Question about Zenith D65W25 TV
Plexiglass "screen" cracked
The outermost clear plexiglass screen of my Zenith D65W25 projection tv was cracked, the victim of an ill-placed doorknob during a move. The tv still works fine but just has a large, annoying crack in the screen. I am having difficulty finding a replacement screen for this unit without purchasing an entire screen unit for over $800. Are there any suppliers who can provide just the outer screen?
  • Zenith Master
  • 2,088 Answers
First, a warning. There is at least one website appearing to sell TV Screen Protectors but if you research the site, you discover that the Yellow Pages indicates that the business has closed. In that instance, I would probably call the Better Business Bureau in that area before I would even test any contact point on that webpage. It might be legitimate but there is sufficient reason to be cautious. Alternatively:
Sears carries Zennith parts:
http://www.searspartsdirect.com/partsdirect/brands-products/Zenith-Parts/Television-Parts
Posted on Aug 11, 2017
5 Suggested Answers
jomaru
  • 337 Answers
SOURCE: Screen goes from blurry to clear to blurry
The first thing to check is for loose conections,the problem is related to the high voltage but it can start in the main board with one component loose,when the high voltage is developed it goes to what is call the distributor block,a lot of sets have the focus and screen controls coming out of this block for each picture tube,this block might be bad but before we go to him we need to check everything is solid in the main board.If you are familiar with electronics you can remove the back cover and tap the chassis with a wooden or rubber handle to see if the set reacts,if it does you need to be atentive what area makes it react and flip the board to do some resoldering,If you are not too familiar with tv service you need the assistance from a servicer.Let Us know how it goes or if you need more information.
Posted on Oct 27, 2006
Benimur
  • 6966 Answers
SOURCE: Zenith A25A11D No Red Color
Hi, If you are comfortable working with a soldering iron, a continuity (VOM) multi tester and a fair knowledge of electronic components, then perhaps you can repair the missing color red. You have to open the unit, expose the small printed circuit board that is attached to the small end of the picture tube. There will be many components present but you will need to focus yourself on three (3) transistors that are bigger than the others sometimes with an aluminum heatsink. It is also possible that instead of 3 transistors you will have one power IC. In any case these control and provide the drive for the 3 colors of your picture tube: red, green and blue. One of them is either dead or suffers from cold solder to any or all of its pins/legs. You have to visually inspect the solder joints of these big transistors/IC and determine if any is dull in color, loose of simply not connected. You may even try the shotgun approach and solder each of the pins/terminals/legs just as long as you don't cross solder creating a short between pins/legs. If this works, you're set, if not: You have to check with the use of the VOM and determine which of the 3 transistor is defective. If you are familiar checking continuity of base to collector to emitter and reverse, again you're set, if not perhaps you check all three and compare which have the same reading from the same position and which is different. Pls keep in mind the transistors have forward and reverse bias readings. If able to determine defective component, desolder, replace and solder. If it were an IC, replace the entire pack. If the above would make you uncomfortable, pls ask for the services of a qualified TV repair man and explain your problem. Hope this works out for you and give you some ideas. Pls post again how things turn up, good luck and kind regards.
Posted on Aug 12, 2007
SOURCE: Zenith rear projection TV
it's unual for all 3 crt's to go bad at same time, so have you tried turning up screen(G2) control? If so also there is a cap in the high voltage line that when replaced may lighten up set. Don't have model so I can't go further.
Rifaa
  • 99 Answers
SOURCE: High pitch buzzing.
Hi there
Let's make ur problem a bit clear. "white lines" how? where?
meaning retrace lines with full raster or a single vertical line?
buzzing sound? without even turning the power switch of the TV to "ON" or when u just plug the power cord?
I'll check for schema, mean while can u tell me where the resistor leads to? is it a fusible resistor? if so , to which area the resistor suppliers power?
Regards
Rifaa
Posted on Nov 12, 2008
Broken front plexiglass rca 52 inch tv
Hello
Contact the nearest authorised service center for RCA at your town.
Mar 06, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Kids playing Wii cracked what appears to be plexiglass screen. Can I just unscrew frame and replace with piece of plexiglass cut to size?
If its just the clear outer screen you can, But the lenticular screen layer and Diffuser layer are special items.
Jun 24, 2011 | Sony KP-51HW40 51" Rear Projection...
How do i replace the plexiglass on the 65in hitachi, it was cracked while moving. Also where can i buy the plexiglass to replace the cracked one
According to Sears Parts Distribution, the panel (which unfortunately is not a piece of plexiglass) can be purchased at this website:
http://www.searspartsdirect.com/partsdirect/part-model/Hitachi-Parts/Television-Parts/Model-65S500/0505/0333200/50022581/00001?blt=06&prst=&shdMod=
at a price of $468.15
It may be worth investing perhaps in a new Mitsubishi DLP, which can cost as little as $999 at places like Costco. Though I did read that your particular TV has an excellent picture.
Jan 21, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
Where can i get a plexiglass screen?
I have a P46921 46 in rear projection television. I brought it in and they told me it was the processor board (main control board with programming) that wasn't letting the TV turn on and was quite an expensive repair. I now have the parts back and was wondering if someone could use them. I know that some people were looking for the actual screen found behind the plexiglass or what looks like plexiglass. I have all the parts and was told that it worked beautifully until it decided it wouldn't turn on again. Anyone interested, please drop me an email at jforest7@gmail.com.
Thanks.
Oct 11, 2010 | RCA P46921 46" Rear Projection Television
Broken plexiglass screen
If your TV is anything like mine (which I expect it is, since they’re the same brand), all you have to do is use a T-20 screwdriver bit to remove all the screws from the back of the frame around the plexiglass. Once the screws are out, the frame just pops up and the plexiglass is easily removable.
Mar 20, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" plixyglass is cracked can i fix it easily and how much does
yes i believe you can.is there a screen behind the plexiglass?
Jan 12, 2009 | Philips 60P8341 60" Rear Projection...
Model 6p6030 w101
Some projection sets have a screen Protector ( plexiglass) along with two other sceens that can cost alot!...
Jun 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Cracked cover D52W19
i have used plexiglass for customers in the past. it has work just fine. rca call this thing supersheild and charges about 200 dollars.
Jan 12, 2008 | RCA D52W19 52" Rear Projection Television
Zenith D65W25 TV Logo
51 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
