Question about Gateway Computers & Internet
The computer keeps adding to 'D' disc on auto backup and will not now function as it is full
  • Jeff Strader
    Jeff Strader May 11, 2010
    does it give you the option to make a multidaisk set?
Back from St Louis Mo. I tried to access the website shown above and got no where. I finally did go into the built in 'fix-it' programs in this machine. I logged in as 'administrator' - created a password and did a 'system restore' to an old date - but I did this from a factory installed program and not from the 'back up' menu that comes up in the 'maintenance' venue. I'm no genius in VISTA or any other computer problem, but I have found with VISTA that if you keep looking around, there is a way - most often - if you can find it, where the computer has the capability to repair internally. I'm saying this coming directly from Windows 98. Still do not know how to clear the 'D' disc, but all else now works again. Too much time involved so 'till it stops again I'm done trying.
Posted on Oct 22, 2008
I am scheduled to leave for St Louis Mo in about two hours so do not have time now to go in to all this, BUT I will go in to all this when I get back. For now - try www.sparebackup.com/support and refer to code 29 - error. My operating system is, of course, Windows VISTA Home Premium. Can you tell I hate it???
Hope you get it resolved.
Posted on Oct 16, 2008
  • 749 Answers
Im not sure what program your using t backup, but thier shouldbe a setting in the program for you to back up to a file on the other drive or an option to make a multi disk set.
look for a button (in the backup program) that say options or properties or settings .
Posted on Oct 15, 2008
I need to restore my computer using the Function keys and do not remember which Function key(s) to use
If you are certain that there is a recovery partition with a factory default image then your user manual should include the instructions on how to access it.
HP normally uses a backup and recovery software rather than a recovery partition with a default image. This setup requires that you make restoration discs before using the computer in case something goes wrong.
Alternatively, you can keep restarting the computer and hit a different function key each time in an attempt to access a recovery program.
If you own a copy of Windows you can also just put in the disc and install Windows to your C: drive and over-write the existing installation.
As a last resort, you can order a set of recovery discs from HP's Customer Support.
Jul 06, 2012 | HEWLETT-PACKARD Compaq DC5850...
Tip
How to repair hard drive
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Operating software installation or build CD</span> </li> <li> <span>Boot-up disc</span> </li> <li> <span>System restore CD</span> </li> <li> <span>Backup tape</span> </li></ul> <ol> <li> Look for tell-tale signs that your computer is about to crash or fail. Extreme slowness, repeated blue screen and noise or clicking are sometimes signs that your computer hard drive is about to crash. When you hear the sound of clicking, scraping or grinding, immediately turn off or shut down your computer. Doing so will prevent any loss of data.<br /> </li> <li> Power down and then power up. Sometimes, hard drive crashes can be easily recovered by doing a power shutdown of the computer. Then, after waiting for a couple of minutes, power it back up again. The initial hard drive crash may not be too serious, but if it happens often, start performing a full system backup, if you haven't been doing so, to be able to recover your data should the inevitable happen.<br /> </li> <li> <span> <a><img src="repair-hard-drive-crashes-1.3-120X120.jpg" /></a> jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/8f/3a/repair-hard-drive-crashes-1.3-800X800.jpg'); }); PC cable or component connection </span> Ensure that your hard drive and other internal components are seated properly. If Steps 1 and 2 do not work, you may need to open your computer's CPU to check on some of the drive connections. Sometimes connections get dislodged, especially if you move your computer box often. The symptom will manifest as if the hard drive has crashed, giving you a "disk error" when you try to boot up your computer. First, turn off your computer and unplug it. Then remove the case of your computer box. Press on each connector to connect it properly. Put the cover back again, plug the computer and power it back up.<br /> </li> <li> <span> <a><img src="repair-hard-drive-crashes-1.4-120X120.jpg" /></a> jQuery(document).ready(function(){ jQuery('#jsArticleStep4 span.image a:first').attr('href','http://i.ehow.com/images/a04/8f/3a/repair-hard-drive-crashes-1.4-800X800.jpg'); }); Boot from CD drive with a boot disc </span> Insert your boot disc and try to boot up your computer using the disc. Once you are able to do so, you can reinstall your operating system. After installing your software, proceed to perform data recovery using your ghost CD or backup.<br /> </li> <li> Use an emergency repair disc to get your computer to work again. Then restore from the last known good configuration.<br /> </li> <li> Reinstall your operating system using the installation or system restore CD that came with your computer when you first purchased it. It will take you through a series of steps that include formatting your hard drive, which will then erase your data. Do this as a last resort.<br /> </li> <li> Recover your data by using a restore and recovery software or using your most recent backup after you have reinstalled the operating system in the previous step.<br /> </li> <li> Reinstall your applications that did not come with your computer when you bought it. Some examples would be Adobe Photoshop, anti-virus software and movie-making software.<br /> </li></ol> jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); <span>Tips & Warnings</span> <ul> <li> Call technical support if you are unsure of what to do. They can walk you through the important steps. You can also take your computer to a PC technician who, for a fee, will do a system restore and data recovery for you.</li> <li> Make it a habit, even if your computer is healthy, to do a complete backup so your important data will not be lost.</li> <li> Never attempt to open your computer without first powering it off to avoid being electrocuted.</li> <li> Do not open your hard drive case; the components are so sensitive that even a single speck of dust may erase your data.</li></ul>
on Dec 23, 2010 | Computers & Internet
My ps3 menu wont show up, t will just keep showing the background what should i do
This is the result of having certain errors in the system or bios of your console. It usually requies you to completely format the system and you can do that on your own by following the steps below.
