Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
  • 749 Answers
Slave is NO jumpers at all
(Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
(Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
(Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
(Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
Posted on Oct 13, 2008
Maxtor hard drive settings for a 53073H4
Before doing anything, the user should completely shut down and unplug the computer to prevent electrocution or computer damage. Remove the computer's side panel so that the hard drive is displayed in order to find the jumpers on the IDE drive. Disconnect the power and IDE cables from the hard drive to access the drive better. The hard drive's jumpers are the small, black pegs on the back of the drive. These pegs fit over small metal conductors and assign the IDE drive's role. The user can remove the jumpers by prying them off of their current conductors with his/her fingernails or a small screwdriver. The jumpers can then be relocated to other conductors in order to assign a role to the IDE drive. The user should be very careful while handling the Maxtor jumpers as they are fragile and very important.maxtor-jumper-settings.jpegEach IDE drive model is different but most have three basic settings: Cable Select, Master, and Slave. Each setting is described below.
Cable Select
Cable Select is a Maxtor jumper setting that is the default for virtually all IDE drives. Cable Select allows an IDE drive to naturally become either a Master or Slave depending on the cable used. Cable Select is a neutral setting and is also often used when a user only has one IDE device installed or when a device is neither a Master or a Slave, such as a Floppy Disk drive.
hope this helps
Jun 22, 2012 | Maxtor Hard Drive
What settings in the bios with maxtor as slve and quantom fireball as master
There are no settings in the BIOS for setting up master ans slave drives.
The hard drives have jumpers for configuring master and Slave drives.
If your hard drives are IDE/PATA hard drives and you intend to install these drives on the same IDE cable then you can set the jumper on Quantum drive as Master and the Maxtor on Slave.
I suggest that you install the Quantum as master on the 1st IDE cable and the Maxtor as Master on the 2nd IDE cable for maximum data transfer rate between the two hard drived.
Any other devices that are connected to these IDE cables will need to be jumpered as Slave devices.
Mar 28, 2012 | Gateway Computers & Internet
Model 34098H4
This FAQ applies to Maxtor model numbers: 31024H1, 31535H2, 32049H2,
33073H3, 34098H4 ... 34098H4, 79,408, 16,383, 16, 63, 40.9, 40,900. ... http://knowledge.seagate.com/articles/en_US/FAQ/195291en?language=en_US - 43k
Follow the link to get full configurations
Feb 01, 2012 | Maxtor Hard Drive
How the jumper setting is done for maxtor n256j50
If this is an IDE/PATA hard drive then the jumper settings are marked on the circuit board.
MA = master
SL = slave
CS = cable select
If this hard drive is the one installed on the Primary IDE controller the the jumper has to be set to Master. If it won't boot up then the jumper needs to be set to Cable select.
If this hard drive is a second hard drive and is connected to the 2nd connector on the IDE data cable that is connected to the primary IDE controller then the jumper must be set to Slave.
If this hard drive is a second hard drive and is connected to the secondary IDE controller and there is no other drive on the IDE data cable other than this hard disk the the jumper can be set to either Master or Slave.
If there is a CD drive on this cable too then the drives on this data cable then the jumpers on each drive must be set differently, they cannot be set the same jumper setting.
Feb 09, 2011 | Maxtor Hard Drive
I have a maxtor H.D. model # 31024h1 , i cannot find the jumper settings to distinguish between master and slave
Typically, for older MAXTOR drives, put the jumper on the 2 pins closest to where the ribbon-cable connects, to set it to 'MASTER'.
Remove all the jumpers to set it to 'SLAVE'.
Aug 24, 2010 | Computers & Internet
Where do i place the jumpers to set a maxtor model 53073U6 to run as slave?
See the sticker on the HDD. There is written the pins, you have to put the jumper.That should be on the 2nd set from the IDE end. Just removing the jumper should make it slave too. Run it without jumper. Thanks
Jun 05, 2009 | Maxtor Hard Drive
I want to install the Maxtor 32049H2 N256 as slave Hd in my new computer how do I set the jumpers ?
hi frnds... step by step way are following link
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/
or
http://www.easeus.com/resource/install-ide-hard-drive.htm
Apr 25, 2009 | Maxtor Hard Drive
Slave harddrive jumper settings
usualy its just one jumper if no jumper on maxtors becomes slave. jumper on 50 is master. if u use cable select.. on same ide another device must also be cable select.
if one is master other is slave on same ide.
Jul 15, 2008 | Maxtor Hard Drive
Jumper settings for an older maxtor hard drive
Support can be found at Seagate.com in case this is not the exact drive. The model number you listed was not an exact match.
Nov 25, 2007 | Maxtor Hard Drive
Maxtor 40gb hard drive as master
Hi, Below is an image of a Maxtor 3.5 HD settings as shown on the actual HD. If you are connecting 2 of them in a single IDE flat cable/strip, one must be master and the other must be slave. Jumper settings on the left is for master, the second is for slave. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
956 people viewed this question
David Payne
David Payne
