Question about LG Goldstar SP-110 Cellular Phone
LG CE110 phone issues
We have a phone that no longer allows us to call voicemail and erase messages or make automated calls where you have to push buttons to access things. In other words, when we are on the phone, we cannot use the keypad. How do we reset it so that the keypad will work while on a call?
4 Suggested Answers
SOURCE: i want to change the # to access my voicemail
Go to Main menu, then "Messaging". Within Messaging go down to "Message Settings". #3 is voicemail. click voicemail and you will be able to edit the number.
Posted on Oct 17, 2008
  • 15 Answers
SOURCE: Does the LG CE110 have a voicemail alert? I know
hi
all the models has voice mail service provided that is enabled by operator
thx
Posted on May 14, 2009
SOURCE: Accessing Voicemail on LG KS360?
I had the same problem and I read the post from
Z1G ZA9, and that solved my problem. To give you step by step, because i had to search thru the fone and find the DTMF option, so here it is, and again a big thanks to Z1G ZA9. 1.press menu button 2.select "settings" 3.select "call" 4.scroll to bottom and select "send dtmf tones" and make sure they are on.
Posted on May 29, 2009
How do I set up voice mail
How to record a voicemail
    1)Call your Voicemail access number, or press its corresponding shortcut key (usually the number "1").
    2)Press the key corresponding to "set your voicemail greeting" or "Set up your voicemail."
    3)Decide whether you want to use an automated greeting, which usually gives out your number and advises callers that you're not available.
    4)Follow the prompts to record and save your greeting.
How to Record Voicemail Message on LG Phones
Nov 20, 2015 | LG Cell Phones
How to make voicemail to text message
Assuming that the you want to have voicemail messages automatically transcribed and either emailed or SMS/Texted to you so you can read them...
First, you would need to get the audio of the message to either an automated or human powered transcription service. Since none of the cellular carriers' voicemail systems are capable of that, the other option is to have unanswered calls diverted to a voicemail system that is capable of delivering an audio file via email. Fortunately, all of the major carriers (including AT&T in your case) offer call forward busy/no answer at no charge.
Once you have liberated the message from the grip of the cellular carrier, you then need to find a service provider that can receive the audio file, rapidly transcribe it, then email and/or text it to the destination(s) you desire.
Automated transcription is generally faster -maybe a couple of minutes- and cheaper -free to a few cents per message- but the accuracy can be laughable. Human powered transcription is a bit slower -maybe 5 to 10 minutes for the average message- and more expensive -maybe $0.20 to $0.50 for the average message-, but the accuracy is reliable.
GoogleVoice is a good example for the automated/free option.
www.TalkScribe.com is a good example for the human powered option.
Aug 15, 2012 | AT&T LG CU720 Cell Phone - Silver
Lg ce110. display lights up, I can search all the menus, It will emit the ringtone if I put it in set mode. However, I can not here any voicemails or calls. The audio seems to be dead except for...
Hello and thank you for your question,
It seems your voicemail has been disabled. Please contact your cellphone provider so they can re-enable this feature.
Please remember to rate this answer for your ratings help me better serve you and the community of others like you needing help.
Once again thank you for you for using Fixya.com and for all your technological needs please continue to use fixya.com where you will find the answers that Fixya problems.
Sincerely,
Zachery D.
Fixya.com - Guru: zdeuyo
Mar 28, 2011 | LG CE110 Cellular Phone
No longer rceiving voicemail
If you are getting the "voicemail does not exist message" when testing your voicemail by calling yourself, this means that the voicemail feature is not on your account. Unfortunately you will have to contact your service provider and ask them to add the voicemail feature back onto you account. Have them test and make sure that you can access the voicemail before they end the call to ensure they have fixed the problem. Hope this helped.
Feb 02, 2010 | LG CE110 Cellular Phone
Incoming calls does not connect to voice mail, you get a busy sign instead. What is the problem?
Call your local carrier as your voice mail feature may need to be reset. If you have any current saved messages write down the info as the reset may or may not cause them to be erased.Best of Luck.
Nov 10, 2009 | LG CE110 Cellular Phone
My LG CE110 phone has dropped and the screen no longer works. The phone itself does though. I need step by step instructions on what buttons to push to copy my contacts from my phone to my sim so that I...
I suggest you take the phone to your cell phone provider. You might get lucky and they have that model (or a close model) in the store. Then you can see what buttons to hit.
Nov 04, 2009 | LG CE110 Cellular Phone
How do I set up an answer phone message on my LG KP500 phone? The manual that came with it doesn't mention ANYTHING about answer phone messages and I must have tried every single combination of buttons and...
Depending on your service provider you'll have to call your own voicemail number, usually different than your cell number and the automated system will prompt you to set up your voicemail. In many cases speed dial has been set up for your voicemail. The way to get there is simply press and hold the (1) key and the phone will "speed dial" it for you. Good luck
Oct 16, 2009 | Cell Phones
Inability to leave voicemail
call your carrier and make sure that the voicemail numbers are good.
Aug 29, 2009 | Lands Phones
hi
thx
May 14, 2009 | LG CE110 Cellular Phone
Turning off answering machine
Hi
you cannot retrieve messages off the voicemail system I am afraid. If this is down to malicious calls and police are involved speak to O2 as they may have a way to supply evidence direct to police?
Regarding turning off voicemail here are the codes you need, dial 1750 to activate voicemail, 1760 to deactivate voicemail, 901 is used to call in and listen to voicemail and additional options i.e. greeting, pin etc.
WARNING! By turning off voicemail you will ERASE any messages in your voicemail as it resets each time deactivated! So only do this is messages are no longer required!
Hope that helps?
Apr 26, 2009 | O2 X2i Cellular Phone
LG Goldstar SP-110 Cellular Phone Logo
22 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
