FixYa.com
Tags:
Panasonic Portable Radio/Cassette Personal Cassette Player
Panasonic Portable Stereo CD System RX-DS25(tuner...
By Green1 - usenet poster
This portable CD/radio/cassette has barely audible FM although it will tune
normally. Its aerial connections are fine. The CD and Tape sections are also
fine.
Does anyone have experience with these sets or similar who could point me in
the right direction.
Jessie V.H
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 27, 2006
Not Rated (0)
Rachel007
Rachel007 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I could hit the local FM station from here with a rock(have tried more than
once). Anyway, problem solved(L6 on radio panel was open cct). Tks anyway
JVH
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Odud
Odud - usenet poster
Rating: 0%, 0 votes
Are you in an FM fringe area? Guess why I ask this? :-)
DalekDOS v(overflow): (I)Obey (V)ision impaired (E)xterminate
Solution #3
Not Rated (0)
pandamama
pandamama - usenet poster
Rating: 0%, 0 votes
Charles
Thanks for your reply
I checked the 5v supply to the demodulator section. L6 in series with this
supply was open circuit. It's a tubular type marked Brown Black Brown. I
make this 100 micro-henry. I changed it and its associated 100/10v
electrolytic and all is well.
Jessie V H
Solution #4
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
You may have a cold solder on the grounds or an electrolytic capacitor, causing
an extremely low voltage to be passed through the demodulator section.
You may also need to check to see if the electrolytic capacitors are leaky.
Other possibilities may be a dirty mode switch or dirty FM switch and/or
controls.
Also advise to check tape section to see if it records FM or AM band at proper
volume.
Charles Lucas
Subject: Panasonic Portable Stereo CD System RX-DS25(tuner fault ?)
Date: 6/16/01 1:58 AM EST
Message-id: <9gf07u$dgs$>
fine.
Jessie V.H
Can you Help with these Personal Cassette Players problems?
Sony Walkman cassette player WM...
the belt came out from the... Answer This...
Broken belt on magnavox MCB...
Where can I source a belt kit... Answer This...
Panasonic Portable Radio/Cassette Personal...
noise when taping on phone...
Panasonic model #: RQ 353 I can... Answer This...
Convert Records to CDs
I'd like to convert old LP... Answer This...
URGENT HELP cassette player...
i have an old PORTABLE CASSETTE... Answer This...
Repair Service
Find Personal Cas. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
