Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Menu pops up constantly
The menu will not stop popping up on screen, took batteries out of remote, not the remote causing the problem, and the menu button is not stuck on console. it did not do it yesterday, but saturday and today menu pops up every few seconds.
  • crazylikafox Oct 17, 2008
    I unhooked the button circuit board, and the menu stopped popping up,
    would it cause any problems later on down the road if i just leave it
    unhooked?
Try this....Go to MENU/Options/Demo
Make sure menu is off and freeze frame is off...if not.. select off and this cured my problem on a sharp aquos model
Posted on Nov 10, 2008
    Genius:
  • 1,030 Answers
There is a problem with the front control buttons. i see this quite often at the shop. the best way to deternmine this is to remove the buttons and use the remote to turn it on if it goes away then i would suggest replace the button cuicit board assembly
Posted on Oct 17, 2008
  • Willie Howell Oct 18, 2008
    other than not being able to control without the buttons.. then the remote should funtction in that capacity
Why does the menu and channel display keeping poping up while watching tv?
1. Remove the batteries from your remote to ensure that is not sending signals to the TV.
2. The TV may have an internal problem and might need repair.
May 11, 2014 | AOC Televison & Video
A black box randomly pops up on my tv screen constantly...
It part of the caption functions is on.Tries find in ur tv menu,goto captioning functions like CC1,2,3 and Text 1,2,3.Turn it all off.These radom black boxes and trying typing somethings,should stop.
Jul 20, 2010 | Olevia 237T 37 in. LCD TV
Menu screen popping up
Remove the batteries, un-screw the back cover of your remote, you'll find a circuit board take that off, clean the other side of that board (the one painted green) with a cotton slighty wet with rubbing alcohol as well as the black carbon on your remote pad, let it dry put it back together replace with a new battery, I guess this'll work
Jun 05, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Menu keeps popping up
check remote faulty batteries/take them out see if it stops doing it also depress menu button on tv might be stuck
Nov 10, 2009 | Philips 42PF9630A 42 in. Plasma Television
Menu pops up while tv is on
Isolate the problem by removing the batteries from the remote. If the problem goes away replace the remote: "CHEAP" .
If the problem does not go away, the problem is in the TV, repair the TV "EXPENSIVE" !
Aug 28, 2009 | Televison & Video
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
The menu screen pops up and won't go away.
I see this alot at the shop common problem... the front conrtrol buttons have become damaged. you need to replace it. You can remove the front panel and leave it out until you can get the front keyboard cuicit board. Just use your remote to control the tv. to remove the board just remove the front middle panel via the t20 torx screws. then unplug the connector. You can get a new cuicit board via union electonics... you need the entire model number...r52wh73 yx1 or yx2 something like that it is in small letters on the same label as the large model number, Let me know if you need any more help on this repair.
Oct 25, 2008 | RCA R52WH73 Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
209 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
