Question about Carrier 38CKC036 Air Conditioner
Blank thermastat i have a blank thermastat lcd
  • 1,420 Answers
Check for a blown fuse inside the air handler.
Posted on Oct 21, 2008
MY lights come on but the LCD screen is blank and it is beeping. Please help
Check that the LCD screen adjustment has not been dimmed or darkened. If that is not the case, then a component is or has most likely failed.
Dec 30, 2015 | Brother Sewing Machines
How do I get the battery out of the thermastat?
There is often a band under the battery that can be pulled to lift it. The band may not have been placed so that you can.
A pointed object might be used to push in at the NON-SPRING end of the cell and lift it out.
If those fail, try tapping it upside down to shake it loose.
Sep 01, 2014 | Honeywell Heating & Cooling
Thermastat display is blank
have you replaced the batteries in the thermostat? some didital thermostats have batteries and wont work when they are bad
May 07, 2012 | Heating & Cooling
Our Robert Shaw thermostat 9520 just went blank. Do you have any ideas, nothing is working?
Try replacing the batteries.
Remove the cover by using a coin or screwdriver to prise it off. Insert the coin at the left side between the backing plate and the the cover, and twist.
Romove old batteries and insert new ones.
Mar 06, 2010 | Shaw Robert RS-9420 Thermostat
1995 toyota 4runner gets hot with new thermastat gasket
the thermostat should be closed when you take it out, therefore the thermostat is bad. It does not closed.
May 22, 2009 | 1995 Toyota 4Runner
Will not heat
Are you getting 220 at the heating element from one lead to the other
Mar 29, 2009 | Dryers
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Blank Thermastat LCD
check power to the furnace.
Aug 10, 2008 | Carrier 38CKC036 Air Conditioner
Refrigerator blowing warm air.
check the thermastat with power off remove one wire on the thermastat and read across the two terminals of the thermastat with an ohm or resistance meter if set to highest setting on the thermastat you should get a resistance reading if you don not the thermastat is vad
May 17, 2008 | Amana ARB8057CSL Bottom Freezer...
Carrier 38CKC036 Air Conditioner Logo
87 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
