Question about HP Compaq Business d530 Ultra-Slim PC Desktop
Switching power option blew a fuse!!!??
My kids switched the power selection switch from 115 to 240 v and something went pop in the box. What can I do?
  • Jeff Strader
    Jeff Strader May 11, 2010
    more than likely the protection capacitors in the power suppy have burst, this is designed to happen to protect the rest of the system in the event of a surge.
    You will pay someone more than what the power supply is worth to fix it.
    you can order one here or somewhere similar for about 60 dollar plus shipping..
    HP asks about 100 for the HP brand of this power supply.
  • 68 Answers
You can find power supplies online (newegg or tigerdirect) for less than $40, sometimes with free shipping. I would guess that is the problem. Hopefully the power supply went out and it didn't ruin the motherboard.
Posted on Dec 05, 2008
My Emerson Microwave MW9117W has lost power and was wondering if there was a fuse or something that needed replacing
There are fuses inside. The big thing is to figure out why the fuse went bad. either something shorted and blew the fuse, or it got hot and went bad due to bad connections at fuse holder. or maybe a bad door switch blew the fuse. I have also had fuses just get old and tired., and just needed to be replaced.
Aug 19, 2017 | Emerson Microwave Ovens
How to reset electric box after vacuum cleaner blew power out
One of your circuit breakers is tripped internally and didn't trip the handle. You'll need a voltmeter to find the defective breaker and replace it.
Aug 22, 2014 | Electrical Supplies
1999 Crown turned ignition switch to start - heard pop - no electrical power
If nothing works including the lights, something happened between the battery and the fuse box.
There are some fuseable links between the battery and the starter solenoid or between the solenoid and the fuse box.
I'd start with the battery cables and look for those fuseable link wires.
Jul 09, 2012 | 1999 Ford Crown Victoria
My radio, wipers, power windows, and heating cooling switches all went out at the same time. i think it may be a relay? what else could be the problem?
It sounds like a fuse more than a relay. Check 'em; they look bad, blown. Correspondingly, replace fuses with gloves on, because you don't want it to scorch your fingers if the short's still there. Did you let a kid with a screwdriver check out the fusebox in the cabin? In that case it'd just be kind of missing. Still...something blew the fuse, right? Unless it was raining saltwater, there might be a wire or cable in a bad way, which would need some cleaning, restraint and electrical tape.
Sep 13, 2011 | 2000 Pontiac Grand Prix
The machine has just stopped working, none of the buttons work. Tried switching on and off please
sound like you blew a fuse. There is a little fuse box next to the on/off switch. You can buy new fuses at Hope that helps!
Jun 26, 2011 | Lavazza Espresso Point Capsule Machine
User Id
Enable or Disable Fast User Switching Note: To enable Fast User Switching, you must also enable the Use the Welcome screen option. This feature cannot be used if your computer is a member of a domain. To enable Fast User Switching:
  1. Log on to the computer as an administrator.
  2. Click Start, click Control Panel, and then click User Accounts.
  3. Click Change the way users log on or off.
  4. If it is not already selected, click to select the Use the Welcome screen check box.
    NOTE: The Use Fast User Switching check box is unavailable until you click to select the Use the Welcome screen check box.
  5. Click to select the Use Fast User Switching check box, and then click Apply Options. Quit the User Accounts tool.
Please don't forget to rate this solution.
Jun 15, 2009 | Dell Latitude C610 Notebook
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
HP Compaq Business d530 Ultra-Slim PC Desktop Logo
80 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
