Question about Matsonic MS7308E (MBMS7308E) Motherboard
Motherboard driver is wiped out
The system was working fine, then I tried to reboot the system with Microsoft XP Service Pack 2. The system works fine in safe mode will not
start up regularly. It freezes when it gets to the screen where the little dots run across the screen to start.
    Genius:
  • 1,124 Answers
Run checkdisk
Start >> Run >> cmd >> CHKDSK
Then try Save mode again
Posted on Oct 13, 2008
USB 2.x driver
USB 2.x driver is inculded in windows XP service pack 2.
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=049c9dbe-3b8e-4f30-8245-9e368d3cdb5a
If that doesnt help try looking for drivers either on the cd that came with your motherboard, or your motherboard manafacturers website.
Mar 09, 2011 | Computers & Internet
Prob
what windows did you install (xp service pack 1 or service pack 2). becouse service pack 1 doesn't fully support all the usb port types.
Jun 16, 2009 | Intel D845GVSR Motherboard
Have windows xp service pack 3 loaded don't have sound
Goto Start, Control Panel, add or remove programs. Uninstall the sound card drivers. Reload the Sound card drivers from your Setup CD. Every thing should work fine then. When you load SP3 some of the drivers get corrupted (lost).
Jun 08, 2009 | Microsoft Windows XP Professional With...
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
Restarts computer in loop at 5-8 minutes of boot
Please try install XP SP3 in safe mode. Then check whether you have the latest Graphics Card Driver. It seems like some driver issue as it reboots only in Normal mode. Since safe mode runs on minimalset of hardware drivers.
Secondly, there may be a corrupt file that caused reboot. Spend a night and schedule bad sector check - Right click on system drive, Tools tab, Error Checking -> Check Now, tick both boxes then Start. It will schedule scan on next reboot. Then reboot to confirm it starts checking HD.
Apr 24, 2009 | Microsoft Windows XP Professional With...
Reinstalled xp after Vista . USB port not working
The usb drivers are part of your chipset drivers, so lets try and get this sorted. The reason that they work in Vista, is probably because Vista has added support for your chipset and XP SP2 doesn't.
Try installing XP from scratch. First you need to completely wipe your hard drive. Use the XP boot disc, you need to delete the hard drive partition as well. This way, you will start with a RAW drive.
Set up a new partition, and let the XP disc format the drive with NTFS. Do NOT use quick format. Then let XP copy the files and install.
When XP has installed, get your internet set up, and download XP Service Pack 3 from Microsoft:
http://www.microsoft.com/downloads/details.aspx?FamilyID=5b33b5a8-5e76-401f-be08-1e1555d4f3d4&DisplayLang=en
You will notice that Microsoft have written not to use if updating just one machine. Ignore this. The reason is because this is the FULL Service Pack, hence it being over 300MB.
Once you have SP3 installed, your system will restart. Open Windows Update, make sure you have this set to update all Microsoft products, then download all updates. Restart your system and check if your usb's are working.
If they are still not working, go to the laptop website and download the chipset drivers from there, but make sure you are downloading the drivers for XP. If not, then go to the Chipset manufacturer's website and download from there.
Let me know how you get on
Tim
Dec 19, 2008 | Computers & Internet
Sound solution plz
goto control panel switch to classic view , double click add remove programs , then when the list comes up look for service pack2 and remove , then restart computer
Oct 25, 2008 | ASUS P5VD2-MX SE Motherboard
Problem with Sound Dirver
try innstall the latest drivers
http://www.realtek.com.tw/products/productsView.aspx?Langid=1&PNid=8&PFid=8&Level=2&Conn=1
Aug 19, 2008 | Matsonic MS9127C Motherboard
Failure in installing realtek Hd Audio driver
remove the space and the link will work.
http://www.bram.us/2008/08/20/fix-to-the-hd-audio-bus-driver-failed-to-load -0xe0000227-realtek-high-definition-audio-driver-install-has-failed-errors/
Aug 09, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
79 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
aravind shet
aravind shet
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