Also, before you reset make sure that there is no disc in the console that it might be trying to load unsuccessfully and therefore causing it to get stuck on the background screen(this usually happens when you are trying to load a disc that is bad and you have the auto-play function on from your settings menu)
HARD RESET INSTRUCTIONS
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully, this would solve your problem.
Jan 16, 2011 | Sony Playstation 3 (PS3) Console
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
How do I transfer my itunes to another computer?
Cucusoft iTunes to iTunes Transfer is an easy to use iTunes utility designed to help you backup/recover/transfer your whole iTunes library and media files. It's a simple way to keep your iTunes in sync everywhere. You can use "iTunes to iTunes Transfer" to backup your own iTunes library or synchronize multiple iTunes on different computers. The backed up library file is pretty easy to transfer to other iTunes, and it's easy to manage. So with this iTunes Transfer software, you can manage your iPod/iPhone/... on different PCs
Transfer photos, music, videos from iPhone iPad iPod to computer or Mac by this software:
http://www.mustsoftware.com/Cucusoft-iPad-iPhone-iPod-to-Computer-Transfer-guide.html
For iphone/ipod/ipad to Mac transfer
Jul 27, 2010 | Apple iTunes
Toshiba Satellite auto backing up all, maxing out D
This sounds like your Toshiba software is the program performing the auto backup. Go into the start button and find the Toshiba Auto backup program and start it. Go to settings and from there you can edit the settings to either backup once a week, month or never. Go to control panel > folder options > View > scroll down a little past where you check "show hidden files and look for a checked box "Hide Protected Operating system files". Uncheck this box, click apply and ok.
If you want to clear out that partition of all the backup files and you are sure you do not need them or you would like to use the space to keep music, pictures etc. Then I can show you how to go the the control panel and reformat that particular partition to clear it.
First, just try to go to the partition and open it. If you see all the files in there, you can simply select all and delete. If you still cannot see the files in the partition, then lets reformat it. Go to the control panel > administration tools > computer management > look in the left pane and click on disc management. The service will load all the drives at this point. Look in the middle pane, lower half for your setup, you should see your drive with two partitions listed side by side. On the "D" partition, you can right click anywhere in the "D" drive area and select "delete Simple volume". This will erase everything on the partition and make the partition unallocated space. Once that is done, right click on the unallocated space and select "Make simple volume". This will bring up a short guide to format the partition. It is already setup to format to the ntfs system, when the small window comes up it will ask you what drive letter to give the new partition, choose "D" and check that "Perform quick format" is checked. It will take a very short time to format the partition, once it is done you can exit from the program. Reboot the machine and enjoy a new empty partition ready to accept files. Go back into the control panel and folder options and check the box to hide the protected system files.
Jun 10, 2010 | Toshiba Satellite T100 Series Black...
I have an Acer Aspire 5720, ive had it for a year now and it is starting to slow down. I have lost the booklet to it and i need to do a master reset on it. Ive already backed everything up im just finding...
This was taken straight out of the manual for your model, which can be found here.
Acer eRecovery Management
Acer eRecovery Management is a tool to quickly backup and restore the system.
You can create and save a backup of the current system configuration to hard
disk, CD or DVD. You can also backup/restore the factory default image, and
reinstall applications and drivers.
Acer eRecovery Management consists of the following functions:
1 Create backup
2 Burn backup disc
3 Restore and recovery
This chapter will guide you through each process.
Note: This feature is only available on certain models. For systems
that do not have a built-in optical disc burner, plug in an external
optical disc burner before entering Acer eRecovery Management
for optical disc-related tasks.
When using Acer eRecovery Management, you may be prompted to enter the
Empowering Technology password to proceed. The Empowering Technology
password is set using the Empowering Technology toolbar or when first running
Acer eLock Management or Acer eRecovery Management.
Create backup
You can easily create full and fast (incremental) backup images of your system
configuration to hard disk from the main Acer eRecovery Management screen.
Note: Fast (incremental) Backup is only available after a Full
Backup is made.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 In the Acer eRecovery Management window, select the type of backup you
want to create using Full or Fast.
3 Follow the instructions on screen to complete the process.
83
English
Burn backup disc
Using the Burn Disc page of Acer eRecovery Management, you can burn the
factory default image, a user backup image, the current system configuration,
or an application backup image to CD or DVD.
2 Switch to the Burn Disc page by selecting the Burn Disc button.
3 Select the type of backup (factory default, user, current system,
application) you would like to burn to disc. Choosing to burn a user backup
will burn your most recently created backup image to disc.
4 Follow the instructions on screen to complete the process.
Note: Create a factory default image when you want to burn a
bootable disc that contains your computer's entire operating
system as it was delivered to you from the factory. If you wish to
have a disc that will allow you to browse the contents and install
selected drivers and applications, create an application backup
image instead — this disc will not be bootable.
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
Dec 20, 2009 | Acer Aspire 5720 Notebook
My licensed software backup disc was stolen. Is it possible to trace a computer that may have attempted to download it?
No there is no way to find out the stolen backup disc or the computer which has attempted to download .
Nov 03, 2009 | Adobe Creative Suite CS3 Design Premium...
Freezes half way threw system adding devices
If you made your recovery discs, then call up gateway and tell them you have defective discs, they will send you the factory install discs for free, try them and I bet you will have better results....Restore discs you make yourself are extreemly picky and are easliy ruined if something happens while youo are burning them (someone sends you an IM or email, windows auto updates) with all the hidden processes running in the background any one of them could have caused a glitch while you were making recovery cd's
Sep 27, 2009 | Gateway MX8711 Notebook
Installing Sims 2 expansion pack
Copy the neighborhood files and put them into documents then when you uninstall and reinstall move the files back in merge them and you will have all your towns.
Happy Simming
Apr 09, 2009 | EA - Electronic Arts The Sims Deluxe...
Computers & Internet Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
