If that speaker dont work,  Change setting and switches., and if you still get no sound, then your amp is toast.
Oct 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
393 people viewed this question
 Grubhead
Grubhead
